[GeoNode-devel] [Docker][SPCGeonode] Questions
João Gaspar
joao.f.r.gaspar at gmail.com
Wed Dec 25 12:06:23 PST 2019
first of all, let me congratulate the excellent job with this configuration.
I install the last version of SPCGeonode with docker in Kubuntu following
your guide.
Everything was install has expected but now I found some issues that I want
to clarify before to report as a bug.
Actual problems:
Adding a remote service from a QGIS Server connection, read the layers but
don't project the layer and after the harvest assumes a different URL.
So if I do
http://siteURL/qgis/qgis_mapserv.fcgi.exe?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&MAP=repo/project.qgs
after the harvest the URL is changed to
http://siteURL/qgis/qgis_mapserv.fcgi.exe?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities?MAP=repo/project.qgs
I tested this in a previous version of geonode and works fine.
After trying a lot of times without success the adding remote service I
think to add wms service using Backoffice GeoServer. After try to add the
Layers from the QGIS Server connection I lose the ability to see the layers
with a java error Then I try to delete the store but give me the same
error message when I try to see the layers. I test using geoserver/rest/
and I have the following error: Don't know how to handle resource
WMTSLayerInfoImpl[layer]
So the layer is in ESPG:32629
PROJCS["WGS 84 / UTM zone 29N",GEOGCS["WGS
84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-9],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Easting",EAST],AXIS["Northing",NORTH],AUTHORITY["EPSG","32629"]]
And the qgis server project is in EPSG:4326
I notice that the user projections don't have the ESPG:32629 in the file
/opt/geonode/scripts/spcgeonode/_volume_geodatadir/user_projections/epsg.properties
This can be the problem?
My questions:
When do I want to do changes what is the correct action?
Sudo docker exec -it spc_container /bin/bash to enter in the container? If
yes, I tried but I have the permission denied.
OR
I change the directory inside Scripts/SPCgeonode and do the build? If yes,
what is the right docker build command?
Thank you for your time.
P.S: I'm available to help in this SPCGeonode Docs and try to clarify some
possible steps or explain the purposes of each folder and docker commands.
For me is a good way to learn and have an official source to look.
Best regards,
João
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20191225/727efd2c/attachment.html>
More information about the geonode-devel
