[GeoNode-devel] geonode-devel Digest, Vol 50, Issue 23
Ahmed Osman
ahmednosman at cartologic.com
Tue Mar 19 12:59:24 PDT 2019
Dear Alessio
Maybe we can have 2.10 as the last release with Python 2 and moving forward
with 2.20 and higher with python 3
So there will be no 2.11
Just a thought
Regards
Ahmed
On Tue, Mar 19, 2019 at 6:35 PM <geonode-devel-request at lists.osgeo.org>
wrote:
> Send geonode-devel mailing list submissions to
> geonode-devel at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> geonode-devel-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of geonode-devel digest..."
> Today's Topics:
> 1. Re: Python 3 / Django 2 Upgrade version naming and branch
> (Francesco Bartoli)
> Message: 1
> Date: Tue, 19 Mar 2019 16:35:29 +0100
> From: Francesco Bartoli <xbartolone at gmail.com>
> To: Simone Giannecchini <simone.giannecchini at geo-solutions.it>,
> Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> Cc: geonode-devel <geonode-devel at lists.osgeo.org>
> Subject: Re: [GeoNode-devel] Python 3 / Django 2 Upgrade version
> naming and branch
> Message-ID: <39128641-1267-4d9f-a647-ab136294b031 at Spark>
> Content-Type: text/plain; charset="utf-8"
> Thanks Alessio for clarifications. Comments inline
> Il 19 mar 2019, 15:30 +0100, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it>, ha scritto:
> > Hello Simone and Francesco,
> > just to clarify a bit more, the idea would be to following one.
> > When we are ready to start the release process (**after** clean up and
> other preparation stuff we have already discussed at the meeting), the 2.10
> branch would become the new stable branch, where we backport only critical
> issues and/or features the community has tested enough (and that have a
> maintainer).
> > The 2.11 branch would become the Python 2 dev branch for a while until
> we definitively switch to Python 3. This because of people that installed
> 2.10, might still need to backport fixes without being forced to switch to
> Python 3 and Django 2.
> what about master during the phases?
> > In the meantime, we will align the branches with the 2.20 one, based on
> Python 3, and once we are ready to switch definitively, the next releases
> will be based on the latter.
> I’m a little bit concerned about this since potential incompatibilities
> would be likely as much as longer the release time of Python 3 will be. I
> believe the more we can cut 2.10 and 2.11 very close to the merge of PR for
> py3 into master the more we stay safe. Once that might happen then I would
> keep 2.11 just for fixing critical issues and master for new features
> > In parallel, hopefully, the work on GeoNode 3 will move on.
> > > Il giorno mar 19 mar 2019 alle ore 15:05 Simone Giannecchini <
> simone.giannecchini at geo-solutions.it> ha scritto:
> > > > Hi Alessio,
> > > > I fully agree that we should not pollute 2.10, however two things:
> > > > -1- it is not clear to me the plan for the two new branches. Are
> they expected to merge before 2.11 or after?
> > > > -2- Cutting 2.10 now could be too early as there is more clean up
> that we might want to do before releasing and this cut would generate a lot
> of work now to keep master and 2.10 branches aligned meanwhile.
> > > > It would probably be best to have the Python 3 development happen in
> parallel in a branch that tracks master and then merge on master at a
> certain point when the upgrade is ready or simply have the Python 3 branch
> become the new master.
> > > > I am also interested to hear what the others think.
> > > > Regards,
> > > > Simone.
> > > > > Il giorno mar 19 mar 2019 alle 10:03 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> ha scritto:
> > > > > > Dear devs,
> > > > > > as the work on upgrading GeoNode 2.10 to Python 3 and Django 2
> is moving on, I would propose to:
> > > > > > 1. Create a 2.10 branch which will be used for the next release
> still based on Python 2; this branch will be stable and only major issues
> will be backported until the release
> > > > > > 2. Move "master" to 2.11; this will be the new development
> branch still based on Python 2
> > > > > > 3. Create a 2.20 branch which will be the development branch
> based on Python3
> > > > > > Any objections? Ideas?
> > > > > > Regards,
> > > > > > Alessio.
> > > > > > GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> > > > > > Ing. Alessio Fabiani
> > > > > > @alfa7691
> > > > > > Founder/Technical Lead
> > > > > > GeoSolutions S.A.S.
> > > > > > Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> > > > > > phone: +39 0584 962313
> > > > > > fax: +39 0584 1660272
> > > > > > mob: +39 331 6233686
> > > > > > http://www.geo-solutions.it
> > > > > > http://twitter.com/geosolutions_it
> > > > > > Con riferimento alla normativa sul trattamento dei dati
> personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei
> dati “GDPR”), si precisa che ogni circostanza inerente alla presente email
> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
> conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente.
> Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni
> altra operazione è illecita. Le sarei comunque grato se potesse darmene
> notizia.
> > > > > > This email is intended only for the person or entity to which it
> is addressed and may contain information that is privileged, confidential
> or otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> > > > > > _______________________________________________
> > > > Regards,
> > > > Simone Giannecchini.
> > > > GeoSolutions Director
> > > > - sent from my mobile, apologies for brevity and typos-
> > @alfa7691
> > GeoSolutions S.A.S.
> > Con riferimento alla normativa sul trattamento dei dati personali (Reg.
> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> > This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190319/39152a03/attachment.html
> Subject: Digest Footer
> End of geonode-devel Digest, Vol 50, Issue 23
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190319/1f15fab3/attachment.html>
More information about the geonode-devel
