[GeoNode-devel] The "gsconfig" module thing!
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Jul 15 07:56:37 PDT 2019
https://github.com/GeoNode/geoserver-restconfig
Il giorno mer 10 lug 2019 alle ore 10:01 Francesco Bartoli <
xbartolone at gmail.com> ha scritto:
> Hi Alessio,
> +1 to host the new library on the GeoNode organization. Regarding the
> name, personally, I don’t like it since it cannot be well recognized from a
> pypi search and in theory might be useful beyond the scope of our project.
> Also do you think the new one should be backward compatible for py2? In
> case not then I would consider to use this library
> https://github.com/encode/http3, which would be a requests-compatible
> API, as building block for the new implementation.
> Ciao,
> Francesco
> Il 10 lug 2019, 09:38 +0200, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it>, ha scritto:
> Dear GeoNode devs, users,
> as you might already know, GeoNode relies on a python library, started by
> boundless several years ago, called "gsconfig", which basically handles
> almost all the APIs communication with GeoServer.
> Currently, the library seems to be abandoned and messed up.
> There are tentatives to make it compliant with Python 3, but the code is
> full of errors and they do not accept PRs anymore.
> With the latest versions of GeoServer, we need to update some API calls.
> Moreover, very soon, we will need to make this fundamental library
> compliant with Python 3.
> Probably the easiest way would be to fork this library and create a
> "gsconfig3" or something hosted by the GeoNode github repo.
> Any thoughts? Comments or feedbacks?
> Alessio.
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190715/1aaeba82/attachment-0001.html>
More information about the geonode-devel
