[GeoNode-devel] Layer Upload doesn't work in GeoNode 2.8.1rc0: "AttributeError at /layers/upload 'NoneType' object has no attribute 'charset'"
Michael Härtel
haerta at haerta.de
Thu May 16 05:49:52 PDT 2019
Hello Alessio, list
I tried to incorporate your changes. I followed these steps:
* Downloaded "geonode-ISSUE_-4401.zip" from github
* unpacked the contents of the ZIP file to
"/home/geo/Envs/geonode/src/geonode" (I followed the instructions
from this
<http://docs.geonode.org/en/latest/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
link to set up geonode).
* Deleted all pyc files in /home/geo
* restarted apache
What I get is this error. Strange enough is that I get same error when I
roll back the changes (copy the backup folder back to
/home/geo/Envs/geonode/src/geonode).
[Thu May 16 13:42:42.686733 2019] [wsgi:error] [pid 22537] [remote
172.30.1.13:41727] mod_wsgi (pid=22537): Exception occurred processing
WSGI script '/home/geonode/my_geonode/my_geonode/wsgi.py'.
[Thu May 16 13:42:42.686885 2019] [wsgi:error] [pid 22537] [remote
172.30.1.13:41727] Traceback (most recent call last):
[Thu May 16 13:42:42.687030 2019] [wsgi:error] [pid 22537] [remote
172.30.1.13:41727] File "/home/geonode/my_geonode/my_geonode/wsgi.py",
line 44, in <module>
[Thu May 16 13:42:42.687205 2019] [wsgi:error] [pid 22537] [remote
172.30.1.13:41727] application = get_wsgi_application()
[Thu May 16 13:42:42.687284 2019] [wsgi:error] [pid 22537] [remote
"/home/geo/Envs/geonode/lib/python2.7/site-packages/django/core/wsgi.py",
line 14, in get_wsgi_application
[Thu May 16 13:42:42.687425 2019] [wsgi:error] [pid 22537] [remote
172.30.1.13:41727] django.setup()
[Thu May 16 13:42:42.687541 2019] [wsgi:error] [pid 22537] [remote
"/home/geo/Envs/geonode/lib/python2.7/site-packages/django/__init__.py",
line 17, in setup
[Thu May 16 13:42:42.687677 2019] [wsgi:error] [pid 22537] [remote
172.30.1.13:41727] configure_logging(settings.LOGGING_CONFIG,
settings.LOGGING)
[Thu May 16 13:42:42.687777 2019] [wsgi:error] [pid 22537] [remote
"/home/geo/Envs/geonode/lib/python2.7/site-packages/django/conf/__init__.py",
line 48, in __getattr__
[Thu May 16 13:42:42.687964 2019] [wsgi:error] [pid 22537] [remote
172.30.1.13:41727] self._setup(name)
[Thu May 16 13:42:42.688062 2019] [wsgi:error] [pid 22537] [remote
line 44, in _setup
[Thu May 16 13:42:42.688154 2019] [wsgi:error] [pid 22537] [remote
172.30.1.13:41727] self._wrapped = Settings(settings_module)
[Thu May 16 13:42:42.688237 2019] [wsgi:error] [pid 22537] [remote
line 92, in __init__
[Thu May 16 13:42:42.688322 2019] [wsgi:error] [pid 22537] [remote
172.30.1.13:41727] mod = importlib.import_module(self.SETTINGS_MODULE)
[Thu May 16 13:42:42.688395 2019] [wsgi:error] [pid 22537] [remote
172.30.1.13:41727] File "/usr/lib/python2.7/importlib/__init__.py",
line 37, in import_module
[Thu May 16 13:42:42.688510 2019] [wsgi:error] [pid 22537] [remote
172.30.1.13:41727] __import__(name)
[Thu May 16 13:42:42.688585 2019] [wsgi:error] [pid 22537] [remote
"/home/geonode/my_geonode/my_geonode/settings.py", line 30, in <module>
[Thu May 16 13:42:42.688709 2019] [wsgi:error] [pid 22537] [remote
172.30.1.13:41727] from geonode.settings import *
[Thu May 16 13:42:42.688799 2019] [wsgi:error] [pid 22537] [remote
172.30.1.13:41727] ImportError: No module named geonode.settings
I blieve I lack some basic understanding here. Can you help?
Thank you very much,
Michael
On 16/05/2019 12:44, Michael Härtel wrote:
> Hello Alessio,
> thank you very much for your efforts. I will give it a try.
> Just 10 minutes ago I set up a local VM with 2.10 rc5 and I can
> confirm that the layer uploads works perfectly for me with the
> included geoserver 2.14.2.
> (What I noted is that the admin link to geoserver from within geonode
> didn't work in DEV mode (paver start): The url it points to is
> "http://localhost:8000/gs/" but I get a 404 (see output below). This
> isn't a big problem because I don't intend to use DEV mode at all. I
> also didn't examine this issue yet.)
> Thanks again, I will try to fix my 2.8.1 version and keep you informed
> Regards,
> Michael
> output from geonode after click on geoserver link in admin menu:
> Page not found (404)
> Request Method: GET
> Request URL: http://localhost:8000/gs/
> Using the URLconf defined in geonode.urls, Django tried these URL
> patterns, in this order:
> ^$ [name='home']
> ^help/$ [name='help']
> ^developer/$ [name='developer']
> ^about/$ [name='about']
> ^privacy_cookies/$ [name='privacy-cookies']
> ^layers/
> ^maps/
> ^catalogue/
> ^data.json$ [name='data_json']
> ^ident.json$ [name='ident_json']
> ^h_keywords_api$ [name='h_keywords_api']
> ^search/$ [name='search']
> ^account/
> ^invitations/
> ^people/
> ^avatar/
> ^comments/
> ^ratings/
> ^activity/
> ^announcements/
> ^messages/
> ^social/
> ^security/
> ^account/ajax_login$ [name='account_ajax_login']
> ^account/ajax_lookup$ [name='account_ajax_lookup']
> ^account/moderation_sent/(?P<inactive_user>[^/]*)$
> [name='moderator_contacted']
> ^lang\.js$ [name='lang']
> ^jsi18n/$ [name='javascript-catalog']
> ^sitemap\.xml$ [name='sitemap']
> ^robots\.txt$ [name='robots']
> ^autocomplete/
> ^groups/
> ^documents/
