[GeoNode-devel] Python 3 / Django 2 Upgrade version naming and branch
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Mar 19 02:52:56 PDT 2019
Dear devs,
as the work on upgrading GeoNode 2.10 to Python 3 and Django 2 is moving
on, I would propose to:
1. Create a 2.10 branch which will be used for the next release still based
on Python 2; this branch will be stable and only major issues will be
backported until the release
2. Move "master" to 2.11; this will be the new development branch still
based on Python 2
3. Create a 2.20 branch which will be the development branch based on
Python3
Any objections? Ideas?
Regards,
Alessio.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190319/5eaf3bff/attachment.html>
More information about the geonode-devel mailing list
