[GeoNode-devel] Time for 2.10rc5?
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Apr 16 07:32:09 PDT 2019
Hi Angelos,
yes, currently some help would be much appreciated since I'm a bit
overwhelmed with work these days.
First of all, we can start by bumping the GeoNode version on the
repositories. This is quite straightforward.
Il giorno mar 16 apr 2019 alle ore 16:21 Angelos Tzotsos <
gcpp.kalxas at gmail.com> ha scritto:
> Hi Alessio,
> I have already done some cleanup in my working ppa:
> https://launchpad.net/~gcpp-kalxas/+archive/ubuntu/geonode/+packages
> I can help with the deb packages for rc5
> Cheers,
> Angelos
> On 4/16/19 5:18 PM, Alessio Fabiani wrote:
> > Hi Angelos,
> > yes, absolutely. Especially we plan to rebuild and publish the deb
> packages
> > to the launchpad.
> > We should move to rc5 before doing any work on dependencies cleanup and
> fix.
> > Il giorno mar 16 apr 2019 alle ore 11:39 Angelos Tzotsos <
> >> Hi all,
> >> I am currently reviewing our debian packages and I noticed that the
> >> dependencies in master are different than our latest pre-release
> (2.10rc4).
> >> I am wondering if now would be a good time to cut another RC.
> >> Cheers,
> >> Angelos
> >> Angelos Tzotsos, PhD
> >> Charter Member
> >> Open Source Geospatial Foundation
> >> http://users.ntua.gr/tzotsos
> >> _______________________________________________
> >> geonode-devel mailing list
> >> geonode-devel at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Charter Member
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190416/f364b477/attachment.html>
More information about the geonode-devel mailing list
