[GeoNode-devel] Switching to MapStore in GeoNode
Paolo Corti
pcorti at gmail.com
Thu Apr 4 06:56:31 PDT 2019
Your plan looks wonderful, and I am looking forward to check it after the
next cycle.
keep up with the great work!
paolo
On Thu, Apr 4, 2019 at 3:54 PM Simone Giannecchini <
simone.giannecchini at geo-solutions.it> wrote:
> Ciao Paolo,
> the direction is CSS, SLD is there if you want to copy over styles from
> QGIS.
> CSS editor for the moment is basic, it has autocomplete and so on but
> still it's based on code.
> Another cycle of development will start soon and the direction is to
> complement the code based GUI with a visual styler.
> Obviously, help is appreciated if anyone wants to step up and help.
> Regards,
> Simone Giannecchini
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services for more information.
> Ing. Simone Giannecchini
> @simogeo
> Founder/Director
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 333 8128928
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> On Thu, Apr 4, 2019 at 3:50 PM Paolo Corti <pcorti at gmail.com> wrote:
>> Thanks a lot, it looks really powerful and impressive.
>> Do I understand correctly that there isn't a UI widget for editing styles
>> (such as the one in GeoExplorer) but you can make changes only via the
>> SLD/CSS editor? That could limit the utility for GeoNode instances where
>> general public isn't used to tools which are not UI based.
>> cheers
>> Paolo
>> On Thu, Apr 4, 2019 at 3:37 PM Simone Giannecchini <
>>> These webinars registrations (mind you, they are huge) can help:
>>> https://www.dropbox.com/s/q1rdwuzc4wu0y0f/Map%20Styling%20IGAD%201.mp4?dl=0
>>> https://www.dropbox.com/s/3yrmb5tdrilt9f9/Map%20Styling%20IGAD%202.mp4?dl=0
>>> Regards,
>>> Simone Giannecchini
>>> @simogeo
>>> Founder/Director
>>> GeoSolutions S.A.S.
>>> Italy
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> On Thu, Apr 4, 2019 at 3:29 PM Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> wrote:
>>>> Hi Paolo,
>>>> cool. Currently, it is possible either by clicking the "Styles > Edit"
>>>> from the "Editing Tools" section or by creating/editing a new map
>>>> containing that Layer.
>>>> [image: image.png]
>>>> Il giorno gio 4 apr 2019 alle ore 15:25 Paolo Corti <pcorti at gmail.com>
>>>> ha scritto:
>>>>> Hi Alessio,
>>>>> I gave a first look at this today, and it is really great and a
>>>>> compelling alternative to the old fashioned GeoExplorer :)
>>>>> Could you explain how it is possible to edit a style, as I didn't find
>>>>> the way? Thanks a lot
>>>>> Paolo
>>>>> On Tue, Apr 2, 2019 at 12:47 PM Paolo Pasquali <
>>>>> paolo.pasquali at gmail.com> wrote:
>>>>>> Ciao Alessio,
>>>>>> I've probably messed up my docker installation. I've solved
>>>>>> rebuilding and adding the mapstore packages in the requirements.
>>>>>> I'm still not sure why it didn't work by pip installing them after
>>>>>> the initial setup.
>>>>>> Anyway, thank you Alessio for your support.
>>>>>> I'll get back to you for more info about MapStore for sure... 😀
>>>>>> Ciao,
>>>>>> P.
>>>>>> On Mon, Apr 1, 2019 at 6:39 PM Alessio Fabiani <
>>>>>>> P.S.: it works only with GeoNode 2.10+
>>>>>>> Il giorno lun 1 apr 2019 alle ore 18:36 Alessio Fabiani <
>>>>>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>>>>>>> That is quite strange. Have you been able to get a stacktrace
>>>>>>>> somehow? Maybe try to comment the "GEONODE_CLIENT_HOOKSET" in order to
>>>>>>>> check that the exception does not occur or it is hidden by another one.
