[GeoNode-devel] Geonode Unable to Sign in (Julierme Pinheiro)
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Thu May 10 15:46:16 PDT 2018
Hey Toni and Paolo,
Thank you very much for your reply and patience. Here are the responses to
your highlights:
*$ chown www-data:www-data
/home/geo/Envs/geonode/lib/python2.7/dist-packages/geonode/development.db*
ls -l development.db
-rw-rw-rw- 1 www-data www-data 424960 Mai 9 17:25 development.db
*python manage.py runserver*
Performing system checks...
System check identified no issues (0 silenced).
Unhandled exception in thread started by <function wrapper at
0x7f004b8f62a8>
File "/usr/local/lib/python2.7/dist-packages/django/utils/autoreload.py",
line 229, in wrapper
fn(*args, **kwargs)
File
"/usr/local/lib/python2.7/dist-packages/django/core/management/commands/runserver.py",
line 116, in inner_run
self.check_migrations()
File
line 168, in check_migrations
executor = MigrationExecutor(connections[DEFAULT_DB_ALIAS])
File
"/usr/local/lib/python2.7/dist-packages/django/db/migrations/executor.py",
line 19, in __init__
self.loader = MigrationLoader(self.connection)
File
"/usr/local/lib/python2.7/dist-packages/django/db/migrations/loader.py",
line 47, in __init__
self.build_graph()
File
line 191, in build_graph
self.applied_migrations = recorder.applied_migrations()
File
"/usr/local/lib/python2.7/dist-packages/django/db/migrations/recorder.py",
line 59, in applied_migrations
self.ensure_schema()
File
line 49, in ensure_schema
if self.Migration._meta.db_table in
self.connection.introspection.table_names(self.connection.cursor()):
File
"/usr/local/lib/python2.7/dist-packages/django/db/backends/base/base.py",
line 162, in cursor
cursor = self.make_debug_cursor(self._cursor())
File
line 135, in _cursor
self.ensure_connection()
File
line 130, in ensure_connection
self.connect()
File "/usr/local/lib/python2.7/dist-packages/django/db/utils.py", line
98, in __exit__
six.reraise(dj_exc_type, dj_exc_value, traceback)
File
self.connect()
File
line 119, in connect
self.connection = self.get_new_connection(conn_params)
File
"/usr/local/lib/python2.7/dist-packages/django/db/backends/sqlite3/base.py",
line 204, in get_new_connection
conn = Database.connect(**conn_params)
django.db.utils.OperationalError: unable to open database file
*Check if your database definition points to the correct file*
settings.DATABASES
{'default': {'ENGINE': 'django.db.backends.sqlite3', 'ATOMIC_REQUESTS':
False, 'CONN_MAX_AGE': 600, 'HOST': '', 'USER': '', 'PASSWORD': '',
'OPTIONS': {}, 'AUTOCOMMIT': True, 'NAME':
'/usr/local/lib/python2.7/dist-packages/geonode/development.db',
'TIME_ZONE': 'UTC', 'PORT': '', 'TEST': {'COLLATION': None, 'CHARSET':
None, 'NAME': None, 'MIRROR': None}}}
*See f.e where the path is
build: https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L104
<https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L104>*
Though I followed the guide in here
<http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
to download the geonode-project *$ django-admin.py startproject --template=
https://github.com/GeoNode/geonode-project/archive/2.8.0.zip -e
py,rst,json,yml my_geonode*, I realized that the settings.py in
/home/geonode/my_geonode/my_geonode/settings.py is totally different than
the one available in here
*https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L104
*Therefore, I do not have lines 101-104 in my settings.py*
Said that, should I change/ replace my settings.py?
*I appreciated your time and help.*
*Kind regards*
*Julierme*
2018-05-10 18:00 GMT-03:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de>:
> Hey Julierme,
> +1 to Paolo
> give
> $ chown www-data:www-data /usr/local/lib/python2.7/dist-packages/
> a try if you try to run geonode with $ python manage.py runserver I think
> the process belongs to the current
> user ($ whoami).
