[GeoNode-devel] Release schedule proposal for GeoNode 2.8.1 and 2.10.0 versions
Dave Kennewell
davekennewell at gmail.com
Wed May 16 05:34:49 PDT 2018
Can I ask - are there new features from 2.8.0 -> 2.8.1 or is it bugfixes?
If there are new features, particularly new database migrations, can we
maintain a way to remain on 2.8.0 using the apt-get install? If it's a
problem, I can create an EC2 image of the current 2.8.0 and install from
that, but I suspect other users might not have the same luxury?
And out of curiosity, is there a change log for 2.8 -> 2.10?
Thanks Alessio!
On 16 May 2018 at 16:22, Alessio Fabiani-2 [via OSGeo.org] <
ml+s1560n5364550h65 at n6.nabble.com> wrote:
> Dear dev and users lists,
> I would like to propose a time schedule for the GeoNode releases:
> - 2.10.0; based on Django 1.11.11
> - 2.8.1; based on Django 1.8.19
> Since, in terms of issues, they look stable enough to be published, I
> would like to release them in a week or so.
> Unless there are complains about that, I would call for an hardening week
> starting from today and then pushing out the releases on Thursday (24) or
> Friday (25) next week.
> In the meantime would be good to spot all potential several issues which
> might block the release process.
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
> 55054 Massarosa
> (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> geonode-devel mailing list
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5364550&i=0>
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Release-schedule-
> proposal-for-GeoNode-2-8-1-and-2-10-0-versions-tp5364550.html
> To unsubscribe from GeoNode, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5185390&code=ZGF2ZWtlbm5ld2VsbEBnbWFpbC5jb218NTE4NTM5MHwtOTI1NjEyMTk0>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180516/4d35c0d6/attachment-0001.html>
More information about the geonode-devel