> ^services/
> ^o/
> ^api/o/v4/tokeninfo [name='tokeninfo']
> ^api/o/v4/userinfo [name='userinfo']
> ^api/roles [name='roles']
> ^api/adminRole [name='adminRole']
> ^api/users [name='users']
> ^(?P<api_name>api)/$ [name='api_api_top_level']
> ^(?P<api_name>api)/
> ^(?P<api_name>api)/
> ^(?P<api_name>api)/
> ^(?P<api_name>api)/
> ^(?P<api_name>api)/
> ^(?P<api_name>api)/
> ^(?P<api_name>api)/
> ^(?P<api_name>api)/
> ^(?P<api_name>api)/
> ^(?P<api_name>api)/
> ^(?P<api_name>api)/
> ^(?P<api_name>api)/
> ^(?P<api_name>api)/
> ^(?P<api_name>api)/
> ^en/
> ^i18n/
> ^showmetadata/
> ^upload/
> ^capabilities/layer/(?P<layerid>\d+)/$ [name='capabilities_layer']
> ^capabilities/map/(?P<mapid>\d+)/$ [name='capabilities_map']
> ^capabilities/user/(?P<user>[\w. at +-]+)/$ [name='capabilities_user']
> ^capabilities/category/(?P<category>\w+)/$
> [name='capabilities_category']
> ^gs/ ^rest/stores/(?P<store_type>\w+)/$ [name='stores']
> ^gs/ ^rest/styles
> ^gs/ ^rest/workspaces
> ^gs/ ^rest/workspaces/(?P<workspace>\w+)/styles
> ^gs/ ^rest/layers
> ^gs/ ^rest/imports
> ^gs/ ^rest/sldservice
> ^gs/ ^ows [name='ows_endpoint']
> ^gs/ ^gwc [name='gwc_endpoint']
> ^gs/ ^wms [name='wms_endpoint']
> ^gs/ ^wfs [name='wfs_endpoint']
> ^gs/ ^wcs [name='wcs_endpoint']
> ^gs/ ^wps [name='wps_endpoint']
> ^gs/ ^pdf [name='pdf_endpoint']
> ^gs/ ^(?P<workspace>[^/]*)/(?P<layername>[^/]*)/ows
> ^gs/ ^(?P<workspace>[^/]*)/(?P<layername>[^/]*)/wms
> ^gs/ ^(?P<workspace>[^/]*)/(?P<layername>[^/]*)/wfs
> ^gs/ ^(?P<workspace>[^/]*)/(?P<layername>[^/]*)/wcs
> ^gs/ ^updatelayers/$ [name='updatelayers']
> ^gs/ ^(?P<layername>[^/]*)/style$ [name='layer_style']
> ^gs/ ^(?P<layername>[^/]*)/style/upload$ [name='layer_style_upload']
> ^gs/ ^(?P<layername>[^/]*)/style/manage$ [name='layer_style_manage']
> ^gs/ ^(?P<layername>[^/]*)/edit-check?$ [name='feature_edit_check']
> ^gs/ ^(?P<layername>[^/]*)/style-check?$ [name='style_edit_check']
> ^gs/ ^acls/?$ [name='layer_acls']
> ^gs/ ^resolve_user/?$ [name='layer_resolve_user']
> ^gs/ ^download$ [name='layer_batch_download']
> ^gs/ ^online/?$ [name='server_online']
> ^notifications/
> ^ ^api/ows_endpoints/
> ^proxy/ [name='proxy']
> ^download/(?P<resourceid>[^/]*)$ [name='download']
> ^static\/(?P<path>.*)$
> ^uploaded\/(?P<path>.*)$
> ^featured/(?P<site>[A-Za-z0-9_\-]+)/$
> ^featured/(?P<site>[A-Za-z0-9_\-]+)/info$
> The current path, gs/, didn't match any of these.
> You're seeing this error because you have DEBUG = True in your Django
> settings file. Change that to False, and Django will display a
> standard 404 page.
> On 16/05/2019 11:49, Alessio Fabiani wrote:
>> Dear Michael,
>> fwi I did a PR [1] backporting most of the fixes currently available
>> on 2.10
>> Once this will be merged, you will need to update the GeoNode 2.8
>> code base accordingly and run again migrations and collectstatic
>> commands.
>> [1] - https://github.com/GeoNode/geonode/pull/4402
>> Il giorno lun 6 mag 2019 alle ore 22:36 Michael Härtel
>> <haerta at haerta.de <mailto:haerta at haerta.de>> ha scritto:
>> Hello Alessio,
>> I installed mod_security and was able to produce more information
>> by capturing the POST data. I attached the logfile to this mail.
>> Michael
>> On 06/05/2019 10:00, Alessio Fabiani wrote:
>>> Hello Michael,
>>> I'm going to do some checks on 2.8 branches and probably
>>> backport some fixes in the next few days.
>>> I'll keep you posted about that.
>>> Alessio.
>>> Il giorno sab 4 mag 2019 alle ore 00:08 Michael Härtel
>>> Hello List,
>>> I followed the instructions from here to install geonode:
>>> Despite the fact that the url to Geonode from the tutorial
>>> ("--template=https://github.com/GeoNode/geonode-project/archive/2.8.0.zip")
>>> is not available and I had a hard time to find a URL that
>>> worked for me (I used the ZIP from GIT/2.8.x branch), I
>>> eventuelly got everything working apart from the layer upload.
>>> I have no idea, how to debug this issue:
>>> * The apache error.log does not show any entry.
>>> * The apache access.log only shows an error 500
>>> * The database doesn't show any relevant entry
>>> * GeoServer doesn't show any relevant entry (Even with
>>> VERBODE logging).
>>> It seems that the file never reaches the server so the
>>> "saved_layer" variable is empty/none/null (I am not a Python
>>> programmer) in line 294 of
>>> "/home/geo/Envs/geonode/src/geonode/geonode/layers/views.py"
>>> Where is the relevant configuration?
>>> * the directory and sub directories of
>>> "/home/geonode/my_geonode/my_geonode/uploaded" has
>>> correct permissions (even tested with "chmod -R ugo+rwx
>>> * the apache file
>>> /etc/apache2/sites-available/geonode.conf has correct
>>> entries:
>>> Alias /uploaded/
>>> /home/geonode/my_geonode/my_geonode/uploaded/
>>> <Directory
>>> "/home/geonode/my_geonode/my_geonode/uploaded/layers/">
>>> Is there anyone who can tell me what else to check or how to
>>> debug this issue?
>>> When I select some shape files and click "upload files", the
>>> DEBUG output on the web page looks like this:
>>> attribute 'charset' Request Method: POST Request URL:
>>> http://geoportal.dummy.org/layers/upload Django Version:
>>> 1.8.19 Python Executable: /usr/bin/python Python Version:
