[GeoNode-devel] GeoNode Loves Keycloak
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Jun 1 10:01:02 PDT 2018
Basically, with several updates to the Oauth2 libraries, GeoNode has become
OIDC 1.0 compliant and therefore it can be setup as a Identity Provider for
Keycloak.
GeoServer is connected directly to Keycloak, which acts as Authentication
Provider.
Keycloak, other than SSO and Identity Broker for several Authentication
Providers, is also able to translate Roles.
Among the advantages listed above, OIDC is more secure since it shares
signed or encrypted JWT.
However, we are still far from having something stable.
2018-06-01 18:52 GMT+02:00 francesco bartoli <xbartolone at gmail.com>:
> Pretty cool Alessio! How does it work?
> Il giorno ven 1 giu 2018 alle ore 18:19 Simone Dalmasso <
> simone.dalmasso at gmail.com> ha scritto:
>> :O !!
>> 2018-06-01 17:42 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-
>> solutions.it>:
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3
>>> <https://maps.google.com/?q=Via+di+Montramito+3&entry=gmail&source=g>/A
>>> - 55054  Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Simone
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180601/b6169730/attachment-0001.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180601/b6169730/attachment-0001.gif>
More information about the geonode-devel mailing list
