[GeoNode-devel] Python 3 / Django 2 Upgrade version naming and branch
Simone Giannecchini
simone.giannecchini at geo-solutions.it
Thu Mar 21 10:08:59 PDT 2019
Dear Angelos, Dear Jeremiah,
we discussed a bit internally and here is our proposal (that extends yours):
- We would want to cut branch 2.10 in proximity of the summit for doing the
release there. This release is for Python 2.
- The new master is open for merging the work on Python 3 once the work si
ready and reviewed. I would expect porting over the work will take a little
since it will have to undergo some review by the community. This would
become GeoNode 3.
Notice that there is some additional clean up that we might want to perform
before 2.10 based on feedback from clients on old things that don't work
properly (e.g. GeoNetwork integration) hence this is why we would want to
wait a little for 2.10 to be cut.
As far as the Python 3 work is concerned, with this plan Jeremiah you would
need to work on a fork that follow current master and then after 2.10 is
out we start the process to review and merge. We plan to help out with this
merge process, obviously, as this Python 3 upgrade is strategic.
Regards,
Simone Giannecchini
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 333 8128928
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
On Thu, Mar 21, 2019 at 6:02 PM Jeremiah Cooper <jcooper at jeremiahcooper.com>
wrote:
> +1 to the plan Angelos laid out. Makes sense to me.
> Thanks.
> Jeremiah Cooper
> On Thu, Mar 21, 2019 at 12:51 PM Angelos Tzotsos <gcpp.kalxas at gmail.com>
> wrote:
> > Hi all,
> > After some discussion on Gitter, here is another proposal:
> > 1. Create a 2.10.x branch to work on finalizing 2.10 release
> > 2. Move master to version 2.99 and start merging work related to Python
> 3 and Django 2 which will become GeoNode 3.0 (easier to communicate to
> users and organizations). GeoNode 3.0 will be Python 3 only.
> > 3. Anything related to Python 2 stays on GeoNode 2.x and we leave room
> for potential 2.12 release after some time if needed.
> > 4. Future plans for GeoNode, like work on geonode-api and separation of
> UI etc can then become GeoNode 4.0 which probably will be a re-write. This
> also is lines up with CSW 4.0 version number which will be based on OpenAPI
> and new OGC OWS direction.
> > Thoughts?
> > Cheers,
> > Angelos
> > On 3/19/19 11:52 AM, Alessio Fabiani wrote:
> > Dear devs,
> > as the work on upgrading GeoNode 2.10 to Python 3 and Django 2 is moving
> > on, I would propose to:
> > 1. Create a 2.10 branch which will be used for the next release still
> based
> > on Python 2; this branch will be stable and only major issues will be
> > backported until the release
> > 2. Move "master" to 2.11; this will be the new development branch still
> > based on Python 2
> > 3. Create a 2.20 branch which will be the development branch based on
> > Python3
> > Any objections? Ideas?
> > Regards,
> > Alessio.
> > geonode-devel mailing list
> > geonode-devel at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/geonode-devel
> > Angelos Tzotsos, PhD
> > Charter Member
> > Open Source Geospatial Foundation
> > http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190321/918cf9d1/attachment.html>
More information about the geonode-devel
