[GeoNode-devel] customizing web pages for GeoNode 2.8
Michael Härtel
haerta at haerta.de
Tue Mar 19 14:24:06 PDT 2019
Hello again,
Thank you for your hints but now as I read a few web pages and
instructions I believe that the DEV mode is not what I want.
* I don't want to customize GeoNode any further. I have to HTML files
which I simply want to be loaded to replace the standard two pages
* I have a production environment already. I don't want to mess around
with docker or break my python installation with the creation of a
virtualEnv (I don't know anything about python).
* I installed Geonode with apt-get install geonode and I doubt that
the setup of a dev environment on the prod server
Is there no way to overwrite the default pages without having to modify
the original source code? It must have worked for 2.6 but I have no idea
what made GeoNode to load the two files but I am pretty sure that it was
done by configuration without mofification of the urls.py
Any ideas?
Thank you very much,
Michael
On 19/03/2019 15:23, Toni Schönbuchner wrote:
> Hi Michael,
> how did you install 2.8?
> As Francesco already said for customisation you should use geonode
> project.
> Find here a good overview how to work with it:
> http://geonode.org/dev-workshop/
> In case you really want to change the core files ( and might run into
> problems on next update )
> you can of course integrate your static html files within the geonode
> core.
> You would put those into templates directory:
> https://github.com/GeoNode/geonode/tree/master/geonode/templates
> and change your urls.py to your needs:
> https://github.com/GeoNode/geonode/blob/master/geonode/urls.py#L61
> Again this is not advisable.
> Best regards,
> Toni
> CSGIS
> Kolonnadenstraße 1
> 04109 Leipzig
> Tel +49/ (0) 341 24 04 738
> Fax +49/ (0) 341 24 04 739
> Webhttp://csgis.de
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument
> ist ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>> Am 19.03.2019 um 15:05 schrieb geonode-devel-request at lists.osgeo.org
>> <mailto:geonode-devel-request at lists.osgeo.org>:
>> Message: 1
>> Date: Tue, 19 Mar 2019 12:22:13 +0100
>> From: Michael Härtel <haerta at haerta.de <mailto:haerta at haerta.de>>
>> To: Francesco Bartoli <xbartolone at gmail.com
>> <mailto:xbartolone at gmail.com>>,
>> geonode-devel at lists.osgeo.org <mailto:geonode-devel at lists.osgeo.org>
>> Subject: Re: [GeoNode-devel] customizing web pages for GeoNode 2.8
>> Message-ID: <01fd8f4d-0fa7-d02b-c028-d95c0a94cec0 at haerta.de
>> <mailto:01fd8f4d-0fa7-d02b-c028-d95c0a94cec0 at haerta.de>>
>> Content-Type: text/plain; charset="utf-8"; Format="flowed"
>> Thank you very much for the link but I am aware that is the recommended
>> way to customize the look & feel.
>> But since it was not necessary for the old installation to create such a
>> project I would also like to avoid these steps for the 2.8 installation
>> (if possible).
>> Regards,
>> Michael
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190319/7b14591b/attachment-0001.html>
More information about the geonode-devel
