[GeoNode-devel] GeoServer doesn't show layer just after
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Tue Aug 27 00:00:36 PDT 2019
Hi Paolo,
I am at the foss4g these days.
I'll look into that as soon as I go back to my office.
Il lun 26 ago 2019, 19:49 Paolo Corti <pcorti at gmail.com> ha scritto:
> Hi Alessio
> I could debug a bit more the issue. In our instance we use both the
> uploaders, the REST for uploading shapefiles and GeoTIFFs and the
> importer for geojson files. I realized that the reported problems
> occurs ONLY when uploading geojson files (with the importer uploader).
> So standard GeoNode instances are not impacted by this issue.
> My best guess is that when using the importer
> set_geofence_invalidate_cache isn't called.
> Do you have time to look into this (I am sure you know exactly what
> changes are required in the code)? Otherwise I can go deeper with
> debugging and maybe provide a fix.
> thanks
> Paolo
> On Thu, Aug 22, 2019 at 11:43 AM Alessio Fabiani
> <alessio.fabiani at geo-solutions.it> wrote:
> > Dear all,
> > if you set the DELAYED_SECURITY flag to True, you must also be sure the
> "cronjob" or whatever is running and currently refreshnig the GeoNode
> permissions.
> > @Paolo Corti di you noticed the flag "dirty" disappearing after some
> time? If yes, it might be a regression causing the management command to
> not being able to sync the GeoFence rules anymore.
> > Il giorno gio 22 ago 2019 alle ore 16:41 Paolo Corti <pcorti at gmail.com>
> ha scritto:
> >> Yes Toni, that could be a possible bug. Let's wait for Alessio opinion
> >> about it and we can file a ticket in the case to report it
> >> cheers
> >> Paolo
> >> On Thu, Aug 22, 2019 at 10:36 AM Toni Schönbuchner
> >> <toni.schoenbuchner at csgis.de> wrote:
> >> > Hey Paolo,
> >> > This makes somehow sense. Then geofence rules might not be in sync.
> >> > However as long a celery worker is available it should work update
> after every DELAYED_SECURITY_INTERVAL ?!
> >> > Maybe systemd or supervisord need to be (re-)started.
> >> > Anyways good you found it.
> >> > Cheers,
> >> > Toni
> >> > CSGIS
> >> > Gottschedstraße 12
> >> > 04109 Leipzig
> >> > Telefon 0341. 39 37 3397
> >> > Web https://csgis.de
> >> > Hinweis gemäß § 33 BDSG
> >> > Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument
> ist ausschließlich für den
> >> > Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> >> > erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> >> > von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> >> > Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> >> > Am 22.08.2019 um 16:25 schrieb Paolo Corti <pcorti at gmail.com>:
> >> > DELAYED_SECURITY_SIGNALS
> >> Paolo Corti
> >> Geospatial software developer
> >> web: http://www.paolocorti.net
> >> twitter: @capooti
> >> skype: capooti
> >> #drt3jc1
> >> _______________________________________________
> >> geonode-devel mailing list
> >> geonode-devel at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> > GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> > Ing. Alessio Fabiani
> > @alfa7691
> > Founder/Technical Lead
> > GeoSolutions S.A.S.
> > Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> > phone: +39 0584 962313
> > fax: +39 0584 1660272
> > mob: +39 331 6233686
> > http://www.geo-solutions.it
> > http://twitter.com/geosolutions_it
> > Con riferimento alla normativa sul trattamento dei dati personali (Reg.
> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> > This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> Paolo Corti
> twitter: @capooti
> skype: capooti
> #drt3jc1
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190827/c410946e/attachment.html>
More information about the geonode-devel
