[GeoNode-devel] Move to Release 2.8
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Feb 2 01:54:02 PST 2018
Not that easy to achieve right now, especially due to some incompatible
dependencies on which whom GeoNode core is currently based.
It's a bit I do not challenge the upgrade to Django 1.11, maybe something
changed in the meanwhile.
I'm also aware of some groups planning to give it a try.
For sure having updated Celery to version 4.0 should easy the process a bit
more.
In any case, we plan to discuss about GeoNode 3.0 architecture during the
GeoNode Summit, and base it on latest Django versions and Python 3. So,
let's see the outcomes of the meeting.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
2018-01-30 23:52 GMT+01:00 Jeremiah Cooper <jcooper at jeremiahcooper.com>:
> I would agree - it would be nice to see 2.8.x on Django 1.11.
> Thanks.
> Jeremiah Cooper
> On Tue, Jan 30, 2018 at 5:39 PM, Olivier Dalang <olivier.dalang at gmail.com>
> wrote:
>> Hello !
>> Django 1.8 LTS reaches end of support in April 2018, which means no more
>> fixes at all (even security fixes).
>> I think it would be nice to support 1.11 (which is the current LTS)
>> before releasing a new version of Geonode. Django 1.11 is probably now old
>> enough so that most third party apps would be compatible, and is still
>> supporting python 2, so it may be a reasonable amount of work.
>> Has anyone already worked on this yet ? I have only migrated smaller
>> Django projects, so I may be underestimating how much work this is...
>> Kind regards,
>> Olivier
>> On Thu, Jan 25, 2018 at 9:23 PM, Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> wrote:
>>> Ok Francesco,
>>> I will put some more consistency checks on the bash scripts then.
>>> Regards,
>>> Alessio Fabiani
>>> http://goo.gl/it488V for more information.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>>> 55054  Massarosa
>>> (LU)
>>> Italy
>>> phone: +39 0584 962313 <+39%200584%20962313>
>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>>> http://twitter.com/geosolutions_it
>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>> principi dettati dal D.Lgs. 196/2003.
>>> The information in this message and/or attachments, is intended solely
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>> copying, distribution, or either dissemination, either whole or partial, is
>>> strictly forbidden except previous formal approval of the named
>>> addressee(s). If you are not the intended recipient, please contact
>>> immediately the sender by telephone, fax or e-mail and delete the
>>> made after they were sent or for other risks which arise as a result of
>>> e-mail transmission, viruses, etc.
>>> 2018-01-25 10:19 GMT+01:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>> Alessio,
>>>> I confirm the error from Dave, which is saying the geoserver context
>>>> from Tomcat has been lost somehow. If I remember well you had the same
>>>> error initially just after started the alpha release right?
>>>> Francesco
>>>> Il 25 gen 2018, 10:13 +0100, Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it>, ha scritto:
>>>> Uhmm, yes it is possible.
>>>> Did not get such error on my previous tests, but I will investigate
>>>> more by using your cathed stacktrace.
>>>> Thanks for reporting.
>>>> Regards,
>>>> Alessio Fabiani
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> 55054
>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%3Chttps://maps.google.com/?q%3DVia%2Bdi%2BMontramito%2B3/A%2B55054%2B%25C2%25A0Massarosa%26entry%3Dgmail%26source%3Dg%3E%C2%A0Massarosa+%3Chttps://maps.google.com/?q%3DVia%2Bdi%2BMontramito%2B3/A%2B55054%2B%25C2%25A0Massarosa%26entry%3Dgmail%26source%3Dg%3E&entry=gmail&source=g>
>>>> Massarosa
>>>> (LU)
>>>> Italy
>>>> fax:     +39 0584 1660272 <+39%200584%201660272>
>>>> mob:   +39 331 6233686 <+39%20331%206233686>
>>>> 2018-01-25 10:03 GMT+01:00 Dave Kennewell <davekennewell at gmail.com>:
>>>>> First question - yes I confirm I typed the
>>>>> sudo geonode-updateip 54.252.237.189
>>>>> Second question - regards "is geoserver running":
>>>>> sudo service tomcat8 status shows tomcat8 is running fine, and wget to
>>>>> http://localhost:8080 establishes a connection with something, but it
>>>>> returns the 404.
