[GeoNode-devel] PSC: Continue with Transifex yes/no
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Apr 30 08:49:26 PDT 2019
+1 to shutdown Transifex, using PRs, as usual, is much more trackable,
revertable and reliable.
Il giorno mar 30 apr 2019 alle ore 13:52 Florian Hoedt <
florian.hoedt at thuenen.de> ha scritto:
> Hi,
> My +1 for Shutdown Transifex and stay with PR´s as explained here [2]?
> I think the google doc is very easy to follow and we do not need Transifex
> as collaborative plattform.
> cheers,
> Florian
> [2]
> https://docs.google.com/document/d/1DKSznzz6m8PWDGNgFwdxN1jOd0s4tH8y036K96CBfYs/edit#heading=h.305bg1fpxz2o
> MSc Florian Hoedt
> Koordinator Geoinformation | Coordinator Geoinformatics
> Thünen-Institut, Zentrum für Informationsmanagement | Thünen Institute,
> Centre for Information Management
> Bundesallee 44
> 38116 Braunschweig
> Tel:  +49 531 596-1428
> Fax:  +49 531 596-1499
> Mail: florian.hoedt at thuenen.de
> Web:  www.thuenen.de
> Das Johann Heinrich von Thünen-Institut, Bundesforschungsinstitut für
> Ländliche Räume, Wald und Fischerei - kurz: Thünen-Institut - besteht aus
> 14 Fachinstituten, die in den Bereichen Ökonomie, Ökologie und Technologie
> forschen und die Politik beraten.
> The Johann Heinrich von Thünen Institute, Federal Research Institute for
> Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists
> of 14 specialized institutes that carry out research and provide policy
> advice in the fields of economy, ecology and technology.
> *Von: *"Toni Schönbuchner" <toni.schoenbuchner at csgis.de>
> *An: *"geonode-devel" <geonode-devel at lists.osgeo.org>
> *Gesendet: *Dienstag, 30. April 2019 09:50:44
> *Betreff: *[GeoNode-devel] PSC: Continue with Transifex yes/no
> Dear PSC members,
> Dear Devs,
> with the lastest update [1] of translations a discussion at Gitter started
> whether the use of Transifex still makes sense.
> The current situation is that Transifex has little or no maintenance.
> Furthermore, many translations are out of sync with Github.
> It may well happen that somebody invests time working on an outdated
> translation at Transifex but overwrites a newer po file at GitHub.
> At Gitter, we agreed that translations will be easier to maintain by just
> editing a language file locally and then creating a PR.
> The question is therefore:
> Your +1 / -1 or any further idea is very welcome.
> (Angelos Tzotsos and Alessio Fabiani already gave their +1 at Gitter)
> Best regards,
> Toni
> [1] https://github.com/GeoNode/geonode/pull/4372
> [2]
> CSGIS
> Kolonnadenstraße 1
> 04109 Leipzig
> Tel  +49/ (0) 341 24 04 738
> Fax  +49/ (0) 341 24 04 739
> Web http://csgis.de
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
> ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> geonode-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190430/3a9db523/attachment-0001.html>
More information about the geonode-devel mailing list
