[GeoNode-devel] GeoNode Demo instance up and running
G. Allegri
giovanni.allegri at geo-solutions.it
Fri Jun 22 00:58:11 PDT 2018
Dear devs,
we're pleased to announce that an instance of the master GeoNode branch has
been published on our servers. It will serve as a demo of the latest
(development) version of GeoNode.
The instance is running on Docker. Every night the containers are restarted
from scratch. Data uploaded from users, maps and any other configuration
will be reset. Only users accounts are retained between restarts.
For the moment the GeoNode image is built manually every two weeks. We did
some tests with automatic pull / build but master code is too much
"volatile" to guarantee CI. This is a topic by itself that we suggest to
discuss in a dedicated thread.
We invite everybody to test it and give us feedbacks.
In a week since now we will publish the link on the demo landing page (
http://demo.geonode.org).
*Master GeoNode Demo URL: http://master.demo.geonode.org
<http://master.demo.geonode.org/>*
All the best,
Giovanni
Giovanni Allegri
GeoSolutions S.A.S.
Via di Montramito 3/A
<https://maps.google.com/?q=Via+di+Montramito+3/A%0D+55054+%C2%A0Massarosa&entry=gmail&source=g>
55054 Massarosa
(LU)
Italy
phone: +39 0584 962313 <+39%200584%20962313>
fax: +39 0584 1660272 <+39%200584%20166%200272>
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180622/352c7b54/attachment.html>
More information about the geonode-devel