>>>>> [image: Inline images 1]
>>>>> HOWEVER, after restarting tomcat8 manually (sudo service tomcat8
>>>>> restart), geoserver now is responsive.
>>>>> So it appears there is something in the configuration that is
>>>>> preventing geoserver from starting properly during the "sudo
>>>>> geonode-updateip" command?
>>>>> On 25 January 2018 at 12:42, Alessio Fabiani-2 [via OSGeo.org] <
>>>>> ml+s1560n5351221h66 at n6.nabble.com> wrote:
>>>>>> However from the logs it looks like geoserver is not running on port
>>>>>> 8080 ? Can you double check?
>>>>>> Regards,
>>>>>> Alessio Fabiani
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> 55054  Massarosa
>>>>>> (LU)
>>>>>> Italy
>>>>>> phone: +39 0584 962313 <0584%20962313>
>>>>>> fax:     +39 0584 1660272 <0584%20166%200272>
>>>>>> mob:   +39 331 6233686 <331%20623%203686>
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> 2018-01-25 9:40 GMT+01:00 Alessio Fabiani <[hidden email]
>>>>>> <http:///user/SendEmail.jtp?type=node&node=5351221&i=0>>:
>>>>>>> Hi Dave,
>>>>>>> did you run
>>>>>>> Regards,
>>>>>>> Alessio Fabiani
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> 55054  Massarosa
>>>>>>> (LU)
>>>>>>> Italy
>>>>>>> phone: <a href="tel:0584%20962313" value="+390584962313
>>>>>>> <0584%20962313>" target="_blank">+39 0584 962313 <0584%20962313>
>>>>>>> fax:     <a href="tel:0584%20166%200272" value="+3905841660272
>>>>>>> <0584%20166%200272>" target="_blank">+39 0584 1660272
>>>>>>> <0584%20166%200272>
>>>>>>> mob:   <a href="tel:331%20623%203686" value="+393316233686
>>>>>>> <331%20623%203686>" target="_blank">+39 331 6233686
>>>>>>> <331%20623%203686>
>>>>>>> 2018-01-25 8:28 GMT+01:00 Dave Kennewell <[hidden email]
>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5351221&i=1>>:
>>>>>>>> Hi Alessio,
>>>>>>>> I tried again this morning with a fresh machine using 2.8.0+rc10 -
>>>>>>>> The install worked fine, however the "sudo geonode-updateip" got a 404
>>>>>>>> talking to geoserver:
>>>>>>>> I also get the 404 if I visit the geoserver index page:
>>>>>>>> http://54.252.237.189/geoserver/index.html
>>>>>>>> Thanks as always
>>>>>>>> Dave
>>>>>>>> On 23 January 2018 at 12:44, Alessio Fabiani-2 [via OSGeo.org] <[hidden
>>>>>>>> email] <http:///user/SendEmail.jtp?type=node&node=5351221&i=2>>
>>>>>>>> wrote:
>>>>>>>>> Hi Dave, hi all,
>>>>>>>>> about your recent findings, I published 2.8.0rc9 which should fix
>>>>>>>>> this configuration issue.
>>>>>>>>> Other than this you don't need now to do "createsuperuser" anymore.
>>>>>>>>> A standard installation should now be working by just doing this
>>>>>>>>> sudo add-apt-repository ppa:geonode/testing
>>>>>>>>> sudo apt update
>>>>>>>>> sudo apt install geonode
>>>>>>>>> # For a local installation
>>>>>>>>> sudo geonode-updateip localhost
>>>>>>>>> # For a public setup
>>>>>>>>> IP_ADDRESS=$(ip route get 8.8.8.8 | awk '{print $NF; exit}')
>>>>>>>>> sudo geonode-updateip $IP_ADDRESS
>>>>>>>>> # You can also directly specify your public ip address or hostname
>>>>>>>>> sudo geonode-updateip www.mygeonode.org
>>>>>>>>> sudo service apache2 restart
>>>>>>>>> I'm currently looking into trying to automatically set the "local"
>>>>>>>>> IP and configuration automatically.
