[GeoNode-devel] Custom geonode project installation
Dimitris Kar dkarakostis at gmail.com
Wed Jan 2 06:19:32 PST 2019
Hey Toni,
Yes. Actually when I execute the paver setup (as above), I get:
IOError: [Errno 13] Permission denied: '/usr/local/share/GeoIP'
GeoNode development environment successfully set up.If you have not set up
an administrative account, please do so now. Use "paver start" to start up
the server.
And then when I run the paver sync or the paver start (as in the
instructions), I get:
django.db.utils.OperationalError: could not connect to server: Connection
refused
    Is the server running on host "localhost" (127.0.0.1) and accepting
    TCP/IP connections on port 5432?
GeoNode is now available. "
I am running the installation in a virtual environment inside a vagrant VM
(ubuntu/xenial64). I thought it could be related with the port forwarding
but that seems to be configured ok in the vagrantfile:
  config.vm.network :forwarded_port, guest: 5432, host: 5432
I also tried to check the configuration in the pg_config file but I can not
find out where my postgres is installed. I run: which psql but there is no
output.
Have you faced this issue before?
On a different note, the installation comes with jetty server right?
On Wed, Jan 2, 2019 at 1:27 PM Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Hi Dimitris,
> have you run
> DJANGO_SETTINGS_MODULE=wfp_geonode.local_settings paver setup
> this should download and create geoserver dependencies.
> Cheers,
> Toni
> CSGIS
> Kolonnadenstraße 1
> 04109 Leipzig
> Mobil +49/ (0) 176 6680 3198
> Tel  +49/ (0) 341 24 04 738
> Fax  +49/ (0) 341 24 04 73
> Web http://csgis.de
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
> ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> Am 02.01.2019 um 11:56 schrieb Dimitris Kar <dkarakostis at gmail.com>:
> Hello Toni,
> At last I found some time to try your instructions for installing the
> geonode-project. Everything was installed successfully but when I try to
> execute the paver commands I get certain errors.
> More specifically - after enabling the local_settings -  when I run:
> DJANGO_SETTINGS_MODULE=wfp_geonode.local_settings paver start
> I get
> ---> pavement.start
> ---> pavement.start_geoserver
> cd /vagrant/wfp_geonode/geoserver/data
> Captured Task Output:
> ---> pavement.start
> Traceback (most recent call last):
>   File
> "/home/ubuntu/Envs/wfp_geonode/local/lib/python2.7/site-packages/paver/tasks.py",
> line 196, in _run_task
>     return do_task()
>   File
> line 192, in do_task
>     task()
>   File
> line 321, in __call__
>     retval = environment._run_task(self.name, self.needs, self.func)
>   File
> line 214, in _run_task
>     return do_task()
>   File
> line 193, in do_task
>     return func(**kw)
>   File "pavement.py", line 667, in start_geoserver
>     with pushd(data_dir):
>   File "/usr/lib/python2.7/contextlib.py", line 17, in __enter__
>     return self.gen.next()
>   File
> "/home/ubuntu/Envs/wfp_geonode/local/lib/python2.7/site-packages/paver/path.py",
> line 39, in pushd
>     os.chdir(dir)
> OSError: [Errno 2] No such file or directory:
> '/vagrant/wfp_geonode/geoserver/data'
> It seems like it can not find the geoserver folder. And in fact there is
> no geoserver folder under the wfp_geonode installation:
> dev_config.yml               Dockerfile      jetty-runner.xml  *package*/
>     README.rst        setup.py   wait-for-databases.sh
> docker-compose.override.yml  *entrypoint.sh**  Makefile          pavement.py
>   requirements.txt  tasks.py   *wfp_geonode*/
> docker-compose.yml           *fixtures*/       *manage.py**
> playbook.yml  *scripts*/          uwsgi.ini  *wfp_geonode.egg-info*/
> Do you have any clue, what could be the problem?
> On Wed, Dec 19, 2018 at 5:27 PM Toni Schönbuchner <
>> Hi Dimitris,
>> it sounds you´re a bit puzzled between 'geonode core‘ and geonode-project.
>> To understand better see whats happening with geonode-project:
>> It installs `geonode core` as dependency:
>> https://github.com/GeoNode/geonode-project/blob/master/requirements.txt#L2
>> further loads/overwrites it´s settings:
>> https://github.com/GeoNode/geonode-project/blob/master/project_name/settings.py#L30
>> Doing so we can overwrite things like templates etc. in Geonode-Project
>> without touching
>> core files.
>> As a rule of thumb, if you´d like to commit changes to geonode core,
>> create a fork of the upstream
>> repository, do your changes and create a PR.
>> I think in your case – as you´d like to modify *your* specific version –
>> start by creating a geonode
>> project as described here (and ignore the first 'geonode core' dev setup):
>> https://github.com/GeoNode/geonode-project#create-a-custom-project
>> I hope I did not misunderstood your question.
>> Happy geonod’ ing.
>> – Toni
>> CSGIS
>> Kolonnadenstraße 1
>> 04109 Leipzig
>> Web http://csgis.de
>> Message: 1
>> Date: Wed, 19 Dec 2018 16:57:16 +0100
>> From: Dimitris Kar <dkarakostis at gmail.com>
>> To: geonode-devel <geonode-devel at lists.osgeo.org>
>> Subject: [GeoNode-devel] Custom geonode project installation
>> Message-ID:
>> <CAH4UFc99H4OuAxKUc+FhFZ=13gSJZDdMnH7Lj1=ec49Qg+6sgA at mail.gmail.com>
>> Content-Type: text/plain; charset="utf-8"
>> Hello all,
>> I am trying following the instructions from this workshop (
>> http://geonode.org/dev-workshop/#/2) in order to install GeoNode and a
>> GeoNode project. I have installed GeoNode in dev mode using a python
>> virtualenv + django development server method.
>> Then I follow the instructions in order to create a geonode-project as
>> following:
>>   1. cd ./geonode
>>   2. django-admin.py startproject wfp_geonode --template=
>>   https://github.com/GeoNode/geonode-project/archive/master.zip -e
>>   py,rst,json,yml,ini,env,sample -n Dockerfile wfp_geonode  (I executed
>>   this command without includong: -n Dockerfile wfp_geonode)
>>   3. workon geonode
>>   4. cd wfp_geonode
>>   5. pip install -e wfp_geonode
>>   6. cd ../geonode
>>   7. DJANGO_SETTINGS_MODULE=wfp_geonode.local_settings paver start
>> But when I actually run the command, I get the below command. If I am not
>> wrong, I remember, that I can not use geonode-project aside with a geonode
>> dev installation but this is not quite clear in the above workshop
>> presentation (see above link).
>> Did anyone had similar issues? Should I install a geonode for production
>> and use the geonode-project then?
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190102/5328bfe9/attachment-0001.html>
More information about the geonode-devel mailing list
