[GeoNode-devel] Thumbnail generation issue for layer in non EPSG:4326 projection
Peter Marlow
Peter.Marlow at scisys.co.uk
Tue Jan 23 01:28:28 PST 2018
I've encountered an issue where I'm getting GeoNode to generate layer thumbnails as part of the updatelayers command. The problem I have is that when I configure the layer in GeoServer in order to get a valid thumbnail produced I then lose the ability to filter by extent for that layer in GeoNode. I believe this is because the layer in question is in a UK projection system and not EPSG:4326.
In order to get a valid thumbnail produced I have to set the following properties in GeoServer:
[cid:image003.png at 01D3942C.86941580]
However with these details set when I filter by extent in GeoNode using either the API or web interface the layer is no longer returned (example filter: http://<geonode_host>/layers/?limit=100&offset=0&extent=-6.899414062500001,48.07807894349862,4.658203125000001,56.145549500679074<http://%3cgeonode_host%3e/layers/?limit=100&offset=0&extent=-6.899414062500001,48.07807894349862,4.658203125000001,56.145549500679074>)
I think this is because the extent being provided via the filter is in EPSG:4326 (as this is what GeoNode supports) but the lat/lon Bounding Box in GeoServer is in EPSG:27700. If I change the Lat/Lon Bounding Box to be EPSG:4326 coordinates in GeoServer then I get a blank white image generated for the thumbnail and the extent filter starts working again.
I've tried all the combinations and SRS Handling, Native Bounding Box and Lat/Lon Bounding Box but I cannot get a valid thumbnail and the extent filter to work at the same time.
Is what I'm trying to do possible? Thanks in advance for any feedback!
Thanks,
Pete
SCISYS UK Limited. Registered in England and Wales No. 4373530.
Registered Office: Methuen Park, Chippenham, Wiltshire SN14 0GB, UK.
Before printing, please think about the environment.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180123/c745cc72/attachment-0001.html>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180123/c745cc72/attachment-0001.png>
More information about the geonode-devel