> Another thing to test is, can you check if your database definition points
> to the correct file:
> See f.e where the path is build: https://github.com/
> cheers,
> toni
> CSGIS
> Kolonnadenstraße 1
> <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+1+04109+Leipzig&entry=gmail&source=g>
> 04109 Leipzig
> Mobil +49/ (0) 176 6680 3198
> Tel +49/ (0) 341 24 04 738
> Fax +49/ (0) 341 24 04 73
> Web http://csgis.de
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
> ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> Am 10.05.2018 um 22:36 schrieb Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com>:
> Hi Toni Schonbuchner,
> Thank you for your reply. Discussing here with my IT colleague, we
> realized that DB could be the one in:
> We changed the development.db permission by
> chmod a+w /usr/local/lib/python2.7/dist-packages/geonode/development.db
> I got very excited about python manage.py createsuperuser because I was
> asked for the:
> username:
> Email address:
> Password:
> Password (again):
> But at the end, look the finally response:
> geo at geo:/home/geonode/my_geonode$ python manage.py createsuperuser
> Username: juliermeadmin
> Email address: julierme.pinheiro at sipam.gov.br
> Password:
> Password (again):
> File "manage.py", line 31, in <module>
> execute_from_command_line(sys.argv)
> File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py",
> line 354, in execute_from_command_line
> utility.execute()
> line 346, in execute
> self.fetch_command(subcommand).run_from_argv(self.argv)
> File "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py",
> line 394, in run_from_argv
> self.execute(*args, **cmd_options)
> File "/usr/local/lib/python2.7/dist-packages/django/contrib/
> auth/management/commands/createsuperuser.py", line 50, in execute
> return super(Command, self).execute(*args, **options)
> line 445, in execute
> output = self.handle(*args, **options)
> auth/management/commands/createsuperuser.py", line 149, in handle
> self.UserModel._default_manager.db_manager(database).
> create_superuser(**user_data)
> File "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/models.py",
> line 191, in create_superuser
> **extra_fields)
> line 182, in _create_user
> user.save(using=self._db)
> File "/usr/local/lib/python2.7/dist-packages/geonode/people/models.py",
> line 169, in save
> super(Profile, self).save(*args, **kwargs)
> File "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py",
> line 734, in save
> force_update=force_update, update_fields=update_fields)
> line 762, in save_base
> updated = self._save_table(raw, cls, force_insert, force_update,
> using, update_fields)
> line 846, in _save_table
> result = self._do_insert(cls._base_manager, using, fields, update_pk,
> raw)
> line 885, in _do_insert
> using=using, raw=raw)
> File "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py",
> line 127, in manager_method
> return getattr(self.get_queryset(), name)(*args, **kwargs)
> File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py",
> line 920, in _insert
> return query.get_compiler(using=using).execute_sql(return_id)
> File "/usr/local/lib/python2.7/dist-packages/django/db/models/sql/compiler.py",
> line 974, in execute_sql
> cursor.execute(sql, params)
> File "/usr/local/lib/python2.7/dist-packages/django/db/backends/utils.py",
> line 79, in execute
> return super(CursorDebugWrapper, self).execute(sql, params)