>>> 2.7.12 Python Path: ['/home/geonode/my_geonode',
>>> '/home/geo/Envs/geonode/lib/python2.7/site-packages',
>>> '/home/geo/Envs/geonode/src/geonode',
>>> '/home/dummygeonode/my_geonode', '/usr/lib/python2.7',
>>> '/usr/lib/python2.7/plat-x86_64-linux-gnu',
>>> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
>>> '/usr/lib/python2.7/lib-dynload',
>>> '/usr/local/lib/python2.7/dist-packages',
>>> '/usr/lib/python2.7/dist-packages',
>>> '/usr/lib/python2.7/dist-packages/PILcompat', '/var/www',
>>> '/var/www'] Server time: Fri, 3 May 2019 21:36:06 +0000
>>> Installed Applications: ('modeltranslation',
>>> 'django.contrib.auth', 'django.contrib.contenttypes',
>>> 'django.contrib.sessions', 'django.contrib.sites',
>>> 'django.contrib.admin', 'django.contrib.sitemaps',
>>> 'django.contrib.staticfiles', 'django.contrib.messages',
>>> 'django.contrib.humanize', 'django.contrib.gis',
>>> 'dj_pagination', 'taggit', 'treebeard', 'geoexplorer',
>>> 'leaflet', 'bootstrap3_datetime', 'django_extensions',
>>> 'django_basic_auth', 'autocomplete_light', 'mptt',
>>> 'storages', 'floppyforms', 'pinax_theme_bootstrap',
>>> 'django_forms_bootstrap', 'avatar', 'dialogos',
>>> 'agon_ratings', 'announcements', 'actstream',
>>> 'user_messages', 'tastypie', 'polymorphic', 'guardian',
>>> 'oauth2_provider', 'corsheaders', 'invitations', 'allauth',
>>> 'allauth.account', 'allauth.socialaccount',
>>> 'rest_framework', 'geonode', 'geonode.api', 'geonode.base',
>>> 'geonode.layers', 'geonode.maps', 'geonode.documents',
>>> 'geonode.security', 'geonode.catalogue', 'geonode.people',
>>> 'geonode.client', 'geonode.themes', 'geonode.proxy',
>>> 'geonode.social', 'geonode.groups', 'geonode.services',
>>> 'geonode.geoserver', 'geonode.upload', 'geonode.tasks',
>>> 'geonode.messaging', 'geonode.contrib.metadataxsl',
>>> 'geonode.contrib.api_basemaps', 'geonode.contrib.ows_api',
>>> 'pinax.notifications', 'geonode.contrib.monitoring',
>>> 'my_geonode', , ) Installed Middleware:
>>> ('corsheaders.middleware.CorsMiddleware',
>>> 'django.middleware.common.CommonMiddleware',
>>> 'django.contrib.sessions.middleware.SessionMiddleware',
>>> 'django.contrib.messages.middleware.MessageMiddleware',
>>> 'dj_pagination.middleware.PaginationMiddleware',
>>> 'django.middleware.locale.LocaleMiddleware',
>>> 'django.middleware.csrf.CsrfViewMiddleware',
>>> 'django.contrib.auth.middleware.AuthenticationMiddleware',
>>> 'django.middleware.clickjacking.XFrameOptionsMiddleware',
>>> 'django.middleware.security.SecurityMiddleware',
>>> 'django.contrib.auth.middleware.SessionAuthenticationMiddleware',
>>> 'oauth2_provider.middleware.OAuth2TokenMiddleware',
>>> 'geonode.contrib.monitoring.middleware.MonitoringMiddleware')
>>> Traceback: File
>>> "/home/geo/Envs/geonode/lib/python2.7/site-packages/django/core/handlers/base.py"
>>> in get_response 132. response = wrapped_callback(request,
>>> *callback_args, **callback_kwargs) File
>>> "/home/geo/Envs/geonode/lib/python2.7/site-packages/django/contrib/auth/decorators.py"
>>> in _wrapped_view 22. return view_func(request, *args,
>>> **kwargs) File
>>> in layer_upload 294. out[_k] =
>>> out[_k].decode(saved_layer.charset).encode("utf-8")
>>> Exception Type: AttributeError at /layers/upload Exception
>>> Value: 'NoneType' object has no attribute 'charset' Request
>>> information: GET: No GET data POST: charset = u'UTF-8'
>>> permissions =
>>> u'{"users":{"AnonymousUser":["view_resourcebase","download_resourcebase"]},"groups":{}}'
>>> FILES: shx_file = base_file = shp_file = dbf_file = prj_file
>>> = COOKIES: csrftoken = 'RCPSALmmUm4LV9RF7wWzsqxGFfdK1XDn'
>>> sessionid = 'h0bcxlw4nutyik4kb63ao9d3pzxud6hq' _ga =
>>> 'GA1.2.1615965258.1556718183' META: mod_wsgi.listener_port =
>>> '80' HTTP_REFERER =
>>> 'http://geoportal.dummy.org/layers/upload'
>>> mod_wsgi.listener_host = '' HTTP_REVERSE_VIA = 'IPGW2'
>>> CONTEXT_DOCUMENT_ROOT =
>>> '/home/geonode/my_geonode/my_geonode' SERVER_SOFTWARE =
>>> 'Apache/2.4.18 (Ubuntu)' SCRIPT_NAME = u''
>>> mod_wsgi.enable_sendfile = '0' HTTP_X_CSRFTOKEN =
>>> 'RCPSALmmUm4LV9RF7wWzsqxGFfdK1XDn' SERVER_SIGNATURE = '
>>> Apache/2.4.18 (Ubuntu) Server at geoportal.dummy.org
>>> <http://geoportal.dummy.org> Port 80
>>> \n' REQUEST_METHOD = 'POST' PATH_INFO = u'/layers/upload'
>>> SERVER_PROTOCOL = 'HTTP/1.1' QUERY_STRING = ''
>>> CONTENT_LENGTH = '4451' HTTP_USER_AGENT = 'Mozilla/5.0
>>> (Windows NT 10.0; Win64; x64; rv:66.0) Gecko/20100101
>>> Firefox/66.0' HTTP_CONNECTION = 'Keep-Alive' HTTP_COOKIE =
>>> 'csrftoken=RCPSALmmUm4LV9RF7wWzsqxGFfdK1XDn;
>>> _ga=GA1.2.1615965258.1556718183;
>>> sessionid=h0bcxlw4nutyik4kb63ao9d3pzxud6hq' SERVER_NAME =
>>> 'geoportal.dummy.org <http://geoportal.dummy.org>'
>>> REMOTE_ADDR = '172.30.1.13' mod_wsgi.handler_script = ''
>>> mod_wsgi.request_handler = 'wsgi-script' apache.version =
>>> wsgi.url_scheme = 'http' PATH_TRANSLATED =
>>> '/home/geonode/my_geonode/my_geonode/wsgi.py/layers/upload
>>> <http://wsgi.py/layers/upload>' SERVER_PORT = '80'
>>> mod_wsgi.queue_start = '1556919366052407' wsgi.multiprocess
>>> = True mod_wsgi.input_chunked = '0' SERVER_ADDR =
>>> '172.30.1.167' DOCUMENT_ROOT =
