[GeoNode-devel] 2.8rc11 API errors
Dave Kennewell davekennewell at gmail.com
Mon Feb 12 01:06:06 PST 2018
Thanks Jonathan, appreciate the feedback.
I found the solution - it was a configuration issue on my behalf.
It turns out I had pinned an old version of Tastypie in the setup.py file
of my geonode-project template, my bad.
On 12 February 2018 at 06:28, Jonathan Doig <j.doig at unsw.edu.au> wrote:
> Hi Dave
> Those API URLs work fine for me on a fresh 2.8rc11 installed last week per
> Alessio’s instructions (attached).
> I’m using a bare Ubuntu 16.04 on AWS EC2 tx2-large: 16 GB RAM,  4 cores.
> Jonathan
> *From:* geonode-devel [mailto:geonode-devel-bounces at lists.osgeo.org] *On
> Behalf Of *Dave Kennewell
> *Sent:* Sunday, 11 February 2018 9:55 PM
> *To:* geonode-devel <geonode-devel at lists.osgeo.org>
> *Subject:* [GeoNode-devel] 2.8rc11 API errors
> Hi all,
> I'm testing 2.8rc11, and any call to the /api/base or /api/layers or
> /api/maps endpoint gives the following error:
> Internal Server Error: /api/layers/
>  Traceback (most recent call last):
>    File "/usr/local/lib/python2.7/dist-packages/tastypie/resources.py", line 211, in wrapper
>      response = callback(request, *args, **kwargs)
>    File "/usr/local/lib/python2.7/dist-packages/tastypie/resources.py", line 438, in dispatch_list
>      return self.dispatch('list', request, **kwargs)
>    File "/usr/local/lib/python2.7/dist-packages/tastypie/resources.py", line 470, in dispatch
>      response = method(request, **kwargs)
>    File "/usr/local/lib/python2.7/dist-packages/geonode/api/resourcebase_api.py", line 666, in get_list
>      **self.remove_api_resource_names(kwargs))
>    File "/usr/local/lib/python2.7/dist-packages/tastypie/resources.py", line 2100, in obj_get_list
>      applicable_filters = self.build_filters(filters=filters)
>    File "/usr/local/lib/python2.7/dist-packages/geonode/api/resourcebase_api.py", line 134, in build_filters
>      filters=filters, ignore_bad_filters=False, **kwargs)
>  TypeError: build_filters() got an unexpected keyword argument 'ignore_bad_filters'
> Can someone replicate this or is it my config error?
> thanks
> Dave
> ---------- Forwarded message ----------
> From: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> To: Paolo Corti <pcorti at gmail.com>
> Cc: geonode-devel <geonode-devel at lists.osgeo.org>
> Bcc:
> Date: Fri, 19 Jan 2018 13:19:32 +0000
> Subject: Re: [GeoNode-devel] Move to Release 2.8
> Release process ongoing.
> For whom willing to try geonode 2.8.0, on a clean Ubuntu 16.04 instance
> just run the following commands
> sudo add-apt-repository ppa:geonode/testing
> sudo apt update
> sudo apt install geonode
> geonode createsuperuser
> IP_ADDRESS=$(ip route get 8.8.8.8 | awk '{print $NF; exit}')
> sudo geonode-updateip $IP_ADDRESS
> sudo service apache2 restart
> This is still under testing, so 1. do not try this on production servers -
> or on server where you have installations you don't want to break ; 2. it
> is possible that something goes wrong - in this case please report to me
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> 2017-12-23 11:29 GMT+01:00 Paolo Corti <pcorti at gmail.com>:
>> +1!
>> of course
>> Paolo
>> On Fri, Dec 22, 2017 at 12:47 AM, Francesco Bartoli
>> <xbartolone at gmail.com> wrote:
>> > Hi Rizky,
>> > yes you should backport it to 2.7.x which will become 2.8.0 then.
>> > Ciao
>> > Il giorno 21/dic/2017, alle ore 22:49, Rizky Maulana Nugraha
>> > <rizky at kartoza.com> ha scritto:
>> > +1
>> > Can I also know how are you going to release 2.8? Is it coming from
>> 2.7.x
>> > branch? I would like to include qgis-server backend if possible, but
>> that
>> > depends on how much effort that would be. At the moment, only master
>> branch
>> > have qgis-server backend.
>> > Software Developer
>> > Kartoza.com
>> > On Dec 22, 2017 02:15, "Tom Kralidis" <tomkralidis at gmail.com> wrote:
>> >> +1
>> >> ..Tom
>> >> Sent from my iPhone
>> >> On Dec 21, 2017, at 14:13, Simone Dalmasso <simone.dalmasso at gmail.com>
>> >> wrote:
>> >> +1!
>> >> 2017-12-21 19:52 GMT+01:00 Jeremiah Cooper <jcooper at jeremiahcooper.com
>> >>> +1.
>> >>> Thanks.
>> >>> Jeremiah Cooper
>> >>> On Thu, Dec 21, 2017 at 1:06 PM, Alessio Fabiani
>> >>> <alessio.fabiani at geo-solutions.it> wrote:
>> >>>> +1
>> >>>> Regards,
>> >>>> Alessio Fabiani
>> >>>> @alfa7691
>> >>>> GeoSolutions S.A.S.
>> >>>> Italy
>> e/o
>> Il loro
>> per le
>> messaggio
>> >>>> senza esserne il destinatario, Vi preghiamo cortesemente di darcene
>> notizia
>> >>>> via e-mail e di procedere alla distruzione del messaggio stesso,
>> divulgarlo
>> utilizzarlo per
>> >>>> finalità diverse, costituisce comportamento contrario ai principi
>> dettati
>> solely
>> >>>> for the attention and use of the named addressee(s) and may be
>> confidential
>> >>>> or proprietary in nature or covered by the provisions of privacy act
>> Protection
>> reproduction,
>> partial, is
>> sender does
>> changes
>> of
>> >>>> On 21 dicembre 2017 17:43, Francesco Bartoli <xbartolone at gmail.com>
>> >>>> wrote:
>> >>>>> Hi devs,
>> >>>>> as 2.7.x became quite stable we should be ready to move to releasing
>> >>>>> 2.8.0 as new stable version. Any feedback or concern?
>> >>>>> At the moment we don’t have a release manager but Alessio, Angelos
>> and
>> >>>>> me can volunteer. However it’s likely we need some guidance to the
>> overall
>> >>>>> procedure.
>> >>>>> Thanks and Merry Christmas to all of you
>> >>>>> Francesco
>> >>>>> _______________________________________________
>> >>>>> geonode-devel mailing list
>> >>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> >> Simone
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180212/25e36a92/attachment-0001.html>
More information about the geonode-devel mailing list