> line 64, in execute
> return self.cursor.execute(sql, params)
> 98, in __exit__
> line 64, in execute
> File "/usr/local/lib/python2.7/dist-packages/django/db/backends/sqlite3/base.py",
> line 318, in execute
> return Database.Cursor.execute(self, query, params)
> Also, looking at /usr/local/lib/python2.7/dist-packages/django/db/backends
> I found the following directories: sqlite3 mysql oracle
> postgresql_psycopg2 base dummy
> and the following files:__init__.py __init__.pyc signals.py
> signals.pyc util.py util.pyc utils.py utils.pyc
> Tweaking through sqlite3 directory, I got the following:
> -rw-r--r-- 1 root staff 17462 Mai 8 13:39 base.py
> -rw-r--r-- 1 root staff 17022 Mai 8 13:39 base.pyc
> -rw-r--r-- 1 root staff 305 Mai 8 13:39 client.py
> -rw-r--r-- 1 root staff 814 Mai 8 13:39 client.pyc
> -rw-r--r-- 1 root staff 3297 Mai 8 13:39 creation.py
> -rw-r--r-- 1 root staff 3603 Mai 8 13:39 creation.pyc
> -rw-r--r-- 1 root staff 2631 Mai 8 13:39 features.py
> -rw-r--r-- 1 root staff 3432 Mai 8 13:39 features.pyc
> -rw-r--r-- 1 root staff 0 Mai 8 13:39 __init__.py
> -rw-r--r-- 1 root staff 156 Mai 8 13:39 __init__.pyc
> -rw-r--r-- 1 root staff 11019 Mai 8 13:39 introspection.py
> -rw-r--r-- 1 root staff 9354 Mai 8 13:39 introspection.pyc
> -rw-r--r-- 1 root staff 8655 Mai 8 13:39 operations.py
> -rw-r--r-- 1 root staff 10228 Mai 8 13:39 operations.pyc
> -rw-r--r-- 1 root staff 11377 Mai 8 13:39 schema.py
> -rw-r--r-- 1 root staff 8944 Mai 8 13:39 schema.pyc
> -rw-r--r-- 1 root staff 389 Mai 8 13:39 utils.py
> -rw-r--r-- 1 root staff 710 Mai 8 13:39 utils.pyc
> Note: At the beginning of geonode installation I set Source
> /usr/local/bin/virtualenvwrapper.sh and the tutorial sets
> source $HOME/.local/bin/virtualenvwrapper.sh
> I wonder if this could cause any issue.
> I appreciated your time.
> Kind regards
> Julierme
> 2018-05-10 14:57 GMT-03:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de>
>> Hey ho Julierme,
>> this is the interesting part:
>> 140163086272256] OperationalError: attempt to write a readonly database
>> yes this is most likely caused by missing permissions of the user who
>> runs the process.
>> can you please check your sqlite database file it shoud name something
>> like db.sqlite3
>> $ ls -l db.sqlite3
>> if you do not know where to find it something have a look in your
>> settings.py or local.settings
>> or do $ find / -name '*sqlite3‘ -type f 2>/dev/null
>> Cheers,
>> Toni
>> CSGIS
>> Kolonnadenstraße 1
>> 04109 Leipzig
>> Web http://csgis.de
>> Am 10.05.2018 um 19:33 schrieb geonode-devel-request at lists.osgeo.org:
>> 1. Re: [GeoNode-users] Geonode Unable to Sign in (Julierme Pinheiro)
>> Message: 1
>> Date: Thu, 10 May 2018 14:33:06 -0300
>> From: Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>
>> To: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
>> Cc: ANDRIAMIADANTSOA Fanevanjanahary <fanevanjanahary at gmail.com>,
>> geonode-users <geonode-users at lists.osgeo.org>, geonode-devel
>> <geonode-devel at lists.osgeo.org>
>> Subject: Re: [GeoNode-devel] [GeoNode-users] Geonode Unable to Sign
>> in
>> Message-ID:
>> <CAKTKyJLa14UN6ggximM4dVJ4T9OhwhUQbL7ivsrZMHV8FFC5kQ at mail.gmail.com>
>> Content-Type: text/plain; charset="utf-8"
>> Find bellow the error.log response when I try to sign in and refresh
>> geonode site. Do you think the problem could be related to user geo
>> permissions?
