[GeoNode-devel] Geonode Unable to Sign in
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Wed May 9 14:58:15 PDT 2018
Hi Faneva,
I have tried all these commands:
python manage.py createsuperuser
python manage.py changepassword admin
And the response to both is:
File "manage.py", line 31, in <module>
execute_from_command_line(sys.argv)
File
"/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py",
line 354, in execute_from_command_line
utility.execute()
File
line 303, in execute
settings.INSTALLED_APPS
File "/usr/local/lib/python2.7/dist-packages/django/conf/__init__.py",
line 48, in __getattr__
self._setup(name)
line 44, in _setup
self._wrapped = Settings(settings_module)
line 92, in __init__
mod = importlib.import_module(self.SETTINGS_MODULE)
File "/usr/lib/python2.7/importlib/__init__.py", line 37, in import_module
__import__(name)
File "/home/geonode/my_geonode/my_geonode/settings.py", line 27, in
<module>
from geonode.settings import *
ImportError: No module named geonode.settings
I have no idea in what is going on. Any help on that would be very
appreciated.
Thank you very much for your help and time.
Kind regards
Julierme
2018-05-09 18:50 GMT-03:00 ANDRIAMIADANTSOA Fanevanjanahary <
fanevanjanahary at gmail.com>:
> Hello Julierme,
> Did you already try to change the admin's password?
> This is commande to change this
> Best regards
> Faneva
> On Thu, May 10, 2018, 00:21 Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> wrote:
>> Hi all,
>> I finally got the end of the geonode installation as in here:
>> http://docs.geonode.org/en/master/tutorials/install_and_
>> admin/geonode_install/all_together.html
>> But now, I am unable to sign in. The tutorial says: Login with admin
>> username and password you just set. But I do not remember setting an
>> username and a password during the installation. I tried the default one:
>> username:admin and password: admin, but I got no success.
>> Any help on that please?
>> Thank you for your time in advance.
>> Best regards
>> Julierme
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180509/fbf2d902/attachment.html>
More information about the geonode-devel