>>>>>>>>> Regards,
>>>>>>>>> Alessio Fabiani
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> 55054  Massarosa
>>>>>>>>> (LU)
>>>>>>>>> Italy
>>>>>>>>> 2018-01-23 6:29 GMT+01:00 Dave Kennewell <[hidden email]
>>>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350910&i=0>>:
>>>>>>>>>> Hi Alessio,
>>>>>>>>>> Yes, I agree it's more a configuration issue than an install
>>>>>>>>>> issue. The package install worked fine.
>>>>>>>>>> When I login to the geoserver GUI, the Redirect URI is listed
>>>>>>>>>> with an additional slash after geoserver:
>>>>>>>>>> And in
>>>>>>>>>> Django admin -> Django OAuth Toolkit -> Applications ->
>>>>>>>>>> GeoServer
>>>>>>>>>> it lists the Redirect uris without the "/index.html" appended:
>>>>>>>>>> [image: Inline images 2]
>>>>>>>>>> I copied the Redirect uri from Django to the geoserver Redirect
>>>>>>>>>> URI box, then restarted both tomcat8 and apache2.
>>>>>>>>>> Now
>>>>>>>>>> http://54.206.23.196/geoserver/web/
>>>>>>>>>> gives me a 404 error and the model preview no longer shows the
>>>>>>>>>> geoserver layers...
>>>>>>>>>> I notice you've run a few more builds overnight. Let me know when
>>>>>>>>>> you're ready and I'll try again from scratch.
>>>>>>>>>> On 22 January 2018 at 14:05, Alessio Fabiani-2 [via OSGeo.org] <[hidden
>>>>>>>>>> email] <http:///user/SendEmail.jtp?type=node&node=5350910&i=1>>
>>>>>>>>>> wrote:
>>>>>>>>>>> Hi Dave,
>>>>>>>>>>> thank you very much for your help and feedbacks.
>>>>>>>>>>> From what you reported it seems that the installation process
>>>>>>>>>>> went well it is mostly a configuration issue.
>>>>>>>>>>> In particular it looks like on GeoNode Admin > Django OAuth
>>>>>>>>>>> Toolkit > Applications (http://54.206.23.196/admin/oa
>>>>>>>>>>> uth2_provider/application/) the "GeoServer" Application is
>>>>>>>>>>> missing the correct "REDIRECT_URI"s
>>>>>>>>>>> [image: Immagine incorporata 1]
>>>>>>>>>>> In your specific use case you will need to add to the above
>>>>>>>>>>> configured on you GeoNode instance, the ones specified on GeoServer oauth2
>>>>>>>>>>> configuration.
>>>>>>>>>>> - Login to GeoServer Admin GUI with admin credentials (by
>>>>>>>>>>> default admin / geoserver)
>>>>>>>>>>> - Go to Security > Authentication > geonode-oauth2 and make sure
>>>>>>>>>>> the "Redirect URI" is listed on GeoNode App
>>>>>>>>>>> [image: Immagine incorporata 2]
>>>>>>>>>>> Also, if the "geonode-updateip" command went well, you should
>>>>>>>>>>> see here all hosts pointing to your public IP. Long story short both
>>>>>>>>>>> GeoServerver and GeoNode should report in your case "
>>>>>>>>>>> http://54.206.23.196/geoserver/" as Redirect URI.
>>>>>>>>>>> *Summary*
>>>>>>>>>>> From what you reported - and if you can confirm the steps above
>>>>>>>>>>> fix your issue - it looks to me that the problem is on updateip management
>>>>>>>>>>> command more than on the installation process.
>>>>>>>>>>> In any case this must be improved and fixed. I will double check
>>>>>>>>>>> and do more tests on this.