>> [Thu May 10 14:20:59.195452 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] Internal Server Error: /account/login/
>> [Thu May 10 14:20:59.200485 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] Traceback (most recent call last):
>> [Thu May 10 14:20:59.200510 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] File
>> "/home/geo/Envs/geonode/lib/python2.7/site-packages/django/
>> core/handlers/base.py",
>> line 132, in get_response
>> [Thu May 10 14:20:59.200518 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] response = wrapped_callback(request, *callback_args,
>> **callback_kwargs)
>> [Thu May 10 14:20:59.200524 2018] [wsgi:error] [pid 4130:tid
>> views/generic/base.py",
>> line 71, in view
>> [Thu May 10 14:20:59.200531 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] return self.dispatch(request, *args, **kwargs)
>> [Thu May 10 14:20:59.200538 2018] [wsgi:error] [pid 4130:tid
>> utils/decorators.py",
>> line 34, in _wrapper
>> [Thu May 10 14:20:59.200544 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] return bound_func(*args, **kwargs)
>> [Thu May 10 14:20:59.200551 2018] [wsgi:error] [pid 4130:tid
>> views/decorators/debug.py",
>> line 76, in sensitive_post_parameters_wrapper
>> [Thu May 10 14:20:59.200558 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] return view(request, *args, **kwargs)
>> [Thu May 10 14:20:59.200564 2018] [wsgi:error] [pid 4130:tid
>> line 30, in bound_func
>> [Thu May 10 14:20:59.200571 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] return func.__get__(self, type(self))(*args2,
>> **kwargs2)
>> [Thu May 10 14:20:59.200577 2018] [wsgi:error] [pid 4130:tid
>> "/home/geo/Envs/geonode/lib/python2.7/site-packages/allauth/
>> account/views.py",
>> line 133, in dispatch
>> [Thu May 10 14:20:59.200584 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] return super(LoginView, self).dispatch(request,
>> *args,
>> **kwargs)
>> [Thu May 10 14:20:59.200590 2018] [wsgi:error] [pid 4130:tid
>> account/views.py",
>> line 79, in dispatch
>> [Thu May 10 14:20:59.200597 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] **kwargs)
>> [Thu May 10 14:20:59.200603 2018] [wsgi:error] [pid 4130:tid
>> line 89, in dispatch
>> [Thu May 10 14:20:59.200610 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] return handler(request, *args, **kwargs)
>> [Thu May 10 14:20:59.200616 2018] [wsgi:error] [pid 4130:tid
>> account/views.py",
>> line 101, in post
>> [Thu May 10 14:20:59.200623 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] if form.is_valid():
>> [Thu May 10 14:20:59.200629 2018] [wsgi:error] [pid 4130:tid
>> forms/forms.py",
>> line 184, in is_valid
>> [Thu May 10 14:20:59.200635 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] return self.is_bound and not self.errors
>> [Thu May 10 14:20:59.200641 2018] [wsgi:error] [pid 4130:tid
>> forms/forms.py",
>> line 176, in errors
>> [Thu May 10 14:20:59.200648 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] self.full_clean()
>> [Thu May 10 14:20:59.200670 2018] [wsgi:error] [pid 4130:tid
>> forms/forms.py",
>> line 393, in full_clean
>> [Thu May 10 14:20:59.200677 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] self._clean_form()
>> [Thu May 10 14:20:59.200683 2018] [wsgi:error] [pid 4130:tid
>> forms/forms.py",
>> line 417, in _clean_form
>> [Thu May 10 14:20:59.200689 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] cleaned_data = self.clean()
>> [Thu May 10 14:20:59.200695 2018] [wsgi:error] [pid 4130:tid
>> account/forms.py",
>> line 159, in clean
>> [Thu May 10 14:20:59.200701 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] **credentials)
>> [Thu May 10 14:20:59.200707 2018] [wsgi:error] [pid 4130:tid
>> account/adapter.py",
>> line 483, in authenticate
>> [Thu May 10 14:20:59.200713 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] user = authenticate(request=request, **credentials)
>> [Thu May 10 14:20:59.200719 2018] [wsgi:error] [pid 4130:tid
>> "/home/geo/Envs/geonode/lib/python2.7/site-packages/allauth/compat.py",
>> line 54, in authenticate
>> [Thu May 10 14:20:59.200725 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] return authenticate(**credentials)
>> [Thu May 10 14:20:59.200731 2018] [wsgi:error] [pid 4130:tid
>> contrib/auth/__init__.py",