>>> '/home/geonode/my_geonode/my_geonode' mod_wsgi.process_group
>>> = 'geonode' HTTP_X_REQUESTED_WITH = 'XMLHttpRequest'
>>> mod_wsgi.daemon_connects = '1' SCRIPT_FILENAME =
>>> '/home/geonode/my_geonode/my_geonode/wsgi.py' SERVER_ADMIN =
>>> 'webmaster at localhost' wsgi.input = HTTP_HOST =
>>> CONTEXT_PREFIX = '' wsgi.multithread = True
>>> mod_wsgi.callable_object = 'application'
>>> mod_wsgi.daemon_restarts = '0' REQUEST_URI =
>>> '/layers/upload' HTTP_ACCEPT = '*/*' wsgi.file_wrapper = ''
>>> wsgi.version = GATEWAY_INTERFACE = 'CGI/1.1' wsgi.run_once =
>>> False wsgi.errors = REMOTE_PORT = '25591'
>>> HTTP_ACCEPT_LANGUAGE = 'en-GB,en;q=0.5' REQUEST_SCHEME =
>>> 'http' mod_wsgi.version = mod_wsgi.script_start =
>>> '1556919366052600' CONTENT_TYPE = 'multipart/form-data;
>>> boundary=---------------------------75853149526340'
>>> mod_wsgi.application_group = 'geoportal.cgiarad.org
>>> <http://geoportal.cgiarad.org>|' mod_wsgi.script_reloading =
>>> '1' mod_wsgi.request_start = '1556919366052122' CSRF_COOKIE
>>> = u'RCPSALmmUm4LV9RF7wWzsqxGFfdK1XDn' mod_wsgi.daemon_start
>>> = '1556919366052568' Settings: Using settings module
>>> my_geonode.settings BROKER_TRANSPORT_OPTIONS =
>>> {'fanout_prefix': True, 'fanout_patterns': True,
>>> 'visibility_timeout': 86400, 'socket_timeout': 60}
>>> EMAIL_USE_TLS = False CELERY_SEND_TASK_SENT_EVENT = True
>>> DOWNLOAD_FORMATS_METADATA = ['Atom', 'DIF', 'Dublin Core',
>>> 'ebRIM', 'FGDC', 'ISO', 'ISO with XSL'] SESSION_SERIALIZER =
>>> 'django.contrib.sessions.serializers.PickleSerializer'
>>> ACCOUNT_EMAIL_REQUIRED = True OGC_SERVER_DEFAULT_USER =
>>> 'admin' MESSAGE_STORAGE =
>>> 'django.contrib.messages.storage.fallback.FallbackStorage'
>>> WSGI_APPLICATION = 'my_geonode.wsgi.application'
>>> SESSION_COOKIE_NAME = 'sessionid' CELERY_BROKER_URL =
>>> 'memory://' VERSION = '2.8.1rc0' AWS_BUCKET_NAME = ''
>>> ACCOUNT_CONFIRM_EMAIL_ON_GET = True EMAIL_SSL_KEYFILE =
>>> u'********************' SERVER_EMAIL = 'root at localhost'
>>> ACCOUNT_EMAIL_VERIFICATION = 'optional' FIRST_DAY_OF_WEEK =
>>> 0 CACHES = {'default': {'BACKEND':
>>> 'django.core.cache.backends.dummy.DummyCache'}} CKAN_ORIGINS
>>> = [{'url':
>>> 'https://data.hdx.rwlabs.org/dataset/new?title={name}&dataset_date={date}¬es={abstract}&caveats={caveats}',
>>> 'css_class': 'hdx', 'label': 'Humanitarian Data Exchange
>>> (HDX)'}] SESSION_COOKIE_PATH = '/' UNOCONV_ENABLE = 1
>>> MISSING_THUMBNAIL = 'geonode/img/missing_thumb.png'
>>> MODELTRANSLATION_FALLBACK_LANGUAGES = 'en'
>>> PINAX_NOTIFICATIONS_HOOKSET = CELERY_TASK_IGNORE_RESULT =
>>> True DEFAULT_INDEX_TABLESPACE = '' MONITORING_HOST_NAME =
>>> 'localhost' THESAURI = [] USE_X_FORWARDED_HOST = False
>>> TWITTER_HASHTAGS = ['geonode'] PUBLIC_GEOSERVER = {'source':
>>> {'url': 'http://localhost:8080/geoserver/ows', 'restUrl':
>>> '/gs/rest', 'attribution': '© http://localhost:8000/',
>>> 'ptype': 'gxp_wmscsource', 'title': 'GeoServer - Public
>>> Layers'}} GUARDIAN_GET_INIT_ANONYMOUS_USER =
>>> 'geonode.people.models.get_anonymous_user_instance'
>>> CSRF_COOKIE_DOMAIN = None FILE_CHARSET = 'utf-8' DEBUG =
>>> True SESSION_FILE_PATH = None DISPLAY_COMMENTS = 1
>>> DATABASE_ENGINE = 'postgresql_psycopg2' STATICFILES_DIRS =
>>> ['/etc/geonode/media',
>>> '/home/geo/Envs/geonode/src/geonode/geonode/static',
>>> '/home/geonode/my_geonode/my_geonode/static']
>>> CELERY_TASK_CREATE_MISSING_QUEUES = True
>>> SECURE_PROXY_SSL_HEADER = None AWS_SECRET_ACCESS_KEY =
>>> u'********************' DEBUG_PROPAGATE_EXCEPTIONS = False
>>> MONTH_DAY_FORMAT = 'F j' SEARCH_FILTERS = {'REGION_ENABLED':
>>> True, 'EXTENT_ENABLED': True, 'DATE_ENABLED': True,
>>> 'KEYWORDS_ENABLED': u'********************',
>>> 'CATEGORIES_ENABLED': True, 'TYPE_ENABLED': True,
>>> 'T_KEYWORDS_ENABLED': u'********************',
>>> 'OWNERS_ENABLED': True, 'H_KEYWORDS_ENABLED':
>>> u'********************', 'TEXT_ENABLED': True}
>>> THUMBNAIL_GENERATOR =
>>> 'geonode.layers.utils.create_gs_thumbnail_geonode'
>>> AUTH_USER_MODEL = 'people.Profile' USE_THOUSAND_SEPARATOR =
>>> False UNOCONV_TIMEOUT = 30 CELERY_DISABLE_RATE_LIMITS =
>>> False CSRF_FAILURE_VIEW = 'django.views.csrf.csrf_failure'
>>> CELERY_WORKER_SEND_TASK_EVENTS = True CELERY_TASK_SERIALIZER
>>> = 'json' DECIMAL_SEPARATOR = '.' IGNORABLE_404_URLS =
>>> NOSE_ARGS = ['--nocapture', '--detailed-errors']
>>> TEMPLATE_STRING_IF_INVALID = '' FIXTURE_DIRS =
>>> SOCIALACCOUNT_AUTO_SIGNUP = False
>>> PINAX_NOTIFICATIONS_BACKENDS = {(0, 'email'): }
>>> FORMAT_MODULE_PATH = None ALLOWED_DOCUMENT_TYPES = ['doc',
>>> 'docx', 'gif', 'jpg', 'jpeg', 'ods', 'odt', 'odp', 'pdf',
>>> 'png', 'ppt', 'pptx', 'rar', 'sld', 'tif', 'tiff', 'txt',
>>> 'xls', 'xlsx', 'xml', 'zip', 'gz', 'qml']
>>> RESOURCE_PUBLISHING = False DISALLOWED_USER_AGENTS =
>>> DEFAULT_LAYER_FORMAT = 'image/png' THUNDERFOREST_BASEMAPS =
>>> False CELERY_REDIRECT_STDOUTS = True SITENAME = 'my_geonode'
>>> CELERY_MESSAGE_COMPRESSION = 'gzip' USE_ETAGS = False
>>> DISPLAY_WMS_LINKS = True GEOTIFF_IO_ENABLED = 0
>>> PINAX_NOTIFICATIONS_GET_LANGUAGE_MODEL = at 0x7f8c98343c80>
>>> USE_TZ = True SHORT_DATETIME_FORMAT = 'm/d/Y P'
>>> LANGUAGE_COOKIE_PATH = '/' MAX_DOCUMENT_SIZE = 2
>>> YEAR_MONTH_FORMAT = 'F Y' AWS_QUERYSTRING_AUTH = False
