[GeoNode-devel] Custom geonode project installation
Dimitris Kar
dkarakostis at gmail.com
Wed Dec 19 09:01:08 PST 2018
Sorry there was a typo in my above email. I did meant "won't modify":
What eventually need is to have two different folders. One with the geonode
core project, which I won't modify and the other one with my_geonode
project, in which I will apply changes.
Ok. I will try this way.
Thanks!
On Wed, Dec 19, 2018 at 5:55 PM Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Dear Dimitris,
> So to understand, if I want to have my own geonode-project, I don't need
> to go through the process of installing 'geonode core‘.
> Exactly it´s installed as dependency via pip. You do not have to care
> about it.
> geonode core project, which I want modify and the other one with my_geonode
> I haven´t done this workshop yet. But you should not touch the core!
> Im quite sure the workshop is meant that you do your changes in
> geonode-project.
> Cheers,
> Toni
> CSGIS
> Kolonnadenstraße 1
> 04109 Leipzig
> Mobil +49/ (0) 176 6680 3198
> Tel +49/ (0) 341 24 04 738
> Fax +49/ (0) 341 24 04 73
> Web http://csgis.de
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
> ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> Am 19.12.2018 um 17:49 schrieb Dimitris Kar <dkarakostis at gmail.com>:
> Thanks Toni,
> to go through the process of installing 'geonode core'. I can directly
> install the geonode-project?
> But if I understand correctly the training instructions (
> http://geonode.org/dev-workshop/#/3/2) I need to follow the below steps
> after I have installed the 'geonode core project':
> 1. Make sure to run it just outside the geonode folder as we will keep
> them completely separate: django-admin.py startproject my_geonode
> --template=https://github.com/GeoNode/geonode-project/archive/master.zip
> -e py,rst,json,yml,ini,env,sample -n Dockerfile my_geonode
> 2. *workon geonode* and
> 3. execute: pip install -e my_geonode
> 4. DJANGO_SETTINGS_MODULE=my_geonode.local_settings paver start
> On Wed, Dec 19, 2018 at 5:27 PM Toni Schönbuchner <
>> Hi Dimitris,
>> it sounds you´re a bit puzzled between 'geonode core‘ and geonode-project.
>> To understand better see whats happening with geonode-project:
>> It installs `geonode core` as dependency:
>> https://github.com/GeoNode/geonode-project/blob/master/requirements.txt#L2
>> further loads/overwrites it´s settings:
>> https://github.com/GeoNode/geonode-project/blob/master/project_name/settings.py#L30
>> Doing so we can overwrite things like templates etc. in Geonode-Project
>> without touching
>> core files.
>> As a rule of thumb, if you´d like to commit changes to geonode core,
>> create a fork of the upstream
>> repository, do your changes and create a PR.
>> I think in your case – as you´d like to modify *your* specific version –
>> start by creating a geonode
>> project as described here (and ignore the first 'geonode core' dev setup):
>> https://github.com/GeoNode/geonode-project#create-a-custom-project
>> I hope I did not misunderstood your question.
>> Happy geonod’ ing.
>> – Toni
>> CSGIS
>> Kolonnadenstraße 1
>> 04109 Leipzig
>> Web http://csgis.de
>> Message: 1
>> Date: Wed, 19 Dec 2018 16:57:16 +0100
>> From: Dimitris Kar <dkarakostis at gmail.com>
>> To: geonode-devel <geonode-devel at lists.osgeo.org>
>> Subject: [GeoNode-devel] Custom geonode project installation
>> Message-ID:
>> <CAH4UFc99H4OuAxKUc+FhFZ=13gSJZDdMnH7Lj1=ec49Qg+6sgA at mail.gmail.com>
>> Content-Type: text/plain; charset="utf-8"
>> Hello all,
>> I am trying following the instructions from this workshop (
>> http://geonode.org/dev-workshop/#/2) in order to install GeoNode and a
>> GeoNode project. I have installed GeoNode in dev mode using a python
>> virtualenv + django development server method.
>> Then I follow the instructions in order to create a geonode-project as
>> following:
>> 1. cd ./geonode
>> 2. django-admin.py startproject wfp_geonode --template=
>> https://github.com/GeoNode/geonode-project/archive/master.zip -e
>> py,rst,json,yml,ini,env,sample -n Dockerfile wfp_geonode (I executed
>> this command without includong: -n Dockerfile wfp_geonode)
>> 3. workon geonode
>> 4. cd wfp_geonode
>> 5. pip install -e wfp_geonode
>> 6. cd ../geonode
>> 7. DJANGO_SETTINGS_MODULE=wfp_geonode.local_settings paver start
>> But when I actually run the command, I get the below command. If I am not
>> wrong, I remember, that I can not use geonode-project aside with a geonode
>> dev installation but this is not quite clear in the above workshop
>> presentation (see above link).
>> Did anyone had similar issues? Should I install a geonode for production
>> and use the geonode-project then?
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181219/c4eec3cc/attachment-0001.html>
More information about the geonode-devel
