[GeoNode-devel] [Docker][Question] Is necessary to add Public IP in Mapfish Printing?
João Gaspar
joao.f.r.gaspar at gmail.com
Mon Apr 1 07:16:08 PDT 2019
Hi, devs
I've got a question regarding Docker installation about printing in
Geonode. Is necessary to change the
/usr/share/geoserver/data/printing/config.yaml (as explained in the
documentation) to add my IPADDRESS? I'm asking this because I test the
printing module in demo mapfish printing module and is working on geoserver
side but in geonode when I select a map to print, geonode open print
preview and have two behaviour:
1º start to shake the dialog when I select some of the templates.
2.º when I select one to print, appears loading PDF e do nothing.
This are my local specifications
Version: Geoserver - 2.14-SNAPSHOT/ Git revision
679e2035cf8c0f6c717e0f78f1dfe4237dfcdc33
Geonode - 2.10rc4
Thank you for your time.
Best Regards,
João Gaspar
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190401/19437407/attachment.html>
More information about the geonode-devel
