[GeoNode-devel] I destroyed GeoNode 2.8 Django installation: How to re-install
Rizky Maulana Nugraha
rizky at kartoza.com
Thu Mar 21 01:09:56 PDT 2019
Hi Michael,
I assume you are working with development workflow, so you have the codebase.
In your codebase, there should be a file called “setup.py” and “requirements.txt”.
The requirements file contains python dependencies. You can install just the dependencies with:
pip install -r requirements.txt
Or, other options, you could include the codebase to your python library like this: (executed from the same folder as setup.py)
pip install -e .
This will install the codebase, and the dependencies in requirements.txt
Hope this helps
Regards,
Senior Software Engineer
Kartoza
> On 21 Mar 2019, at 07.16, Michael Härtel <haerta at haerta.de> wrote:
> Hello list,
> I destroyed my Django installation on my GeoNode 2.8 server when trying to add some python packages to build up my dev environment.
> Is there a way to re-install only the python setup without having to re-install the rest for GeoNode 2.8?
> Thank you very much,
> Michael
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190321/e3b29e73/attachment.html>
More information about the geonode-devel