>>> CELERY_SEND_TASK_EVENTS = True LANGUAGE_CODE = 'en'
>>> ROOT_URLCONF = 'my_geonode.urls' LOGIN_URL =
>>> '/account/login/' DEFAULT_MAP_CENTER = DATABASE_HOST =
>>> 'localhost' TEMPLATE_DIRS = BROKER_HEARTBEAT = 0
>>> SESSION_CACHE_ALIAS = 'default' SESSION_COOKIE_DOMAIN = None
>>> PINAX_NOTIFICATIONS_QUEUE_ALL = False
>>> FILE_UPLOAD_PERMISSIONS = None BING_API_KEY =
>>> u'********************' APPEND_SLASH = True DATABASE_ROUTERS
>>> = [] STAMEN_BASEMAPS = False GEOSERVER_LOCATION =
>>> 'http://localhost/geoserver/' INVITATIONS_ADAPTER =
>>> 'geonode.people.adapters.LocalAccountAdapter' HOSTNAME =
>>> 'localhost' EXIF_ENABLED = False CATALOGUE = {'default':
>>> {'ENGINE': 'geonode.catalogue.backends.pycsw_local', 'URL':
>>> 'http://geoportal.dummy.org/catalogue/csw'}}
>>> LOCKDOWN_GEONODE = 0 MIDDLEWARE_CLASSES = USE_I18N = 1
>>> LANGUAGE_COOKIE_NAME = 'django_language'
>>> CELERY_TASK_ALWAYS_EAGER = True TEST_RUNNER_PARALLEL = 0
>>> CELERYD_HIJACK_ROOT_LOGGER = True HAYSTACK_SEARCH = 0
>>> X_FRAME_OPTIONS = 'DENY' UNOCONV_EXECUTABLE =
>>> '/usr/bin/unoconv' OAUTH2_PROVIDER = {'SCOPES': {'read':
>>> 'Read scope', 'write': 'Write scope', 'groups': 'Access to
>>> your groups'}, 'CLIENT_ID_GENERATOR_CLASS':
>>> 'oauth2_provider.generators.ClientIdGenerator'}
>>> GEOSERVER_PUBLIC_LOCATION =
>>> 'http://geoportal.dummy.org/geoserver/' SECURE_SSL_HOST =
>>> None NLP_ENABLED = False MONITORING_DISABLE_CSRF = False
>>> SOCIAL_ORIGINS = [{'url':
>>> 'mailto:?subject={name}&body={url}', 'css_class': 'email',
>>> 'label': 'Email'}, {'url':
>>> 'http://www.facebook.com/sharer.php?u={url}', 'css_class':
>>> 'fb', 'label': 'Facebook'}, {'url':
>>> 'https://twitter.com/share?url={url}&hashtags={hashtags}',
>>> 'css_class': 'tw', 'label': 'Twitter'}, {'url':
>>> 'https://plus.google.com/share?url={url}', 'css_class':
>>> 'gp', 'label': 'Google +'}] PREPEND_WWW = False
>>> AUTH_IP_WHITELIST = [] DATABASE_PORT = '5432'
>>> DEFAULT_ANONYMOUS_VIEW_PERMISSION = 1 GOOGLE_API_KEY =
>>> u'********************' GEOIP_PATH =
>>> '/usr/local/share/GeoIP' ADMIN_MODERATE_UPLOADS = False
>>> TASTYPIE_DEFAULT_FORMATS = ['json']
>>> DEFAULT_ANONYMOUS_DOWNLOAD_PERMISSION = 1 FORCE_SCRIPT_NAME
>>> = None DISPLAY_RATINGS = 1 TEST_RUNNER_KEEPDB = 0
>>> PASSWORD_RESET_TIMEOUT_DAYS = u'********************'
>>> DEFAULT_SEARCH_SIZE = 10 CELERYD_CONCURENCY = 1
>>> SESSION_ENGINE = 'django.contrib.sessions.backends.db'
>>> API_INCLUDE_REGIONS_COUNT = u'********************'
>>> PINAX_NOTIFICATIONS_LOCK_WAIT_TIMEOUT = -1 MIGRATION_MODULES
>>> = {} NLP_MODEL_PATH =
>>> '/opt/MITIE/MITIE-models/english/ner_model.dat'
>>> PROXY_ALLOWED_HOSTS = ['geoportal.dummy.org
>>> <http://geoportal.dummy.org>', 'geoportal.cgiarad.org
>>> <http://geoportal.cgiarad.org>', '172.30.1.167',
>>> 'localhost'] CARTODB_BASEMAPS = False
>>> SECURE_BROWSER_XSS_FILTER = True GEONODE_CONTRIB_APPS = SRID
>>> = {'DETAIL': 'never'} ACCOUNT_NOTIFY_ON_PASSWORD_CHANGE =
>>> u'********************' AGON_RATINGS_CATEGORY_CHOICES =
>>> {'maps.Map': {'map': 'How good is this map?'},
>>> 'layers.Layer': {'layer': 'How good is this layer?'},
>>> 'documents.Document': {'document': 'How good is this
>>> document?'}} DEFAULT_EXCEPTION_REPORTER_FILTER =
>>> 'django.views.debug.SafeExceptionReporterFilter' ADMINS = []
>>> MONITORING_DATA_TTL = datetime.timedelta(7)
>>> GEOSERVER_EXCHANGE = CELERY_ACCEPT_CONTENT = ['json']
>>> LOCAL_MEDIA_URL = '/uploaded/' LOGOUT_URL =
>>> '/account/logout/' USE_GEOSERVER = True EXTRA_LANG_INFO =
>>> {'tl': {'code': 'tl', 'name': 'Tagalog', 'bidi': False,
>>> 'name_local': 'tagalog'}, 'am': {'code': 'am', 'name':
>>> 'Amharic', 'bidi': False, 'name_local': 'Amharic'}, 'si':
>>> {'code': 'si', 'name': 'Sinhala', 'bidi': False,
>>> 'name_local': 'sinhala'}, 'ta': {'code': 'ta', 'name':
>>> 'Tamil', 'bidi': False, 'name_local': u'tamil'}}
>>> SHOW_PROFILE_EMAIL = False CELERYD_LOG_LEVEL = 1
>>> DATABASE_USER = 'geonode' TEMPLATES = [{'DIRS':
>>> ['/home/geonode/my_geonode/my_geonode/templates',
>>> '/home/geo/Envs/geonode/src/geonode/geonode/templates'],
>>> 'OPTIONS': {'debug': 1, 'context_processors':
>>> ['django.template.context_processors.debug',
>>> 'django.template.context_processors.i18n',
>>> 'django.template.context_processors.tz
>>> <http://django.template.context_processors.tz>',
>>> 'django.template.context_processors.request',
>>> 'django.template.context_processors.media',
>>> 'django.template.context_processors.static',
>>> 'django.contrib.auth.context_processors.auth',
>>> 'django.contrib.messages.context_processors.messages',
>>> 'geonode.context_processors.resource_urls',
>>> 'geonode.geoserver.context_processors.geoserver_urls',
>>> 'geonode.themes.context_processors.custom_theme'],
>>> 'loaders': ['django.template.loaders.filesystem.Loader',
>>> 'django.template.loaders.app_directories.Loader']}, 'NAME':
>>> 'GeoNode Project Templates', 'BACKEND':
>>> 'django.template.backends.django.DjangoTemplates'}]
>>> EMAIL_SSL_CERTFILE = None CELERY_TASK_QUEUES =
>>> DEFAULT_WORKSPACE = 'geonode' ASYNC_SIGNALS = False
>>> LOCAL_GEOSERVER = {'source': {'url':
>>> 'http://geoportal.dummy.org/geoserver/wms', 'restUrl':
