[GeoNode-devel] ☞ GeoNode 2.8 vagrant base box & video walkthrough ☜
G. Allegri
giohappy at gmail.com
Mon Jul 2 13:58:36 PDT 2018
Well done Toni! Many thanks ;)
Giovanni
Il lun 2 lug 2018, 18:53 Toni Schönbuchner <toni.schoenbuchner at csgis.de> ha
scritto:
> Dear GeoNode Community,
> recently questions regarding howto install GeoNode from source as project
> [1] in dev or production
> environment popped up.
> VIRTUAL MACHINE
> To get you started or even for workshops and trainings find here a fully
> configured
> geonode 2.8 vagrant base box (Provider: virtualbox)
> > https://app.vagrantup.com/t-book/boxes/geonode_28_base/versions/1.0.0
> To use this instance make sure you´ve installed virtualbox and vagrant and
> create a file
> called Vagrantfile with following content:
> > https://gist.github.com/t-book/7ae41929b22ec84abe97d13f1c338cd6
> From the same directory in a terminal run
> > vagrant up && vagrant ssh
> This downloads the box, configures the network and starts a fresh ssh
> session.
> Vagrant provisions the network with address: 192.168.33.14.
> In case you need to change it:
> 1) edit the IP in your Vagrantfile
> 2) change the ip in ALLOWED_HOSTS see:
> /home/geonode/my_geonode/my_geonode/local_settings.py
> 3) correct the oauth2 part of geoserver as shown in following video.
> VIDEO
> I´ve screen recorded and commented the whole setup for you:
> > https://vimeo.com/278003647
> > *Get yourself a full bottle of coffee it’ll be lengthy and boring ;) *
> The Installation process is quite close to the installation guide with
> following differences:
> > the sudo user from the docs GEO is here called vagrant
> > the docs use virtualenvwrapper to setup the virtualenv, I´m directly
> using virtualenv
> > Errata: Around minute 7:30 my comment says pygdal 2.3.1.3 where it
> should say 2.2.1.3
> > I´ve recognized the first line of the terminal is cut off ;(
> But as I copy the commands from the documentation it should not be hard
> to follow.
> Last but not least, please be lenient if you find spelling mistakes in my
> comments
> ! multitasking !
> && please help to save our planet.
> https://en.wikipedia.org/wiki/Great_Pacific_garbage_patch
> Cheers,
> – Toni
> [1]
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html#
> https://www.virtualbox.org/
> https://www.vagrantup.com/
> CSGIS
> Kolonnadenstraße 1
> 04109 Leipzig
> Mobil +49/ (0) 176 6680 3198
> Tel +49/ (0) 341 24 04 738
> Fax +49/ (0) 341 24 04 73
> Web http://csgis.de
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
> ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180702/6230f479/attachment.html>
More information about the geonode-devel