>>>>>>>>>>> *Notice*
>>>>>>>>>>> On a PUBLIC instance you *must* perform other manual steps
>>>>>>>>>>> before exposing it to the web:
>>>>>>>>>>> 1. Update the GeoServer by changing:
>>>>>>>>>>>      Internal "admin" password - this change must be reflected
>>>>>>>>>>> on GeoNode local_settings also
>>>>>>>>>>>      Internal "master" password
>>>>>>>>>>> 2. Update OAuth2 Client-ID and Client-Secret tokens
>>>>>>>>>>>     Update GeoNode GeoServer Oauth2 App
>>>>>>>>>>>     Update GeoServer "geonode-oauth2" service accordingly
>>>>>>>>>>> 3. Change the GeoNode default "admin" password
>>>>>>>>>>>    *warning:* "admin" user must exists. Do not remove it, just
>>>>>>>>>>> change its passowrd
>>>>>>>>>>>    *note:* "admin" user *is different* from internal GeoServer
>>>>>>>>>>> admin one
>>>>>>>>>>> 4- make sure the DB does not use simple passwords and users
>>>>>>>>>>> 5- double check the filesystem permissions and secure static /
>>>>>>>>>>> upload folders
>>>>>>>>>>> Regards,
>>>>>>>>>>> Alessio Fabiani
>>>>>>>>>>> @alfa7691
>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa+(LU)+Italy&entry=gmail&source=g>
>>>>>>>>>>> Italy
>>>>>>>>>>> phone: <a href="tel:0584%20962313" value="<a
>>>>>>>>>>> href="tel:0584%20962313" value="+390584962313 <0584%20962313>"
>>>>>>>>>>> target="_blank">+390584962313" target="_blank"><a
>>>>>>>>>>> href="tel:0584%20962313" value="+390584962313" target="_blank">+39
>>>>>>>>>>> fax:     <a href="tel:0584%20166%200272" value="<a
>>>>>>>>>>> <0584%20166%200272>" target="_blank">+3905841660272"
>>>>>>>>>>> target="_blank"><a href="tel:0584%20166%200272" value="
>>>>>>>>>>> +3905841660272 <0584%20166%200272>" target="_blank">+39 0584
>>>>>>>>>>> mob:   <a href="tel:331%20623%203686" value="<a
>>>>>>>>>>> <331%20623%203686>" target="_blank">+393316233686"
>>>>>>>>>>> target="_blank"><a href="tel:331%20623%203686" value="
>>>>>>>>>>> +393316233686" target="_blank">+39 331 6233686
>>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>>> 2018-01-22 8:16 GMT+01:00 Dave Kennewell <[hidden email]
>>>>>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350773&i=0>>:
>>>>>>>>>>>> Hi Alessio,
>>>>>>>>>>>> Thanks so much for putting the energy into this. I made two
>>>>>>>>>>>> tries to get it working:
>>>>>>>>>>>> ___________________________________________________
>>>>>>>>>>>> *First attempt*
>>>>>>>>>>>> I installed on a fresh 16.04 Ubuntu server EC2 instance on AWS.
>>>>>>>>>>>> The package install worked fine (although took +30mins to download the
>>>>>>>>>>>> packages - I guess this is normal for a new launchpad repo).
>>>>>>>>>>>> However the command
>>>>>>>>>>>> will pick up the PRIVATE IP address on an Amazon instance,
>>>>>>>>>>>> which leads to "400 Bad Request" errors when trying to access Geonode
>>>>>>>>>>>> through the internet.
>>>>>>>>>>>> So I run the command instead with the PUBLIC IP:
>>>>>>>>>>>> sudo geonode-updateip 54.206.48.105
>>>>>>>>>>>> and now it throws and error while "Inspecting the available
>>>>>>>>>>>> layers in GeoServer" (apologies, I didn't record the exact error before I
>>>>>>>>>>>> terminated the machine & realised that would have been useful!)
>>>>>>>>>>>> But, the django part of geonode is accessible now, just not the
>>>>>>>>>>>> geoserver parts. I don't think it was valuable to delve into custom config
>>>>>>>>>>>> to get a release working, so I tried again from scratch...
>>>>>>>>>>>> ____________________________________________________
>>>>>>>>>>>> *Second attempt*
>>>>>>>>>>>> I terminated the first machine and started again but this time
>>>>>>>>>>>> I just updated to the PUBLIC IP:
>>>>>>>>>>>> sudo geonode-updateip 54.206.23.196
>>>>>>>>>>>> Now there's no errors, and both django and geoserver parts of
>>>>>>>>>>>> the app are at least working. I can upload both raster and vector layers,
>>>>>>>>>>>> and they will display in the map preview.