>>>>>>>> Il giorno lun 1 apr 2019 alle ore 18:13 Paolo Pasquali <
>>>>>>>> paolo.pasquali at gmail.com> ha scritto:
>>>>>>>>> Ciao Alessio,
>>>>>>>>> My settings section starts with:
>>>>>>>>> # To enable the MapStore2 based Client enable those
>>>>>>>>> if 'geonode_mapstore_client' not in INSTALLED_APPS:
>>>>>>>>> INSTALLED_APPS += (
>>>>>>>>> 'mapstore2_adapter',
>>>>>>>>> 'geonode_mapstore_client',)
>>>>>>>>> GEONODE_CLIENT_LAYER_PREVIEW_LIBRARY = 'mapstore' # DEPRECATED
>>>>>>>>> use HOOKSET instead
>>>>>>>>> GEONODE_CLIENT_HOOKSET =
>>>>>>>>> "geonode_mapstore_client.hooksets.MapStoreHookSet"
>>>>>>>>> Thanks,
>>>>>>>>> P.
>>>>>>>>> Paolo Pasquali
>>>>>>>>> ITHACA - Information Technology for Humanitarian Assistance,
>>>>>>>>> Cooperation and Action
>>>>>>>>> via Pier Carlo Boggio, 61
>>>>>>>>> 10138 Torino - Italy
>>>>>>>>> Tel. +39 011 1975 1872
>>>>>>>>> Fax +39 011 1975 1122
>>>>>>>>> On Mon, Apr 1, 2019 at 5:53 PM Alessio Fabiani <
>>>>>>>>>> Hello Paolo,
>>>>>>>>>> can you check if the before the Hookset you have the following
>>>>>>>>>> sentence in your settings file
>>>>>>>>>> INSTALLED_APPS += (
>>>>>>>>>> Il giorno lun 1 apr 2019 alle ore 17:45 Paolo Pasquali <
>>>>>>>>>>> Dear all,
>>>>>>>>>>> I would like to test MapStore in GeoNode. I've followed the
>>>>>>>>>>> instructions [1] and removed the related comments in my settings but I get:
>>>>>>>>>>> ImportError: No module named mapstore2_adapter
>>>>>>>>>>> Double checking:
>>>>>>>>>>> $ pip show django-mapstore-adapter
>>>>>>>>>>> Version: 0.1.13
>>>>>>>>>>> Summary: Django MapStore2 Adapter
>>>>>>>>>>> Home-page:
>>>>>>>>>>> https://github.com/geosolutions-it/django-mapstore-adapter
>>>>>>>>>>> Author: Alessio Fabiani
>>>>>>>>>>> Author-email: alessio.fabiani at geo-solutions.it
>>>>>>>>>>> License: UNKNOWN
>>>>>>>>>>> Location:
>>>>>>>>>>> /Users/paolo/Documents/workspaces/teragrop/lib/python2.7/site-packages
>>>>>>>>>>> Requires: Markdown, requests, django, jsonfield,
>>>>>>>>>>> djangorestframework, idna, MarkupSafe
>>>>>>>>>>> Required-by: django-geonode-mapstore-client
>>>>>>>>>>> And
>>>>>>>>>>> $ pip show django-geonode-mapstore-client
>>>>>>>>>>> Version: 0.1.18
>>>>>>>>>>> Summary: Use GeoNode client in your django projects
>>>>>>>>>>> Home-page: https://github.com/GeoNode/geonode-mapstore-client
>>>>>>>>>>> Author-email: alessio.fabiani at gmail.com
>>>>>>>>>>> License: BSD, see LICENSE file.
>>>>>>>>>>> Location:
>>>>>>>>>>> Requires: django-mapstore-adapter
>>>>>>>>>>> Required-by:
>>>>>>>>>>> Thanks in advance for your help.
>>>>>>>>>>> Best,
>>>>>>>>>>> Paolo
>>>>>>>>>>> [1]
>>>>>>>>>>> https://github.com/geosolutions-it/geonode-mapstore-client#integrating-into-geonodedjango
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>> @alfa7691
>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>>>>>> mob: +39 331 6233686
>>>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>> Paolo Corti
>>>>> Geospatial software developer
>>>>> web: http://www.paolocorti.net
>>>>> twitter: @capooti
>>>>> skype: capooti
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190404/a68dc46c/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190404/a68dc46c/attachment-0001.png>
More information about the geonode-devel
