[GeoNode-devel] Geocode layers inaccessible by anonymous and broken keywords
Francesco Bartoli xbartolone at gmail.com
Mon Sep 17 07:50:10 PDT 2018
That release has not been completed so it is expected to be facing with potential errors. Can you please file a ticket so we can keep track of that?
In the meantime if you want to have your instance up and running I’d suggest to use a different deployment method within the same machine. For example you can install docker and use docker-compose to bootstrap your instance.
Thanks,
Francesco
Il 17 set 2018, 16:00 +0200, Lian Feng (lfeng) <lfeng at memphis.edu>, ha scritto:
> Dear all,
> Can anyone provide insights to this problem? Currently layers and maps are unavailable to anyone other than admin account?
> Tried to set permissions for individual layers in geonode too, but nothing has changed.
> Thanks very much!
> Lydia Lian Feng
> Senior Research Software Developer  | CAESER
> Center for Applied Earth Science and Engineering Research
> The University of Memphis
> Wilder Tower Suite 900
> 3675 Alumni Drive
> Memphis, TN 38152
> 901.678.5110 | http://strengthencommunities.com/
> From: "Lian Feng (lfeng)" <lfeng at memphis.edu>
> Date: Monday, September 10, 2018 at 8:32 AM
> To: "geonode-devel at lists.osgeo.org" <geonode-devel at lists.osgeo.org>
> Subject: Geocode layers inaccessible by anonymous and broken keywords
> Dear all,
> I installed geonode 2.8 on a 16.04 Ubuntu virtualbox through apt-get. The endpoint is http://geoportal-test.memphis.edu/ .
> I have a few details questions.
> 1. KEYWORDS navbar on the layer page fail to be synchronized. Keywords for layers in geoserver are first updated and then ` python manage.py updatelayers --settings=my_geonode.local_settings ` runs successfully. Like in the attached screenshot, `,` is found in 5 layers but all these layers don’t have ‘,’ in keywords. It used to have it but I manually deleted it in every layer in Geoserver.
> 2. On geoserver Security>GeoFence Data Rules, I set ROLE_ANONYMOUS allow access to all layers under all workspace. But layers are not accessible (downloadable and WMS thumbnails) for anonymous. But if I login as admin, layers are accessible.
> Lydia Lian Feng
> 3675 Alumni Drive
> Memphis, TN 38152
> geonode-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180917/1cd7a9af/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180917/1cd7a9af/attachment-0006.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180917/1cd7a9af/attachment-0007.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180917/1cd7a9af/attachment-0008.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180917/1cd7a9af/attachment-0009.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180917/1cd7a9af/attachment-0010.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180917/1cd7a9af/attachment-0011.jpg>
More information about the geonode-devel mailing list