>>>>>>>>>>>> However a few quick tests show the following bugs:
>>>>>>>>>>>> 1. Once I'm logged in to the django app, if I try and log in to
>>>>>>>>>>>> the geoserver index page using the geonode button, I get the following
>>>>>>>>>>>> error in my browser:
>>>>>>>>>>>>> Error: invalid_request
>>>>>>>>>>>>> Mismatching redirect URI.
>>>>>>>>>>>> 2. The vector layer is displayed in the map preview map (
>>>>>>>>>>>> http://54.206.23.196/layers/geonode:model_boundary), but I get
>>>>>>>>>>>> pink tiles if I try and "create a map" and view in geoexplorer.  (
>>>>>>>>>>>> http://54.206.23.196/maps/new?layer=geonode:model_boundary)
>>>>>>>>>>>> I'll leave this instance up & running for a couple of days if
>>>>>>>>>>>> you wish to investigate. I can send you superuser details direct if it will
>>>>>>>>>>>> help debug, let me know.
>>>>>>>>>>>> Thanks again
>>>>>>>>>>>> Dave
>>>>>>>>>>>> On 19 January 2018 at 17:20, Alessio Fabiani-2 [via OSGeo.org]
>>>>>>>>>>>> <[hidden email]
>>>>>>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350773&i=1>> wrote:
>>>>>>>>>>>>> Release process ongoing.
>>>>>>>>>>>>> For whom willing to try geonode 2.8.0, on a clean Ubuntu 16.04
>>>>>>>>>>>>> instance just run the following commands
>>>>>>>>>>>>> sudo apt update
>>>>>>>>>>>>> geonode createsuperuser
>>>>>>>>>>>>> This is still under testing, so 1. do not try this on
>>>>>>>>>>>>> production servers - or on server where you have installations you don't
>>>>>>>>>>>>> want to break ; 2. it is possible that something goes wrong - in this case
>>>>>>>>>>>>> please report to me
>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>> Alessio Fabiani
>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>> 55054  Massarosa
>>>>>>>>>>>>> (LU)
>>>>>>>>>>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa+%3Chttps://maps.google.com/?q%3DVia%2Bdi%2BMontramito%2B3/A%2B55054%2B%25C2%25A0Massarosa%26entry%3Dgmail%26source%3Dg%3E+(LU)+Italy&entry=gmail&source=g>
>>>>>>>>>>>>> Italy
>>>>>>>>>>>>> href="tel:0584%20962313" value="<a href="tel:0584%20962313" value="
>>>>>>>>>>>>> +390584962313 <0584%20962313>" target="_blank">+390584962313"
>>>>>>>>>>>>> target="_blank"><a href="tel:0584%20962313" value="
>>>>>>>>>>>>> +390584962313" target="_blank">+390584962313"
>>>>>>>>>>>>> target="_blank"><a href="tel:0584%20962313" value="<a
>>>>>>>>>>>>> target="_blank">+39 0584 962313 <+39%200584%20962313>
>>>>>>>>>>>>> href="tel:0584%20166%200272" value="<a href="tel:0584%20166%200272" value="
>>>>>>>>>>>>> +3905841660272" target="_blank"><a
>>>>>>>>>>>>> target="_blank"><a href="tel:0584%20166%200272" value="<a
>>>>>>>>>>>>> href="tel:331%20623%203686" value="<a href="tel:331%20623%203686" value="
>>>>>>>>>>>>> +393316233686 <331%20623%203686>" target="_blank">
>>>>>>>>>>>>> +393316233686" target="_blank"><a href="tel:331%20623%203686"
>>>>>>>>>>>>> value="+393316233686" target="_blank">+393316233686"
>>>>>>>>>>>>> target="_blank"><a href="tel:331%20623%203686" value="<a
>>>>>>>>>>>>> href="tel:331%20623%203686" value="+393316233686"
>>>>>>>>>>>>> target="_blank">+393316233686" target="_blank"><a
>>>>>>>>>>>>> target="_blank">+39 331 6233686 <+39%20331%206233686>
>>>>>>>>>>>>> intended solely for the attention and use of the named addressee(s) and may
>>>>>>>>>>>>> be confidential or proprietary in nature or covered by the provisions of
>>>>>>>>>>>>> 2017-12-23 11:29 GMT+01:00 Paolo Corti <[hidden email]
>>>>>>>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=0>>:
>>>>>>>>>>>>>> +1!
