[GeoNode-devel] Custom geonode project installation
Dimitris Kar
dkarakostis at gmail.com
Tue Jan 8 01:22:18 PST 2019
Thanks Toni,
The video was really helpful. I was doing a really silly mistake confusing
the paths of the different projects. So the synchronization between my host
machine and the vagrant VM was not working properly. Everything is working
as expected now.
Thanks again for your time.
Cheers
On Mon, Jan 7, 2019 at 7:49 PM Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Dear Dimitris,
> I think this is based on some missunderstanding. I´ve just screenrecorded
> a short video for you https://vimeo.com/309933580
> What you see is geonode project running by use of django dev server on
> port 8000.
> First I´m changing the layers_details.html in "geonode" core. Which is as
> a dependency
> installed in the virtualenv directory in src folder. Later the video shows
> the same
> but by use of geonode project. Please excuse my typos, it´s been a bit of
> a long day :)
> Let me know if this works for you.
> Cheers,
> Toni
> Am 07.01.2019 um 09:25 schrieb Dimitris Kar <dkarakostis at gmail.com>:
> Hey Toni,
> Unfortunately I can not confirm it. I still don't see the changes. Perhaps
> I edit the wrong files? The source code for the core project is
> under: /Envs/wfp_geonode/src/geonode
> I tried to restart the local server after the changes but there was no
> effect. Just in case, I also changed the permissions of the files.
> Cheers
> Dimitris
> On Fri, Jan 4, 2019 at 11:17 AM Toni Schönbuchner <
>> Hi Dimitris,
>> great to hear! For understanding
>> If there is no file within your project structure which overwrites the
>> core your core
>> changes should apply. Can you confirm this?
>> Cheers,
>> Toni
>> CSGIS
>> Kolonnadenstraße 1
>> 04109 Leipzig
>> Mobil +49/ (0) 176 6680 3198
>> Tel +49/ (0) 341 24 04 738
>> Fax +49/ (0) 341 24 04 73
>> Web http://csgis.de
>> Hinweis gemäß § 33 BDSG
>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>> ausschließlich für den
>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>> diese E-Mail versehentlich
>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>> löschen Sie diese Nachricht
>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>> Vervielfältigung, Veränderung,
>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>> Am 04.01.2019 um 09:29 schrieb Dimitris Kar <dkarakostis at gmail.com>:
>> Hello Toni,
>> Thanks for the answer. After reinstalling everything in a fresh VM,
>> everything runs fine. I also made some tests editing the templates and
>> creating a contrib app and everything seems to be working. I am aware that
>> when using the geonode-project, its not recommended to edit/change the
>> geonode core but I was curious to try that. For some reason though when I
>> do minor changes on templates (/Envs/geonode/src/geonode), they are not
>> applied. Are you aware if this is the expected behavior?
>> Also I have checked your video on vimeo (
>> https://vimeo.com/278003647#t=37m37s). Great documentation!
>> On Wed, Jan 2, 2019 at 6:43 PM Toni Schönbuchner <
>>> Hi Dimitris,
>>> let me recap:
>>> IOError: [Errno 13] Permission denied: '/usr/local/share/GeoIP'
>>> This was solved by settings permissions of /usr/local/share
>>> And then when I run the paver sync or the paver start (as in the
>>> instructions), I get:
>>> django.db.utils.OperationalError: could not connect to server:
>>> Connection refused
>>> Is the server running on host "localhost" (127.0.0.1) and accepting
>>> TCP/IP connections on port 5432?
>>> Note, with dev setup there is neither tomcat nor postgresql involved.
>>> GeoServer is run by use of Jetty. Instead of Postgresql Setup we´re using
>>> Sqlite.
>>> So the error is here:
>>> DJANGO_SETTINGS_MODULE=wfp_geonode.local_settings
>>> You´re using local_settings which expects a running postgresql server.
>>> https://github.com/GeoNode/geonode-project/blob/master/project_name/local_settings.py.sample#L88
>>> Try:
>>> DJANGO_SETTINGS_MODULE=wfp_geonode.settings
>>> (settings instead of local_settings) instead.
>>> I am running the installation in a virtual environment inside a vagrant
>>> VM (ubuntu/xenial64). I thought it could be related with the port
>>> forwarding but that seems to be configured ok in the vagrantfile:
>>> config.vm.network :forwarded_port, guest: 5432, host: 5432
>>> This is totally fine. It would only matter when running in production.
>>> (Sqlite should not care about the port, in production I would further
>>> close 5432 and
>>> only connect by local_tunnel to postgres)
>>> I also tried to check the configuration in the pg_config file but I can
>>> not find out where my postgres is installed. I run: which psql but there is
>>> no output.
>>> Also only relevant with production setup. ;)
>>> On a different note, the installation comes with jetty server right?
>>> See above.
>>> As summary. You can use the dev setup with with django-dev-server, jetty
>>> and sqlite to quickly
>>> setup a environment for development. Going to production is much more
>>> complex as the different
>>> parts have to be configured. ( The docs explain how (a bit outdated but
>>> working.) I´ve created a little
>>> ansible playbook which automates those steps:
>>> https://github.com/csgis/geonode_ansible )
>>> Hope this helps,
>>> Toni
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190108/8331d77a/attachment.html>
More information about the geonode-devel