>> line 74, in authenticate
>> [Thu May 10 14:20:59.200756 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] user = backend.authenticate(**credentials)
>> [Thu May 10 14:20:59.200764 2018] [wsgi:error] [pid 4130:tid
>> contrib/auth/backends.py",
>> line 18, in authenticate
>> [Thu May 10 14:20:59.200770 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] if user.check_password(password):
>> [Thu May 10 14:20:59.200776 2018] [wsgi:error] [pid 4130:tid
>> line 241, in check_password
>> [Thu May 10 14:20:59.200782 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] return check_password(raw_password, self.password,
>> setter)
>> [Thu May 10 14:20:59.200788 2018] [wsgi:error] [pid 4130:tid
>> contrib/auth/hashers.py",
>> line 62, in check_password
>> [Thu May 10 14:20:59.200794 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] setter(password)
>> [Thu May 10 14:20:59.200800 2018] [wsgi:error] [pid 4130:tid
>> line 240, in setter
>> [Thu May 10 14:20:59.200807 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] self.save(update_fields=["password"])
>> [Thu May 10 14:20:59.200813 2018] [wsgi:error] [pid 4130:tid
>> "/home/geo/Envs/geonode/lib/python2.7/site-packages/geonode/
>> people/models.py",
>> line 169, in save
>> [Thu May 10 14:20:59.200819 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] super(Profile, self).save(*args, **kwargs)
>> [Thu May 10 14:20:59.200825 2018] [wsgi:error] [pid 4130:tid
>> db/models/base.py",
>> line 734, in save
>> [Thu May 10 14:20:59.200831 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] force_update=force_update,
>> [Thu May 10 14:20:59.200837 2018] [wsgi:error] [pid 4130:tid
>> db/models/base.py",
>> [Thu May 10 14:20:59.200843 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] updated = self._save_table(raw, cls, force_insert,
>> force_update, using, update_fields)
>> [Thu May 10 14:20:59.200855 2018] [wsgi:error] [pid 4130:tid
>> db/models/base.py",
>> line 827, in _save_table
>> [Thu May 10 14:20:59.200861 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] forced_update)
>> [Thu May 10 14:20:59.200867 2018] [wsgi:error] [pid 4130:tid
>> db/models/base.py",
>> line 877, in _do_update
>> [Thu May 10 14:20:59.200874 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] return filtered._update(values) > 0
>> [Thu May 10 14:20:59.200880 2018] [wsgi:error] [pid 4130:tid
>> line 580, in _update
>> [Thu May 10 14:20:59.200886 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] return query.get_compiler(self.db).ex
>> ecute_sql(CURSOR)
>> [Thu May 10 14:20:59.200892 2018] [wsgi:error] [pid 4130:tid
>> line 1062, in execute_sql
>> [Thu May 10 14:20:59.200898 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] cursor = super(SQLUpdateCompiler,
>> self).execute_sql(result_type)
>> [Thu May 10 14:20:59.200904 2018] [wsgi:error] [pid 4130:tid
>> line 840, in execute_sql
>> [Thu May 10 14:20:59.200910 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] cursor.execute(sql, params)
>> [Thu May 10 14:20:59.200916 2018] [wsgi:error] [pid 4130:tid
>> line 79, in execute
>> [Thu May 10 14:20:59.200923 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] return super(CursorDebugWrapper, self).execute(sql,
>> params)
>> [Thu May 10 14:20:59.200928 2018] [wsgi:error] [pid 4130:tid
>> line 64, in execute
>> [Thu May 10 14:20:59.200935 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] return self.cursor.execute(sql, params)
>> [Thu May 10 14:20:59.200941 2018] [wsgi:error] [pid 4130:tid
>> "/home/geo/Envs/geonode/lib/python2.7/site-packages/django/db/utils.py",
>> line 98, in __exit__
>> [Thu May 10 14:20:59.200947 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] six.reraise(dj_exc_type, dj_exc_value, traceback)
>> [Thu May 10 14:20:59.200953 2018] [wsgi:error] [pid 4130:tid
>> line 64, in execute
>> [Thu May 10 14:20:59.200959 2018] [wsgi:error] [pid 4130:tid
>> [Thu May 10 14:20:59.200965 2018] [wsgi:error] [pid 4130:tid
>> [Thu May 10 14:20:59.200971 2018] [wsgi:error] [pid 4130:tid
>> 140163086272256] return Database.Cursor.execute(self, query, params)
>> [Thu May 10 14:20:59.200977 2018] [wsgi:error] [pid 4130:tid
>> Kind regards
>> Julierme
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180510/b57c6a65/attachment-0001.html>
More information about the geonode-devel