>>> '/gs/rest', 'ptype': 'gxp_wmscsource'}} DEFAULT_TABLESPACE =
>>> '' CELERY_ACKS_LATE = True EMAIL_ENABLE = True
>>> SESSION_COOKIE_AGE = 1209600 THEME_ACCOUNT_CONTACT_EMAIL =
>>> 'admin at example.com <mailto:admin at example.com>'
>>> NOTIFICATION_ENABLED = True LANGUAGES =
>>> CELERY_TASK_RESULT_EXPIRES = 43200
>>> GEONODE_CLIENT_LAYER_PREVIEW_LIBRARY = 'geoext'
>>> ABSOLUTE_URL_OVERRIDES = {} OGC_SERVER_DEFAULT_PASSWORD =
>>> u'********************' CACHE_MIDDLEWARE_SECONDS = 600
>>> CSRF_COOKIE_HTTPONLY = False TEST = False EMAIL_HOST_USER =
>>> 'Geoportal dummy ' CASCADE_WORKSPACE = 'geonode'
>>> CSRF_COOKIE_SECURE = False CELERY_TRACK_STARTED = True
>>> UPLOADER = {'SUPPORTED_CRS': ['EPSG:4326', 'EPSG:3785',
>>> 'EPSG:3857', 'EPSG:900913', 'EPSG:32647', 'EPSG:32736'],
>>> 'BACKEND': 'geonode.rest', 'OPTIONS': {'TIME_ENABLED':
>>> False, 'MOSAIC_ENABLED': False, 'GEOGIG_ENABLED': False},
>>> 'SUPPORTED_EXT': ['.shp', '.csv', '.kml', '.kmz', '.json',
>>> '.geojson', '.tif', '.tiff', '.geotiff', '.gml', '.xml']}
>>> LICENSES = {'ENABLED': True, 'DETAIL': 'above', 'METADATA':
>>> 'verbose'} EMAIL_HOST_PASSWORD = u'********************'
>>> PYCSW = {'CONFIGURATION': {'metadata:main':
>>> {'identification_fees': 'None', 'provider_url':
>>> 'http://geoportal.dummy.org/', 'identification_keywords':
>>> 'sdi, catalogue, discovery, metadata, GeoNode',
>>> 'contact_address': 'Mailing Address',
>>> 'identification_accessconstraints': 'None', 'contact_name':
>>> 'Lastname, Firstname', 'contact_stateorprovince':
>>> 'Administrative Area', 'contact_country': 'Country',
>>> 'contact_url': 'Contact URL', 'provider_name': 'Organization
>>> Name', 'contact_phone': '+xx-xxx-xxx-xxxx', 'contact_hours':
>>> 'Hours of Service', 'contact_role': 'pointOfContact',
>>> 'contact_email': 'Email Address', 'identification_title':
>>> 'GeoNode Catalogue', 'contact_postalcode': 'Zip or Postal
>>> Code', 'contact_city': 'City',
>>> 'identification_keywords_type': 'theme',
>>> 'identification_abstract': 'GeoNode is an open source
>>> platform that facilitates the creation, sharing, and
>>> collaborative use of geospatial data', 'contact_fax':
>>> '+xx-xxx-xxx-xxxx', 'contact_instructions': 'During hours of
>>> service. Off on weekends.', 'contact_position': 'Position
>>> Title'}, 'metadata:inspire': {'languages_supported':
>>> 'eng,gre', 'default_language': 'eng', 'temp_extent':
>>> 'YYYY-MM-DD/YYYY-MM-DD', 'conformity_service':
>>> 'notEvaluated', 'contact_email': 'Email Address', 'date':
>>> 'YYYY-MM-DD', 'contact_name': 'Organization Name',
>>> 'gemet_keywords': 'Utility and governmental services',
>>> 'enabled': 'true'}}} CELERY_RESULT_SERIALIZER = 'json'
>>> AWS_STORAGE_BUCKET_NAME = ''
>>> FILE_UPLOAD_DIRECTORY_PERMISSIONS = None LOCAL_ROOT =
>>> '/home/geonode/my_geonode/my_geonode' FILE_UPLOAD_HANDLERS =
>>> DEFAULT_CONTENT_TYPE = 'text/html' DEBUG_STATIC = False
>>> MONITORING_SERVICE_NAME = 'local-geonode'
>>> SOCIALACCOUNT_PROVIDERS = {'linkedin_oauth2': {'SCOPE':
>>> ['r_emailaddress', 'r_basicprofile'], 'PROFILE_FIELDS':
>>> ['emailAddress', 'firstName', 'headline', 'id', 'industry',
>>> 'lastName', 'pictureUrl', 'positions', 'publicProfileUrl',
>>> 'location', 'specialties', 'summary']}, 'facebook':
>>> {'SCOPE': ['email', 'public_profile'], 'METHOD': 'oauth2',
>>> 'FIELDS': ['id', 'email', 'name', 'first_name', 'last_name',
>>> 'verified', 'locale', 'timezone', 'link', 'gender']}}
>>> STATICFILES_STORAGE =
>>> 'django.contrib.staticfiles.storage.StaticFilesStorage'
>>> USE_WORLDMAP = 0 SILENCED_SYSTEM_CHECKS = ['1_8.W001',
>>> 'fields.W340'] LOGGING_CONFIG = 'logging.config.dictConfig'
>>> TEMPLATE_LOADERS = AUTO_GENERATE_AVATAR_SIZES =
>>> HAYSTACK_CONNECTIONS = {'default': {'ENGINE':
>>> 'haystack.backends.elasticsearch2_backend.Elasticsearch2SearchEngine',
>>> 'URL': 'http://127.0.0.1:9200/', 'INDEX_NAME': 'haystack'}}
>>> GEONODE_INTERNAL_APPS = ACCOUNT_LOGIN_REDIRECT_URL =
>>> 'http://localhost:8000/' EMAIL_TIMEOUT = None
>>> SESSION_COOKIE_SECURE = False GEONODE_CORE_APPS = CACHE_TIME
>>> = 0 AWS_ACCESS_KEY_ID = u'********************'
>>> INSTALLED_APPS = THUMBNAIL_GENERATOR_DEFAULT_BG =
>>> 'http://a.tile.openstreetmap.org/{z}/{x}/{y}.png'
>>> STATIC_ROOT = '/var/www/geonode/static/'
>>> SECURE_HSTS_INCLUDE_SUBDOMAINS = True GEONODE_APPS =
>>> SESSION_COOKIE_HTTPONLY = True DATETIME_FORMAT = 'N j, Y, P'
>>> USER_MESSAGES_ALLOW_MULTIPLE_RECIPIENTS = True
>>> GEOTIFF_IO_BASE_URL = 'https://app.geotiff.io'
>>> DATE_INPUT_FORMATS = ACCOUNT_LOGOUT_REDIRECT_URL =
>>> 'http://localhost:8000/' TWITTER_CARD = 1 CSRF_COOKIE_NAME =
>>> 'csrftoken' SESSION_SAVE_EVERY_REQUEST = False
>>> NUMBER_GROUPING = 0 LOCALE_PATHS = GEONODE_ROOT =
>>> '/home/geo/Envs/geonode/src/geonode/geonode' LOGGING =
>>> {'loggers': {'geonode': {'handlers': ['applogfile'],
>>> 'level': 'DEBUG'}, 'django': {'handlers': ['applogfile'],
>>> 'level': 'DEBUG'}, 'pycsw': {'handlers': ['applogfile'],
>>> 'level': 'DEBUG'}, 'owslib': {'handlers': ['applogfile'],
>>> 'level': 'DEBUG'}, 'gsconfig.catalog': {'handlers':
>>> ['applogfile'], 'level': 'DEBUG'}},
>>> 'disable_existing_loggers': True, 'handlers': {'console':
>>> {'formatter': 'simple', 'class': 'logging.StreamHandler',
