[GeoNode-devel] FOSS4G 2019 GeoNode status talk
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Apr 15 05:40:32 PDT 2019
Yeps. Thanks both.
Il giorno lun 15 apr 2019 alle ore 14:39 Angelos Tzotsos <
gcpp.kalxas at gmail.com> ha scritto:
> Excellent!
> Can you please submit it Alessio as the PSC chair?
> Thanks!
> Angelos
> On 4/15/19 3:34 PM, Francesco Bartoli wrote:
> > Hi Alessio,
> > The presentation from Paolo is great but I would suggest to use the
> abstract below from the article written at the beginning of this year.
> > GeoNode is an open source framework designed to build geospatial content
> management systems (GeoCMS) and spatial data infrastructure (SDI) nodes.
> Its development was initiated by the Global Facility for Disaster Reduction
> and Recovery (GFDRR) in 2009 and adopted by a large number of organizations
> in the following years. Using an open source stack based on mature and
> robust frameworks and software like Django, OpenLayers, PostGIS, GeoServer
> and pycsw, an organization can build on top of GeoNode its SDI or
> geospatial open data portal. GeoNode provides a large number of user
> friendly capabilities, broad interoperability using Open Geospatial
> Consortium (OGC) standards, and a powerful authentication/authorization
> mechanism. Supported by a vast, diverse and global open source community,
> GeoNode is an official project of the Open Source Geospatial Foundation
> (OSGeo).
> > Francesco
> > Il 15 apr 2019, 14:31 +0200, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it>, ha scritto:
> >> Hi Angelos,
> >> right, thanks for highlighting this. you are right.
> >> If no other options/volunteers, I can submit it. The most updated one
> currently is the one submitted by @capooti (Paolo Corti) @ FOSS4G-NA.
> >> Let me check if I can retrieve it somewhere or if Paolo can send it to
> us.
> >>> Il giorno lun 15 apr 2019 alle ore 13:46 Angelos Tzotsos <
> >>>> Hi all,
> >>>> We are only 12h from deadline to submit a GeoNode status talk to
> FOSS4G.
> >>>> Has anyone submitted this talk?
> >>>> If not, does anyone have the abstract from last year in order to adapt
> >>>> and submit?
> >>>> Best,
> >>>> Angelos
> >>>> Angelos Tzotsos, PhD
> >>>> Charter Member
> >>>> http://users.ntua.gr/tzotsos
> >>>> _______________________________________________
> >>>> geonode-devel mailing list
> >>>> geonode-devel at lists.osgeo.org
> >>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> >> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> >> Ing. Alessio Fabiani
> >> @alfa7691
> >> Founder/Technical Lead
> >> GeoSolutions S.A.S.
> >> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> >> phone: +39 0584 962313
> >> fax: +39 0584 1660272
> >> mob: +39 331 6233686
> >> http://www.geo-solutions.it
> >> http://twitter.com/geosolutions_it
> >> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> >> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> Charter Member
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190415/fe41de64/attachment-0001.html>
More information about the geonode-devel
