[GeoNode-devel] Geonode Thumbnails Error
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Mon May 28 09:11:44 PDT 2018
Dear Toni Schonbuchner,
Thank you very much for your reply and highlights. While tweaking through
local_settings.py [1] and settings.py [1][2], trying to find any port 8000
set to geoserver URL, I got some questions:
1 - regarding local_settings.py
1.1 OGC_SERVER --> LOG_FILE
OGC_SERVER : {
          ' default' : {
            'LOG_FILE' : '%s/geoserver/data/logs/geoserver.log' % os.path.
abspath(os.path.join(PROJECT_ROOT, os.pardir)),
PROJECT_ROOT is the only variable in the file, shouldn't it be changed to
LOCAL_ROOT? PROJECT_ROOT was set as LOCAL_ROOT at the top of the file.
1.2 LOCAL_GEOSERVER
Should I keep the condition (if 'geonode.geoserver' in INSTALLED_APPS:)
before LOCAL_GEOSERVER configuration?
2 - regarding settings.py
2.1 -  LOGGING --> loggers
The configuration in [1] differs from configuration in [2]. Config [2] in
settings.py gets
"{{ project_name }}": {
        "handlers": ["console"], "level": "DEBUG", },
"my_geonode": {
project_name = my_geonde
but config [1] in local_settings does not. I guess this shouldn't be a
problem because settings.py inherits local_settings.py.
LOGGING = {
     }, 'loggers':
Lastly, my settings.py is different than settings.py in [3]. According to
[4], my settings.py [5] is downloaded from here [6].
For instance, USE_GEOSERVER is set in Line 1249 [7], but it is not set in
[5], at least the configuration is different. Furthermore, some libraries
are imported in [7], but  they aren't in [5].
Is it settings.py in [5] out of date?
Yet, I am tweaking through geonode-updateip script and I will try to make
some changes in order to have it working for GeNode installed from source.
As soon as get it, I will share it here.
I appreciated your time and help.
Kind regards and greetings to Germany.
Julierme
[1] http://docs.geonode.org/en/master/tutorials/install_and_
admin/geonode_install/setup_configure_httpd.html
[2]
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/create_geonode_db.html
[3] https://github.com/GeoNode/geonode/blob/2.8.0/geonode/settings.py#L650
[4]
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html
[5]
https://github.com/GeoNode/geonode-project/blob/2.8.0/project_name/settings.py
[6] http://github.com/Geonode/geonode-project/archive/2.8.0.zip
[7] https://github.com/GeoNode/geonode/blob/2.8.0/geonode/settings.py#L1249
2018-05-28 11:20 GMT-03:00 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com>:
> Thank you very much for your reply. While tweaking through settings.py and
> local_settings.py [1], trying to find any port 8000 set to geoserver URL, I
> got some questions:
> OGC_SERVER : {
>           ' default' : {
> 2018-05-25 17:02 GMT-03:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de>
>> Dear Julierme,
>> I think  using grep does not really help to get insights.
>> Why not look at the code? The geoserver URL is composed
>> in settings.py [1]. I think here you will find your 8000.
>> Next I think the best way to see what´s going on is to have
>> a look at the helpers.py [2]. Here you should find the code which
>> is responsible for creating thumbnails and here [3] the signal
>> which you see in stdout logging. If there is some time I will
>> do a dev installation and will test it as well.
>> Further you´ve asked if there is something like geonode-updateip
>> for an installation by source? Not that I know of but yes it would be
>> helpful.
>> But it should not be to hard to write a little script which does the job.
>> Have a look what geonode-updateip actually does [4] it programatically
>> changes
>> the parts which the documentation [5] explains regarding auth.
>> I hope this helps a bit.
>> Best greetings to Brasilia!
>> Toni
>> [1] https://github.com/GeoNode/geonode/blob/2.8.0/geonode/
>> settings.py#L650
>> [2] https://github.com/GeoNode/geonode/blob/master/geonode/
>> geoserver/helpers.py#L1730
>> [3] https://github.com/GeoNode/geonode/blob/df12893ced001973
>> bd748f86d08fa6ae4c10dde9/geonode/geoserver/signals.py#L497
>> [4] https://github.com/GeoNode/geonode/blob/df12893ced001973
>> bd748f86d08fa6ae4c10dde9/package/support/geonode.updateip#L126
>> [5] http://docs.geonode.org/en/master/tutorials/install_and_
>> admin/geonode_install/install_geoserver_application.html#
>> geonode-authentication-integration
>> CSGIS
>> Kolonnadenstraße 1
>> <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+1+04109+Leipzig&entry=gmail&source=g>
>> 04109 Leipzig
>> Mobil +49/ (0) 176 6680 3198
>> Tel  +49/ (0) 341 24 04 738
>> Fax  +49/ (0) 341 24 04 73
>> Web http://csgis.de
>> Hinweis gemäß § 33 BDSG
>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>> ausschließlich für den
>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>> diese E-Mail versehentlich
>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>> löschen Sie diese Nachricht
>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>> Vervielfältigung, Veränderung,
>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>> From: Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>
>> To: Toni Schönbuchner <toni.schoenbuchner at csgis.de>, geonode-users
>> <geonode-users at lists.osgeo.org>,  geonode-devel
>> <geonode-devel at lists.osgeo.org>
>> Subject: Re: [GeoNode-devel] Geonode Thumbnails Error
>> Message-ID:
>> <CAKTKyJJmjL0QBMuZvw0DsBzeCu2yW5vKCj5dMjDN=cddheWJ+g at mail.gmail.com>
>> Content-Type: text/plain; charset="utf-8"
>> Here are some more paths that port 8000 could be coming from:
>> geo/Envs/geonode/lib/python2.7/site-packages/pycsw/wsgi.py:#
>> http://localhost:8000/
>> geo/Envs/geonode/lib/python2.7/site-packages/djangorestframe
>> work-3.8.2.dist-info/DESCRIPTION.rst:You
>> can now open the API in your browser at ``http://127.0.0.1:8000/``
>> <http://127.0.0.1:8000/>,
>> $ curl -H 'Accept: application/json; indent=4' -u admin:password
>> http://127.0.0.1:8000/users/
>> "url": "http://127.0.0.1:8000/users/1/",
>> $ curl -X POST -d username=new -d email=new at example.com -d is_staff=false
>> "url": "http://127.0.0.1:8000/users/2/",
>> work-3.8.2.dist-info/METADATA:You
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180528/6b9614fd/attachment-0001.html>
More information about the geonode-devel mailing list