>>> 'level': 'DEBUG'}, 'applogfile': {'level': 'DEBUG',
>>> 'maxBytes': 15728640, 'backupCount': 10, 'class':
>>> 'logging.handlers.RotatingFileHandler', 'filename':
>>> '/tmp/GEONODE_APP.log'}, 'mail_admins': {'class':
>>> 'django.utils.log.AdminEmailHandler', 'filters':
>>> ['require_debug_false'], 'level': 'ERROR'}}, 'formatters':
>>> {'simple': {'format': '%(message)s'}, 'verbose': {'format':
>>> '%(levelname)s %(asctime)s %(module)s %(process)d %(thread)d
>>> %(message)s'}}, 'version': 1, 'filters':
>>> {'require_debug_false': {'()':
>>> 'django.utils.log.RequireDebugFalse'}}} INTEGRATION = False
>>> OGP_URL = 'http://geodata.tufts.edu/solr/select' USE_L10N =
>>> 1 CELERYD_LOG_FILE = None EMAIL_HOST =
>>> 'dummysmtp4.cgiarad.org <http://dummysmtp4.cgiarad.org>'
>>> NLP_LOCATION_THRESHOLD = 1.0 REST_FRAMEWORK =
>>> {'DEFAULT_PERMISSION_CLASSES':
>>> ['rest_framework.permissions.DjangoModelPermissionsOrAnonReadOnly']}
>>> DATABASE_NAME = 'geonode' MEDIA_URL = '/uploaded/'
>>> RABBITMQ_SIGNALS_BROKER_URL = 'amqp://localhost:5672'
>>> DJANGO_LIVE_TEST_SERVER_ADDRESS = 'localhost:8000'
>>> MONITORING_ENABLED = True DOWNLOAD_FORMATS_VECTOR = ['JPEG',
>>> 'PDF', 'PNG', 'Zipped Shapefile', 'GML 2.0', 'GML 3.1.1',
>>> 'CSV', 'Excel', 'GeoJSON', 'KML', 'View in Google Earth',
>>> 'Tiles', 'QGIS layer file (.qlr)', 'QGIS project file
>>> (.qgs)'] SKIP_PERMS_FILTER = False GEONODE_CLIENT_HOOKSET =
>>> TWITTER_SITE = '@GeoNode' SLACK_ENABLED = False PROJECT_NAME
>>> = 'my_geonode' TEST_RUNNER =
>>> 'django_nose.NoseTestSuiteRunner' HAYSTACK_FACET_COUNTS =
>>> True SECURE_SSL_REDIRECT = False TIME_ZONE = 'UTC'
>>> CORS_ORIGIN_ALLOW_ALL = True EMAIL_BACKEND =
>>> 'django.core.mail.backends.smtp.EmailBackend'
>>> DEFAULT_MAP_ZOOM = 0 TEMPLATE_CONTEXT_PROCESSORS =
>>> MAPBOX_ACCESS_TOKEN = u'********************'
>>> S3_STATIC_ENABLED = False PINAX_NOTIFICATIONS_LANGUAGE_MODEL
>>> = None LANGUAGES_BIDI = HAYSTACK_SIGNAL_PROCESSOR =
>>> 'haystack.signals.RealtimeSignalProcessor'
>>> CLIENT_RESULTS_LIMIT = 20 MODELTRANSLATION_DEFAULT_LANGUAGE
>>> = 'en' GEOFENCE_SECURITY_ENABLED = True
>>> SOCIALACCOUNT_ADAPTER =
>>> 'geonode.people.adapters.SocialAccountAdapter'
>>> DATABASE_PASSWORD = u'********************'
>>> SECURE_HSTS_SECONDS = 3600 TEST_NON_SERIALIZED_APPS = []
>>> DEFAULT_CHARSET = 'utf-8' OPENGRAPH_ENABLED = 1
>>> CELERY_MAX_CACHED_RESULTS = 32768 CELERY_RESULT_PERSISTENT =
>>> False ALLOWED_HOSTS = ['geoportal.dummy.org
>>> 'localhost'] OGC_SERVER = {'default':
>>> {'BACKEND_WRITE_ENABLED': True, 'PASSWORD':
>>> u'********************', 'WPS_ENABLED': True,
>>> 'LOGIN_ENDPOINT': 'j_spring_oauth2_geonode_login',
>>> 'PUBLIC_LOCATION': 'http://geoportal.dummy.org/geoserver/',
>>> 'GEONODE_SECURITY_ENABLED': True, 'PRINT_NG_ENABLED': True,
>>> 'GEOGIG_DATASTORE_DIR': '', 'PG_GEOGIG': False,
>>> 'GEOFENCE_SECURITY_ENABLED': True, 'LOCATION':
>>> 'http://localhost/geoserver/', 'MAPFISH_PRINT_ENABLED':
>>> True, 'LOGOUT_ENDPOINT': 'j_spring_oauth2_geonode_logout',
>>> 'TIMEOUT': 10, 'WMST_ENABLED': False, 'DATASTORE':
>>> 'datastore', 'LOG_FILE':
>>> '/usr/share/geoserver/data/logs/geoserver.log', 'BACKEND':
>>> 'geonode.geoserver', 'GEOGIG_ENABLED': False, 'USER':
>>> 'admin'}} DOWNLOAD_FORMATS_RASTER = ['JPEG', 'PDF', 'PNG',
>>> 'ArcGrid', 'GeoTIFF', 'Gtopo30', 'ImageMosaic', 'KML', 'View
>>> in Google Earth', 'Tiles', 'GML', 'GZIP', 'QGIS layer file
>>> (.qlr)', 'QGIS project file (.qgs)', 'Zipped All Files']
>>> AUTH_EXEMPT_URLS = EMAIL_SUBJECT_PREFIX = '[Django] '
>>> THOUSAND_SEPARATOR = ',' STATICFILES_FINDERS =
>>> S3_MEDIA_ENABLED = False CELERY_WORKER_DISABLE_RATE_LIMITS =
>>> False STATIC_URL = '/static/' TIME_INPUT_FORMATS =
>>> SECURE_REDIRECT_EXEMPT = [] DATABASES = {'default':
>>> {'ENGINE': 'django.db.backends.postgresql_psycopg2',
>>> 'AUTOCOMMIT': True, 'ATOMIC_REQUESTS': False, 'NAME':
>>> 'geonode', 'CONN_MAX_AGE': 0, 'CONN_TOUT': 900, 'TIME_ZONE':
>>> 'UTC', 'PORT': '5432', 'HOST': 'localhost', 'USER':
>>> 'geonode', 'TEST': {'COLLATION': None, 'CHARSET': None,
>>> 'NAME': None, 'MIRROR': None}, 'PASSWORD':
>>> u'********************', 'OPTIONS': {}}, 'datastore':
>>> {'ENGINE': 'django.contrib.gis.db.backends.postgis',
>>> 'geonode_data', 'CONN_MAX_AGE': 0, 'CONN_TOUT': 900,
>>> 'TIME_ZONE': 'UTC', 'PORT': '5432', 'HOST': 'localhost',
>>> 'USER': 'geonode', 'TEST': {'COLLATION': None, 'CHARSET':
>>> None, 'NAME': None, 'MIRROR': None}, 'PASSWORD':
>>> u'********************', 'OPTIONS': {}}} LEAFLET_CONFIG =
>>> {'SRID': 3857, 'RESET_VIEW': False, 'TILES': [('Watercolor',
>>> 'http://{s}.tile.stamen.com/watercolor/{z}/{x}/{y}.png
>>> <http://tile.stamen.com/watercolor/%7Bz%7D/%7Bx%7D/%7By%7D.png>',
>>> 'Map tiles by Stamen Design, CC BY 3.0 — Map data ©
>>> OpenStreetMap contributors, CC-BY-SA'), ('Toner Lite',
>>> 'http://{s}.tile.stamen.com/toner-lite/{z}/{x}/{y}.png
>>> <http://tile.stamen.com/toner-lite/%7Bz%7D/%7Bx%7D/%7By%7D.png>',
>>> OpenStreetMap contributors, CC-BY-SA')], 'PLUGINS':
>>> {u'forms': {u'css': , u'auto-include': False, u'js': },
>>> u'__default__': {u'css': , u'js': }, u'ALL': {u'css': ,
>>> u'js': }, 'leaflet-plugins': {'css': , 'auto-include': True,
