[GeoNode-devel] Switching to MapStore in GeoNode
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Apr 8 03:40:47 PDT 2019
Thanks Francesco +1
Il giorno lun 8 apr 2019 alle ore 12:40 Francesco Bartoli <
xbartolone at gmail.com> ha scritto:
> By the way I volunteer to make the devel workshop together with Alessio
> and anybody wants to join at the Summit. It makes sense to me to improve it
> and add a specific section for enabling MapStore as default client.
> Francesco
> Il 8 apr 2019, 12:30 +0200, Paolo Pasquali <
> paolo.pasquali at ithaca.polito.it>, ha scritto:
> Thanks Simone.
> Please consider a MapStore presentation at the next Summit.
> I'm looking forward to learning more.
> Ciao
> P.
> On Thu, Apr 4, 2019 at 3:58 PM Simone Giannecchini <
> simone.giannecchini at geo-solutions.it> wrote:
>> Paolo,
>> the standard version of MapStore (which we are using for GeoNode) does
>> not support vector tiles yet.
>> We are experimenting within the framework of OGC testbeds on the support
>> of vector tiles and the ability to switch server-side rendering to
>> client-side rendering (and the other way around) but this experiment has
>> not landed on master yet.
>> I think Alessio sent links to these pilots earlier, but still, these are
>> pilots of what will come in the future.
>> Regards,
>> Simone Giannecchini
>> GeoServer Professional Services from the experts!
>> Visit http://bit.ly/gs-services for more information.
>> Ing. Simone Giannecchini
>> @simogeo
>> Founder/Director
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054 Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 333 8128928
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
>> On Thu, Apr 4, 2019 at 3:53 PM Paolo Pasquali <
>> paolo.pasquali at ithaca.polito.it> wrote:
>>> Dear Alessio, Simone,
>>> As I understand MapStore can also publish Vector Tiles.
>>> My guess is that the GeoServer Vector Tiles Extension must be installed
>>> [1] since it doesn't come with GeoNode.
>>> The extension works fine with an OpenLayers simple viewer but that must
>>> be defined in the source code with new ol.layer.VectorTile and so on.
>>> Is there any documentation on how to publish vector tiles in MapStore
>>> instead of Image Tiles?
>>> Does the style editor works with Vector Tiles as well?
>>> Thanks!
>>> Ciao
>>> Paolo
>>> [1]
>>> https://docs.geoserver.org/latest/en/user/extensions/vectortiles/install.html
>>> On Thu, Apr 4, 2019 at 3:50 PM Paolo Corti <pcorti at gmail.com> wrote:
>>>> Thanks a lot, it looks really powerful and impressive.
>>>> Do I understand correctly that there isn't a UI widget for editing
>>>> styles (such as the one in GeoExplorer) but you can make changes only via
>>>> the SLD/CSS editor? That could limit the utility for GeoNode instances
>>>> where general public isn't used to tools which are not UI based.
>>>> cheers
>>>> Paolo
>>>> On Thu, Apr 4, 2019 at 3:37 PM Simone Giannecchini <
>>>>> These webinars registrations (mind you, they are huge) can help:
>>>>> https://www.dropbox.com/s/q1rdwuzc4wu0y0f/Map%20Styling%20IGAD%201.mp4?dl=0
>>>>> https://www.dropbox.com/s/3yrmb5tdrilt9f9/Map%20Styling%20IGAD%202.mp4?dl=0
>>>>> Regards,
>>>>> Simone Giannecchini
>>>>> @simogeo
>>>>> Founder/Director
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>> On Thu, Apr 4, 2019 at 3:29 PM Alessio Fabiani <
>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>> Hi Paolo,
>>>>>> cool. Currently, it is possible either by clicking the "Styles >
>>>>>> Edit" from the "Editing Tools" section or by creating/editing a new map
>>>>>> containing that Layer.
>>>>>> <image.png>
>>>>>> Il giorno gio 4 apr 2019 alle ore 15:25 Paolo Corti <pcorti at gmail.com>
>>>>>> ha scritto:
>>>>>>> Hi Alessio,
>>>>>>> I gave a first look at this today, and it is really great and a
>>>>>>> compelling alternative to the old fashioned GeoExplorer :)
>>>>>>> Could you explain how it is possible to edit a style, as I didn't
>>>>>>> find the way? Thanks a lot
>>>>>>> Paolo
>>>>>>> On Tue, Apr 2, 2019 at 12:47 PM Paolo Pasquali <
>>>>>>> paolo.pasquali at gmail.com> wrote:
>>>>>>>> Ciao Alessio,
>>>>>>>> I've probably messed up my docker installation. I've solved
>>>>>>>> rebuilding and adding the mapstore packages in the requirements.
>>>>>>>> I'm still not sure why it didn't work by pip installing them after
>>>>>>>> the initial setup.
>>>>>>>> Anyway, thank you Alessio for your support.
>>>>>>>> I'll get back to you for more info about MapStore for sure... 😀
>>>>>>>> Ciao,
>>>>>>>> P.
>>>>>>>> On Mon, Apr 1, 2019 at 6:39 PM Alessio Fabiani <
>>>>>>>>> P.S.: it works only with GeoNode 2.10+
>>>>>>>>> Il giorno lun 1 apr 2019 alle ore 18:36 Alessio Fabiani <
>>>>>>>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>>>>>>>>> That is quite strange. Have you been able to get a stacktrace
>>>>>>>>>> somehow? Maybe try to comment the "GEONODE_CLIENT_HOOKSET" in order to
>>>>>>>>>> check that the exception does not occur or it is hidden by another one.
