[GeoNode-devel] Installing & configuring Geonode for production
Olivier Dalang olivier.dalang at gmail.com
Wed Jan 30 15:08:38 PST 2019
Did you consider this Docker setup :
https://github.com/GeoNode/geonode/tree/master/scripts/spcgeonode ?
It is meant to deploy Geonode for production is much easier than to
reconfigure everything from scratch.
Cheers,
Olivier
On Tue, Jan 29, 2019 at 9:26 AM Dimitris Karakostis <
karakostis.dimitris at gmail.com> wrote:
> I am following the instructions from here [1] to install Geonode 2.8 in a
> Vagrant machine (ubuntu 16.04). I manage to complete all the steps without
> any error but in the end of the installation & configuration process the
> geonode page is not accessible (localhost or localhost:8000). But I am able
> to access tomcat and geoserver (http://localhost:8080/geoserver/web/). I
> have also followed the steps from Toni's video [2] and I have made sure
> that I use the right user (in my case is "ubuntu" instead of "geo" or
> "vagrant"). Also I have deactivate the apache conf files (000-default.conf)
> and made sure to reload the server (sudo service apache2 reload).
> The error.log does't say a lot either:
> [Mon Jan 28 15:23:33.256516 2019] [mpm_event:notice] [pid 2648:tid
> 140573263873920] AH00491: caught SIGTERM, shutting down
> [Tue Jan 29 08:16:38.027075 2019] [wsgi:warn] [pid 1337:tid
> 140030881531776] mod_wsgi: Compiled for Python/2.7.11.
> [Tue Jan 29 08:16:38.028465 2019] [wsgi:warn] [pid 1337:tid
> 140030881531776] mod_wsgi: Runtime using Python/2.7.12.
> [Tue Jan 29 08:16:38.029659 2019] [mpm_event:notice] [pid 1337:tid
> 140030881531776] AH00489: Apache/2.4.18 (Ubuntu) mod_wsgi/4.3.0
> Python/2.7.12 configured -- resuming normal operations
> [Tue Jan 29 08:16:38.029684 2019] [core:notice] [pid 1337:tid
> 140030881531776] AH00094: Command line: '/usr/sbin/apache2'
> Any advice on how to debug this?
> [1]
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
> [2] https://vimeo.com/278003647#t=37m37s
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190131/deb6876e/attachment.html>
More information about the geonode-devel mailing list
