[GeoNode-devel] Merged significative updates to geonode-project's Docker configurations
G. Allegri
giovanni.allegri at geo-solutions.it
Wed Jul 25 02:03:20 PDT 2018
Dear devs,
we've just merged to the master branch an upgrade to geonode-project, where
a deep rework has been done to it's Docker based configuration.
The docker-compose now runs the full stack of services by default
(Elasticsearch, RabbitMQ, Nginx + uWSGI).
We have fixed several issues to env vars, entrypoint.sh and tasks.py to
align it with the latest GeoNode's stack Docker images, and simplified them
a bit.
An updated README
<https://github.com/GeoNode/geonode-project/blob/master/README.rst> gives
you all the informations to run and testi it.
Feedbacks are welcome.
All the best,
Giovanni
Giovanni Allegri
GeoSolutions S.A.S.
Via di Montramito 3/A
<https://maps.google.com/?q=Via+di+Montramito+3/A%0D+55054+%C2%A0Massarosa&entry=gmail&source=g>
55054 Massarosa
(LU)
Italy
phone: +39 0584 962313 <+39%200584%20962313>
fax: +39 0584 1660272 <+39%200584%20166%200272>
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180725/6f8f5346/attachment.html>
More information about the geonode-devel