>>>>>>>>>> Il giorno lun 1 apr 2019 alle ore 18:13 Paolo Pasquali <
>>>>>>>>>> paolo.pasquali at gmail.com> ha scritto:
>>>>>>>>>>> Ciao Alessio,
>>>>>>>>>>> My settings section starts with:
>>>>>>>>>>> # To enable the MapStore2 based Client enable those
>>>>>>>>>>> if 'geonode_mapstore_client' not in INSTALLED_APPS:
>>>>>>>>>>> INSTALLED_APPS += (
>>>>>>>>>>> 'mapstore2_adapter',
>>>>>>>>>>> 'geonode_mapstore_client',)
>>>>>>>>>>> GEONODE_CLIENT_LAYER_PREVIEW_LIBRARY = 'mapstore' # DEPRECATED
>>>>>>>>>>> use HOOKSET instead
>>>>>>>>>>> GEONODE_CLIENT_HOOKSET =
>>>>>>>>>>> "geonode_mapstore_client.hooksets.MapStoreHookSet"
>>>>>>>>>>> Thanks,
>>>>>>>>>>> P.
>>>>>>>>>>> Paolo Pasquali
>>>>>>>>>>> ITHACA - Information Technology for Humanitarian Assistance,
>>>>>>>>>>> Cooperation and Action
>>>>>>>>>>> via Pier Carlo Boggio, 61
>>>>>>>>>>> 10138 Torino - Italy
>>>>>>>>>>> Tel. +39 011 1975 1872
>>>>>>>>>>> Fax +39 011 1975 1122
>>>>>>>>>>> On Mon, Apr 1, 2019 at 5:53 PM Alessio Fabiani <
>>>>>>>>>>>> Hello Paolo,
>>>>>>>>>>>> can you check if the before the Hookset you have the following
>>>>>>>>>>>> sentence in your settings file
>>>>>>>>>>>> INSTALLED_APPS += (
>>>>>>>>>>>> Il giorno lun 1 apr 2019 alle ore 17:45 Paolo Pasquali <
>>>>>>>>>>>>> Dear all,
>>>>>>>>>>>>> I would like to test MapStore in GeoNode. I've followed the
>>>>>>>>>>>>> instructions [1] and removed the related comments in my settings but I get:
>>>>>>>>>>>>> ImportError: No module named mapstore2_adapter
>>>>>>>>>>>>> Double checking:
>>>>>>>>>>>>> $ pip show django-mapstore-adapter
>>>>>>>>>>>>> Version: 0.1.13
>>>>>>>>>>>>> Summary: Django MapStore2 Adapter
>>>>>>>>>>>>> Home-page:
>>>>>>>>>>>>> https://github.com/geosolutions-it/django-mapstore-adapter
>>>>>>>>>>>>> Author: Alessio Fabiani
>>>>>>>>>>>>> Author-email: alessio.fabiani at geo-solutions.it
>>>>>>>>>>>>> License: UNKNOWN
>>>>>>>>>>>>> Location:
>>>>>>>>>>>>> /Users/paolo/Documents/workspaces/teragrop/lib/python2.7/site-packages
>>>>>>>>>>>>> Requires: Markdown, requests, django, jsonfield,
>>>>>>>>>>>>> djangorestframework, idna, MarkupSafe
>>>>>>>>>>>>> Required-by: django-geonode-mapstore-client
>>>>>>>>>>>>> And
>>>>>>>>>>>>> $ pip show django-geonode-mapstore-client
>>>>>>>>>>>>> Version: 0.1.18
>>>>>>>>>>>>> Summary: Use GeoNode client in your django projects
>>>>>>>>>>>>> Home-page: https://github.com/GeoNode/geonode-mapstore-client
>>>>>>>>>>>>> Author-email: alessio.fabiani at gmail.com
>>>>>>>>>>>>> License: BSD, see LICENSE file.
>>>>>>>>>>>>> Location:
>>>>>>>>>>>>> Requires: django-mapstore-adapter
>>>>>>>>>>>>> Required-by:
>>>>>>>>>>>>> Thanks in advance for your help.
>>>>>>>>>>>>> Best,
>>>>>>>>>>>>> Paolo
>>>>>>>>>>>>> [1]
>>>>>>>>>>>>> https://github.com/geosolutions-it/geonode-mapstore-client#integrating-into-geonodedjango
>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>>>>>>>> mob: +39 331 6233686
>>>>>>>>>>>> personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei
>>>>>>>>>>>> dati “GDPR”), si precisa che ogni circostanza inerente alla presente email
>>>>>>>>>>>> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
>>>>>>>>>>>> conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente.
>>>>>>>>>>>> Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni
>>>>>>>>>>>> altra operazione è illecita. Le sarei comunque grato se potesse darmene
>>>>>>>>>>>> notizia.
>>>>>>>>>>>> it is addressed and may contain information that is privileged,
>>>>>>>>>>>> confidential or otherwise protected from disclosure. We remind that - as
>>>>>>>>>>>> provided by European Regulation 2016/679 “GDPR” - copying, dissemination or
>>>>>>>>>>>> use of this e-mail or the information herein by anyone other than the
>>>>>>>>>>>> intended recipient is prohibited. If you have received this email by
>>>>>>>>>>>> mistake, please notify us immediately by telephone or e-mail.
>>>>>>>>>> @alfa7691
>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>> Paolo Corti
>>>>>>> Geospatial software developer
>>>>>>> web: http://www.paolocorti.net
>>>>>>> twitter: @capooti
>>>>>>> skype: capooti
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>> Paolo Corti
>>>> twitter: @capooti
>>>> skype: capooti
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190408/a788c2db/attachment-0001.html>
More information about the geonode-devel
