[GeoNode-devel] Problem with map zoom using mouse wheel
Alessio Fabiani alessio.fabiani at geo-solutions.it
Sat Jul 7 07:28:04 PDT 2018
Fixed by
https://github.com/GeoNode/geonode/commit/5761b91e3f460c5f7cf4f89a3f00df24c8db3cf2
Il giorno gio 28 giu 2018 alle ore 11:05 Anton Pesegov <
a.pesegov at innopolis.ru> ha scritto:
> Hi,
> I have a problem during geonode map creation/preview.
> If I try to zoom in with mouse wheel as much as possible - the map turns
> white and mouse wheel stops working for zooming.
> In order to zoom out I have to use zoom scrollbar on the left.
> Anyone encountered an issue like that before?
> Thanks,
> Anton
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180707/750c54f4/attachment.html>
More information about the geonode-devel mailing list