>>>>>>>>>>>>>> of course
>>>>>>>>>>>>>> Paolo
>>>>>>>>>>>>>> On Fri, Dec 22, 2017 at 12:47 AM, Francesco Bartoli
>>>>>>>>>>>>>> <[hidden email]
>>>>>>>>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=1>>
>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> > Hi Rizky,
>>>>>>>>>>>>>> > yes you should backport it to 2.7.x which will become 2.8.0
>>>>>>>>>>>>>> then.
>>>>>>>>>>>>>> > Ciao
>>>>>>>>>>>>>> > Il giorno 21/dic/2017, alle ore 22:49, Rizky Maulana Nugraha
>>>>>>>>>>>>>> > <[hidden email]
>>>>>>>>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=2>> ha
>>>>>>>>>>>>>> scritto:
>>>>>>>>>>>>>> > +1
>>>>>>>>>>>>>> > Can I also know how are you going to release 2.8? Is it
>>>>>>>>>>>>>> coming from 2.7.x
>>>>>>>>>>>>>> > branch? I would like to include qgis-server backend if
>>>>>>>>>>>>>> possible, but that
>>>>>>>>>>>>>> > depends on how much effort that would be. At the moment,
>>>>>>>>>>>>>> only master branch
>>>>>>>>>>>>>> > have qgis-server backend.
>>>>>>>>>>>>>> > Software Developer
>>>>>>>>>>>>>> > Kartoza.com
>>>>>>>>>>>>>> > On Dec 22, 2017 02:15, "Tom Kralidis" <[hidden email]
>>>>>>>>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=3>>
>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> >> +1
>>>>>>>>>>>>>> >> ..Tom
>>>>>>>>>>>>>> >> Sent from my iPhone
>>>>>>>>>>>>>> >> On Dec 21, 2017, at 14:13, Simone Dalmasso <[hidden email]
>>>>>>>>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=4>>
>>>>>>>>>>>>>> >> wrote:
>>>>>>>>>>>>>> >> +1!
>>>>>>>>>>>>>> >> 2017-12-21 19:52 GMT+01:00 Jeremiah Cooper <[hidden email]
>>>>>>>>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=5>>:
>>>>>>>>>>>>>> >>> +1.
>>>>>>>>>>>>>> >>> Thanks.
>>>>>>>>>>>>>> >>> Jeremiah Cooper
>>>>>>>>>>>>>> >>> On Thu, Dec 21, 2017 at 1:06 PM, Alessio Fabiani
>>>>>>>>>>>>>> >>> <[hidden email]
>>>>>>>>>>>>>> <http:///user/SendEmail.jtp?type=node&node=5350525&i=6>>
>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> >>>> +1
>>>>>>>>>>>>>> >>>> Regards,
>>>>>>>>>>>>>> >>>> Alessio Fabiani
>>>>>>>>>>>>>> >>>> @alfa7691
>>>>>>>>>>>>>> >>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+%0D+%3E%3E%3E%3E+55054%C2%A0+Massarosa&entry=gmail&source=g>
>>>>>>>>>>>>>> >>>> 55054  Massarosa
>>>>>>>>>>>>>> (LU)
>>>>>>>>>>>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A+%0D+%3E%3E%3E%3E+55054%C2%A0+Massarosa+%3Chttps://maps.google.com/?q%3DVia%2Bdi%2BMontramito%2B3/A%2B%250D%2B%253E%253E%253E%253E%2B55054%25C2%25A0%2BMassarosa%26entry%3Dgmail%26source%3Dg%3E+(LU)+%0D+%3E%3E%3E%3E+Italy&entry=gmail&source=g>
>>>>>>>>>>>>>> >>>> Italy
>>>>>>>>>>>>>> >>>> phone: <a href="tel:%2B39%200584%20962313" value="<a
>>>>>>>>>>>>>> href="tel:0584%20962313" value="<a href="tel:0584%20962313" value="<a
>>>>>>>>>>>>>> +390584962313" target="_blank">+390584962313 <0584%20962313>"><a
>>> [Message clipped]
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180202/424a0938/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180202/424a0938/attachment-0001.png>
More information about the geonode-devel mailing list
