[GeoNode-devel] Incorporate Docker repositories into main repo
Francesco Bartoli xbartolone at gmail.com
Tue Apr 16 07:47:08 PDT 2019
Hi Florian,
this was in the roadmap but it’s not easily achievable as one could expect because it would break the automated build mechanism of nginx, geoserver and postgis images on Docker Hub from those repos.
We should come up with a good proposal that might maintain the current automation before the move.
Francesco
Il 16 apr 2019, 13:20 +0200, Florian Hoedt <florian.hoedt at thuenen.de>, ha scritto:
> Hi,
> As discussed by @frafra and me:
> https://github.com/GeoNode/geonode/pull/4355#discussion_r274414735
> https://gitter.im/GeoNode/general?at=5cb43fec20fbe911eebaa0b1
> we should think about merging the outside residing Dockerfiles into the main repository. The docker stack is very closely coupled with GeoNode and imho nginx, GeoServer and PostgreSQL should be managed by the main repo. There where some issues in not properly synched geonode-docker images in the past and some intended pull request can only be properly tested, if dockerfiles are modified.
> I would propose a new 'docker' folder which will hold one folder per image:
> docker/...
> ./nginx
> ./Dockerfile
> ./postgres
> ./geoserver
> Furthermore I would propose to use just one single .env file located at root for configuring the docker-compose.yml - like currently used in spc-geonode.
> What are your thoughts about that?
> Florian
> MSc Florian Hoedt
> Koordinator Geoinformation | Coordinator Geoinformatics
> Thünen-Institut, Zentrum für Informationsmanagement | Thünen Institute, Centre for Information Management
> Bundesallee 44
> 38116 Braunschweig
> Tel: +49 531 596-1428
> Fax: +49 531 596-1499
> Mail: florian.hoedt at thuenen.de
> Web: www.thuenen.de
> Das Johann Heinrich von Thünen-Institut, Bundesforschungsinstitut für Ländliche Räume, Wald und Fischerei - kurz: Thünen-Institut - besteht aus 14 Fachinstituten, die in den Bereichen Ökonomie, Ökologie und Technologie forschen und die Politik beraten.
> The Johann Heinrich von Thünen Institute, Federal Research Institute for Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists of 14 specialized institutes that carry out research and provide policy advice in the fields of economy, ecology and technology.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190416/05a09a24/attachment.html>
More information about the geonode-devel mailing list
