[GeoNode-devel] GeoServer doesn't show layer just after
Paolo Corti
pcorti at gmail.com
Thu Aug 22 07:25:04 PDT 2019
Thanks Toni for you help
after some debugging I believe the incorrect behavior is caused for
our instance because we have DELAYED_SECURITY_SIGNALS set to True.
After restoring this to False everything works as expected - at least right now.
Paolo
On Thu, Aug 22, 2019 at 3:06 AM Toni Schönbuchner
<toni.schoenbuchner at csgis.de> wrote:
> Dear Paolo,
> I suppose you already double checked the oauth2 settings on both sides further
> REST ROLE SERVICE setttings.
> Can you double check geofence rules for a newly uploaded layer?
> Are those set correctly to grant view permissions?
> Cheers,
> Toni
> > Message: 1
> > Date: Wed, 21 Aug 2019 14:09:08 -0400
> > From: Paolo Corti <pcorti at gmail.com>
> > To: geonode-devel <geonode-devel at lists.osgeo.org>
> > Subject: [GeoNode-devel] GeoServer doesn't show layer just after
> > upload
> > Message-ID:
> > <CAHXrU-KHkaYMwwyaYCAOyK55zth==uD-si+hFPqHq8++8_hUgg at mail.gmail.com>
> > Content-Type: text/plain; charset="UTF-8"
> > Hi GeoServer developers
> > we are experiencing the following issue in our staging (not sure when
> > this started happening, but before, a few weeks back, this worked
> > correctly).
> > When a user upload a layer, the layer is correctly created in
> > GeoServer and in GeoNode and can be seen in GeoServer layer preview,
> > but the user cannot see it in the GeoNode layer details page and in
> > the map composer.
> > The following error is logged:
> > ERROR [geoserver.ows] -
> > org.geoserver.platform.ServiceException: Could not find layer geonode:layername
> > If I restart GeoServer the layer is working again. Same thing if I log
> > in to the GeoServer admin interface in the same session.
> > The problem arise with any kind of user, including admin.
> > We are using GeoNode from master and GeoServer 2.15.2
> > thanks in advance!
> > Paolo
> > Paolo Corti
> > Geospatial software developer
> > web: http://www.paolocorti.net
> > twitter: @capooti
> > skype: capooti
> > #drt3jc1
> > Subject: Digest Footer
> > geonode-devel mailing list
> > https://lists.osgeo.org/mailman/listinfo/geonode-devel
> > End of geonode-devel Digest, Vol 55, Issue 14
Paolo Corti
twitter: @capooti
skype: capooti
#drt3jc1
More information about the geonode-devel
