[GeoNode-devel] Switching to MapStore in GeoNode
Paolo Corti
pcorti at gmail.com
Thu Apr 4 06:49:42 PDT 2019
Thanks a lot, it looks really powerful and impressive.
Do I understand correctly that there isn't a UI widget for editing styles
(such as the one in GeoExplorer) but you can make changes only via the
SLD/CSS editor? That could limit the utility for GeoNode instances where
general public isn't used to tools which are not UI based.
cheers
Paolo
On Thu, Apr 4, 2019 at 3:37 PM Simone Giannecchini <
simone.giannecchini at geo-solutions.it> wrote:
> These webinars registrations (mind you, they are huge) can help:
> https://www.dropbox.com/s/q1rdwuzc4wu0y0f/Map%20Styling%20IGAD%201.mp4?dl=0
> https://www.dropbox.com/s/3yrmb5tdrilt9f9/Map%20Styling%20IGAD%202.mp4?dl=0
> Regards,
> Simone Giannecchini
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services for more information.
> Ing. Simone Giannecchini
> @simogeo
> Founder/Director
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 333 8128928
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> On Thu, Apr 4, 2019 at 3:29 PM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Hi Paolo,
>> cool. Currently, it is possible either by clicking the "Styles > Edit"
>> from the "Editing Tools" section or by creating/editing a new map
>> containing that Layer.
>> [image: image.png]
>> Il giorno gio 4 apr 2019 alle ore 15:25 Paolo Corti <pcorti at gmail.com>
>> ha scritto:
>>> Hi Alessio,
>>> I gave a first look at this today, and it is really great and a
>>> compelling alternative to the old fashioned GeoExplorer :)
>>> Could you explain how it is possible to edit a style, as I didn't find
>>> the way? Thanks a lot
>>> Paolo
>>> On Tue, Apr 2, 2019 at 12:47 PM Paolo Pasquali <paolo.pasquali at gmail.com>
>>> wrote:
>>>> Ciao Alessio,
>>>> I've probably messed up my docker installation. I've solved rebuilding
>>>> and adding the mapstore packages in the requirements.
>>>> I'm still not sure why it didn't work by pip installing them after the
>>>> initial setup.
>>>> Anyway, thank you Alessio for your support.
>>>> I'll get back to you for more info about MapStore for sure... 😀
>>>> Ciao,
>>>> P.
>>>> On Mon, Apr 1, 2019 at 6:39 PM Alessio Fabiani <
>>>>> P.S.: it works only with GeoNode 2.10+
>>>>> Il giorno lun 1 apr 2019 alle ore 18:36 Alessio Fabiani <
>>>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>>>>> That is quite strange. Have you been able to get a stacktrace
>>>>>> somehow? Maybe try to comment the "GEONODE_CLIENT_HOOKSET" in order to
>>>>>> check that the exception does not occur or it is hidden by another one.
>>>>>> Il giorno lun 1 apr 2019 alle ore 18:13 Paolo Pasquali <
>>>>>> paolo.pasquali at gmail.com> ha scritto:
>>>>>>> Ciao Alessio,
>>>>>>> My settings section starts with:
>>>>>>> # To enable the MapStore2 based Client enable those
>>>>>>> if 'geonode_mapstore_client' not in INSTALLED_APPS:
>>>>>>> INSTALLED_APPS += (
>>>>>>> 'mapstore2_adapter',
>>>>>>> 'geonode_mapstore_client',)
>>>>>>> GEONODE_CLIENT_LAYER_PREVIEW_LIBRARY = 'mapstore' # DEPRECATED use
>>>>>>> HOOKSET instead
>>>>>>> GEONODE_CLIENT_HOOKSET =
>>>>>>> "geonode_mapstore_client.hooksets.MapStoreHookSet"
>>>>>>> Thanks,
>>>>>>> P.
>>>>>>> Paolo Pasquali
>>>>>>> ITHACA - Information Technology for Humanitarian Assistance,
>>>>>>> Cooperation and Action
>>>>>>> via Pier Carlo Boggio, 61
>>>>>>> 10138 Torino - Italy
>>>>>>> Tel. +39 011 1975 1872
>>>>>>> Fax +39 011 1975 1122
>>>>>>> On Mon, Apr 1, 2019 at 5:53 PM Alessio Fabiani <
>>>>>>>> Hello Paolo,
>>>>>>>> can you check if the before the Hookset you have the following
>>>>>>>> sentence in your settings file
>>>>>>>> INSTALLED_APPS += (
>>>>>>>> Il giorno lun 1 apr 2019 alle ore 17:45 Paolo Pasquali <
>>>>>>>>> Dear all,
>>>>>>>>> I would like to test MapStore in GeoNode. I've followed the
>>>>>>>>> instructions [1] and removed the related comments in my settings but I get:
>>>>>>>>> ImportError: No module named mapstore2_adapter
>>>>>>>>> Double checking:
>>>>>>>>> $ pip show django-mapstore-adapter
>>>>>>>>> Version: 0.1.13
>>>>>>>>> Summary: Django MapStore2 Adapter
>>>>>>>>> Home-page:
>>>>>>>>> https://github.com/geosolutions-it/django-mapstore-adapter
>>>>>>>>> Author: Alessio Fabiani
>>>>>>>>> Author-email: alessio.fabiani at geo-solutions.it
>>>>>>>>> License: UNKNOWN
>>>>>>>>> Location:
>>>>>>>>> /Users/paolo/Documents/workspaces/teragrop/lib/python2.7/site-packages
>>>>>>>>> Requires: Markdown, requests, django, jsonfield,
>>>>>>>>> djangorestframework, idna, MarkupSafe
>>>>>>>>> Required-by: django-geonode-mapstore-client
>>>>>>>>> And
>>>>>>>>> $ pip show django-geonode-mapstore-client
>>>>>>>>> Version: 0.1.18
>>>>>>>>> Summary: Use GeoNode client in your django projects
>>>>>>>>> Home-page: https://github.com/GeoNode/geonode-mapstore-client
>>>>>>>>> Author-email: alessio.fabiani at gmail.com
>>>>>>>>> License: BSD, see LICENSE file.
>>>>>>>>> Location:
>>>>>>>>> Requires: django-mapstore-adapter
>>>>>>>>> Required-by:
>>>>>>>>> Thanks in advance for your help.
>>>>>>>>> Best,
>>>>>>>>> Paolo
>>>>>>>>> [1]
>>>>>>>>> https://github.com/geosolutions-it/geonode-mapstore-client#integrating-into-geonodedjango
>>>>>>>>> _______________________________________________
>>>>>>>>> geonode-devel mailing list
>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>> Ing. Alessio Fabiani
>>>>>>>> @alfa7691
>>>>>>>> Founder/Technical Lead
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>>>> mob: +39 331 6233686
>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>> Paolo Corti
>>> Geospatial software developer
>>> web: http://www.paolocorti.net
>>> twitter: @capooti
>>> skype: capooti
>> @alfa7691
>> GeoSolutions S.A.S.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
Paolo Corti
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190404/c73fae16/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190404/c73fae16/attachment-0001.png>
More information about the geonode-devel
