[GeoNode-devel] Refactoring APIs from tastypie to Django Rest Framework
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Tue Feb 27 02:32:23 PST 2018
Well, let's say, for sure django-rest-framework is quite old and imho not
sufficient to have a correct and comprehensive REST API interface.
At least we would need also "drf-nested-routers" in order to be able to
correctly follow the REST protocol specs.
If in the meantime something better has been done, we should take it into
account.
I remember someone was suggesting to support OpenAPI specs through
https://github.com/limdauto/drf_openapi
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
2018-02-27 11:08 GMT+01:00 Ricardo Silva <ricardo.silva at geo-solutions.it>:
> Hi all
> I've recently become aware of apistar[1], a Web API framework which seems
> very promising.
> It is made by the same author of django-rest-framework and it seems like
> its evolution. I haven't used it for anything yet, so I won't vouch for its
> suitability/stability, but it seems really neat.
> I guess I'm just throwing options into the table ;)
> [1] - https://github.com/encode/apistar
> On 27-02-2018 09:51, Simone Dalmasso wrote:
> Matteo,
> this won't happen in geonode 2.x but rather in 3.0. No timing though :)
> 2018-02-27 10:30 GMT+01:00 Matteo De Stefano <matteo.destefano at nina.no>:
>> Dear geonode devs,
>> I was reading some time ago about the idea of replacing tastypie with
>> Django Rest Framework.
>> Is the proposal still alive? Anyone involved? Any idea about the timing?
>> Thanks,
>> Matteo
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
> geonode-devel mailing listgeonode-devel at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/geonode-devel
> Regards,
> Ricardo Silva
> Visit http://goo.gl/it488V for more information.
> Ricardo Silva
> Senior Software Engineer
> GeoSolutions S.A.S.
> Italy
> phone: +39 0584 962313 <0584%20962313>
> fax: +39 0584 1660272 <0584%20166%200272>
> http://www.geo-solutions.ithttp://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> Il loro utilizzo è consentito esclusivamente al destinatario del
> messaggio, per le finalità indicate nel messaggio stesso. Qualora
> riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
> cortesemente di darcene notizia via e-mail e di procedere alla
> distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
> Conservare il messaggio stesso, divulgarlo anche in parte,
> distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
> diverse, costituisce comportamento contrario ai principi dettati dal
> D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely
> for the attention and use of the named addressee(s) and may be
> confidential or proprietary in nature or covered by the provisions of
> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
> Data Protection Code). Any use not in accord with its purpose, any
> disclosure, reproduction, copying, distribution, or either
> dissemination, either whole or partial, is strictly forbidden except
> previous formal approval of the named addressee(s). If you are not the
> intended recipient, please contact immediately the sender by
> telephone, fax or e-mail and delete the information in this message
> that has been received in error. The sender does not give any warranty
> or accept liability as the content, accuracy or completeness of sent
> messages and accepts no responsibility for changes made after they
> were sent or for other risks which arise as a result of e-mail
> transmission, viruses, etc.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180227/5d52e559/attachment-0001.html>
More information about the geonode-devel
