[GeoNode-devel] 2.8.0 - ACCOUNT_APPROVAL_REQUIRED setting appears not to have effect
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed May 30 08:12:38 PDT 2018
in order to receive emails you need to configure the email backend too,
which is disabled by default
2018-05-30 16:53 GMT+02:00 Dave Kennewell <davekennewell at gmail.com>:
> Hi all,
> I'm using 2.8.0.
> The ACCOUNT_APPROVAL_REQUIRED setting appears to work in that it stops a
> new user's account being immediately active, but geonode does not appear to
> be emailing the admins to let them know, resulting in some pretty lonely
> users not being onboarded.
> Looking through the code, I was expecting a notification to be sent to the
> admins from here:
> https://github.com/GeoNode/geonode/blob/d41328bfddbe3d5820338f455c5767
> b2067d759d/geonode/views.py#L151
> Am I missing something here, or does this need a fix?
> Thanks
> Dave
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180530/0b3b4e3c/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180530/0b3b4e3c/attachment-0001.png>
More information about the geonode-devel
