[GeoNode-devel] Custom geonode project installation
Dimitris Kar
dkarakostis at gmail.com
Wed Jan 2 02:56:45 PST 2019
Hello Toni,
At last I found some time to try your instructions for installing the
geonode-project. Everything was installed successfully but when I try to
execute the paver commands I get certain errors.
More specifically - after enabling the local_settings - when I run:
DJANGO_SETTINGS_MODULE=wfp_geonode.local_settings paver start
I get
---> pavement.start
---> pavement.start_geoserver
cd /vagrant/wfp_geonode/geoserver/data
Captured Task Output:
---> pavement.start
File
"/home/ubuntu/Envs/wfp_geonode/local/lib/python2.7/site-packages/paver/tasks.py",
line 196, in _run_task
return do_task()
File
line 192, in do_task
task()
File
line 321, in __call__
retval = environment._run_task(self.name, self.needs, self.func)
File
line 214, in _run_task
return do_task()
File
line 193, in do_task
return func(**kw)
File "pavement.py", line 667, in start_geoserver
with pushd(data_dir):
File "/usr/lib/python2.7/contextlib.py", line 17, in __enter__
return self.gen.next()
File
"/home/ubuntu/Envs/wfp_geonode/local/lib/python2.7/site-packages/paver/path.py",
line 39, in pushd
os.chdir(dir)
OSError: [Errno 2] No such file or directory:
'/vagrant/wfp_geonode/geoserver/data'
It seems like it can not find the geoserver folder. And in fact there is no
geoserver folder under the wfp_geonode installation:
dev_config.yml Dockerfile jetty-runner.xml *package*/
README.rst setup.py wait-for-databases.sh
docker-compose.override.yml *entrypoint.sh** Makefile pavement.py
requirements.txt tasks.py *wfp_geonode*/
docker-compose.yml *fixtures*/ *manage.py**
playbook.yml *scripts*/ uwsgi.ini *wfp_geonode.egg-info*/
Do you have any clue, what could be the problem?
On Wed, Dec 19, 2018 at 5:27 PM Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Hi Dimitris,
> it sounds you´re a bit puzzled between 'geonode core‘ and geonode-project.
> To understand better see whats happening with geonode-project:
> It installs `geonode core` as dependency:
> https://github.com/GeoNode/geonode-project/blob/master/requirements.txt#L2
> further loads/overwrites it´s settings:
> https://github.com/GeoNode/geonode-project/blob/master/project_name/settings.py#L30
> Doing so we can overwrite things like templates etc. in Geonode-Project
> without touching
> core files.
> As a rule of thumb, if you´d like to commit changes to geonode core,
> create a fork of the upstream
> repository, do your changes and create a PR.
> I think in your case – as you´d like to modify *your* specific version –
> start by creating a geonode
> project as described here (and ignore the first 'geonode core' dev setup):
> https://github.com/GeoNode/geonode-project#create-a-custom-project
> I hope I did not misunderstood your question.
> Happy geonod’ ing.
> – Toni
> CSGIS
> Kolonnadenstraße 1
> 04109 Leipzig
> Mobil +49/ (0) 176 6680 3198
> Tel +49/ (0) 341 24 04 738
> Fax +49/ (0) 341 24 04 73
> Web http://csgis.de
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
> ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> Message: 1
> Date: Wed, 19 Dec 2018 16:57:16 +0100
> From: Dimitris Kar <dkarakostis at gmail.com>
> To: geonode-devel <geonode-devel at lists.osgeo.org>
> Subject: [GeoNode-devel] Custom geonode project installation
> Message-ID:
> <CAH4UFc99H4OuAxKUc+FhFZ=13gSJZDdMnH7Lj1=ec49Qg+6sgA at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hello all,
> I am trying following the instructions from this workshop (
> http://geonode.org/dev-workshop/#/2) in order to install GeoNode and a
> GeoNode project. I have installed GeoNode in dev mode using a python
> virtualenv + django development server method.
> Then I follow the instructions in order to create a geonode-project as
> following:
> 1. cd ./geonode
> 2. django-admin.py startproject wfp_geonode --template=
> https://github.com/GeoNode/geonode-project/archive/master.zip -e
> py,rst,json,yml,ini,env,sample -n Dockerfile wfp_geonode (I executed
> this command without includong: -n Dockerfile wfp_geonode)
> 3. workon geonode
> 4. cd wfp_geonode
> 5. pip install -e wfp_geonode
> 6. cd ../geonode
> 7. DJANGO_SETTINGS_MODULE=wfp_geonode.local_settings paver start
> But when I actually run the command, I get the below command. If I am not
> wrong, I remember, that I can not use geonode-project aside with a geonode
> dev installation but this is not quite clear in the above workshop
> presentation (see above link).
> Did anyone had similar issues? Should I install a geonode for production
> and use the geonode-project then?
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190102/fe831d7b/attachment.html>
More information about the geonode-devel