>>> 'js': }, u'__is_normalized__': True}}
>>> ACCOUNT_APPROVAL_REQUIRED = 0 DATABASE_URL =
>>> 'sqlite:////home/geo/Envs/geonode/src/geonode/geonode/development.db'
>>> MODELTRANSLATION_LANGUAGES = ['en'] SLACK_WEBHOOK_URLS =
>>> ['https://hooks.slack.com/services/T000/B000/XX']
>>> ALT_OSM_BASEMAPS = False ACCOUNT_OPEN_SIGNUP = True
>>> ACCOUNT_ADAPTER =
>>> SECURE_CONTENT_TYPE_NOSNIFF = True SECRET_KEY =
>>> u'********************' FILE_UPLOAD_TEMP_DIR = None
>>> DEFAULT_MAP_CRS = 'EPSG:900913'
>>> DATA_UPLOAD_MAX_NUMBER_FIELDS = 100000
>>> MAP_CLIENT_USE_CROSS_ORIGIN_CREDENTIALS = 0
>>> REDIS_SIGNALS_BROKER_URL = 'redis://localhost:6379/0'
>>> SETTINGS_MODULE = 'my_geonode.settings'
>>> AUTHENTICATION_BACKENDS = CELERY_ALWAYS_EAGER = True
>>> MODIFY_TOPICCATEGORY = True SIGNING_BACKEND =
>>> 'django.core.signing.TimestampSigner' LANGUAGE_COOKIE_DOMAIN
>>> = None DEFAULT_FILE_STORAGE =
>>> 'django.core.files.storage.FileSystemStorage' SITEURL =
>>> 'http://geoportal.dummy.org/' LANGUAGE_COOKIE_AGE = None
>>> SOCIALACCOUNT_PROFILE_EXTRACTORS = {'linkedin_oauth2':
>>> 'geonode.people.profileextractors.LinkedInExtractor',
>>> 'facebook':
>>> 'geonode.people.profileextractors.FacebookExtractor'}
>>> MANAGERS = [] SESSION_EXPIRE_AT_BROWSER_CLOSE = False
>>> TIME_FORMAT = 'P' CACHE_MIDDLEWARE_ALIAS = 'default'
>>> SERVICE_UPDATE_INTERVAL = 0 CSRF_COOKIE_PATH = '/'
>>> NLP_LIBRARY_PATH = '/opt/MITIE/mitielib' MONITORING_CONFIG =
>>> None CELERYD_POOL_RESTARTS = True PROJECT_ROOT =
>>> CACHE_MIDDLEWARE_KEY_PREFIX = u'********************' RISKS
>>> = {'PDF_GENERATOR': {'BIN': '/usr/bin/wkhtml2pdf', 'ARGS':
>>> [], 'NAME': 'wkhtml2pdf'}, 'DEFAULT_LOCATION': None}
>>> MAP_BASELAYERS = [{'source': {'url':
>>> '/gs/rest', 'ptype': 'gxp_wmscsource'}}, {'group':
>>> 'background', 'name': 'background', 'args': ['No
>>> background'], 'visibility': False, 'source': {'ptype':
>>> 'gxp_olsource'}, 'fixed': True, 'type': 'OpenLayers.Layer'},
>>> {'source': {'ptype': 'gxp_olsource'}, 'wrapDateLine': True,
>>> 'fixed': True, 'attribution': '© UNESCO', 'name':
>>> 'background', 'title': 'UNESCO', 'group': 'background',
>>> 'args': ['UNESCO',
>>> 'http://en.unesco.org/tiles/${z}/${x}/${y}.png'], 'type':
>>> 'OpenLayers.Layer.XYZ <http://OpenLayers.Layer.XYZ>',
>>> 'visibility': False}, {'source': {'ptype': 'gxp_olsource'},
>>> 'wrapDateLine': True, 'fixed': True, 'attribution': '©
>>> UNESCO', 'name': 'background', 'title': 'UNESCO GEODATA',
>>> 'group': 'background', 'args': ['UNESCO GEODATA',
>>> 'http://en.unesco.org/tiles/geodata/${z}/${x}/${y}.png'],
>>> 'type': 'OpenLayers.Layer.XYZ
>>> <http://OpenLayers.Layer.XYZ>', 'visibility': False},
>>> 'fixed': True, 'attribution': "© OpenStreetMap, Tiles
>>> courtesy of Humanitarian OpenStreetMap Team", 'name':
>>> 'background', 'title': 'Humanitarian OpenStreetMap',
>>> 'group': 'background', 'args': ['Humanitarian
>>> OpenStreetMap',
>>> 'http://a.tile.openstreetmap.fr/hot/${z}/${x}/${y}.png'],
>>> 'fixed': True, 'attribution': "© Mapbox © OpenStreetMap
>>> Improve this map", 'name': 'background', 'title': 'MapBox
>>> Satellite Streets', 'group': 'background', 'args': ['MapBox
>>> Satellite Streets',
>>> 'http://api.mapbox.com/styles/v1/mapbox/satellite-streets-v9/tiles/${z}/${x}/${y}?access_token='],
>>> Streets', 'group': 'background', 'args': ['MapBox Streets',
>>> 'http://api.mapbox.com/styles/v1/mapbox/streets-v9/tiles/${z}/${x}/${y}?access_token='],
>>> {'source': {'ptype': 'gxp_osmsource'}, 'wrapDateLine': True,
>>> 'attribution': "© OpenStreetMap contributors", 'name':
>>> 'mapnik', 'title': 'OpenStreetMap', 'group': 'background',
>>> 'fixed': True, 'type': 'OpenLayers.Layer.OSM', 'visibility':
>>> True}] LOGIN_REDIRECT_URL = '/' GROUP_PRIVATE_RESOURCES =
>>> False DATE_FORMAT = 'N j, Y' LOCAL_SIGNALS_BROKER_URL =
>>> 'memory://' MEDIA_ROOT = '/var/www/geonode/uploaded'
>>> PROXY_URL = '/proxy/?url=' TEMPLATE_DEBUG = False
>>> DEFAULT_FROM_EMAIL = 'Geoportal dummy '
>>> FREETEXT_KEYWORDS_READONLY = u'********************'
>>> GEONODE_EXCHANGE = NOTIFICATIONS_MODULE =
>>> 'pinax.notifications' SITE_ID = 1 ALLOWED_INCLUDE_ROOTS =
>>> API_LIMIT_PER_PAGE = u'********************'
>>> SHORT_DATE_FORMAT = 'm/d/Y' ACTSTREAM_SETTINGS =
>>> {'GFK_FETCH_DEPTH': 1, 'USE_JSONFIELD': True,
>>> 'FETCH_RELATIONS': True, 'USE_PREFETCH': False}
>>> AWS_S3_BUCKET_DOMAIN = '.s3.amazonaws.com
>>> <http://s3.amazonaws.com>' FILE_UPLOAD_MAX_MEMORY_SIZE =
>>> 2621440 DISPLAY_SOCIAL = 1 CSRF_COOKIE_AGE = 31449600
>>> EMAIL_USE_SSL = False INTERNAL_IPS = EMAIL_PORT = 25
>>> GROUP_MANDATORY_RESOURCES = False PASSWORD_HASHERS =
>>> u'********************' ANONYMOUS_USER_ID = '-1'
>>> DATETIME_INPUT_FORMATS = You're seeing this error because
>>> you have DEBUG = True in your Django settings file. Change
>>> that to False, and Django will display a standard page
>>> generated by the handler for this status code.
>>> Michael Härtel
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> <mailto:geonode-devel at lists.osgeo.org>
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.==Ing. Alessio Fabiani
>>> @alfa7691Founder/Technical Lead
>>> GeoSolutions S.A.S.Via di Montramito 3/A - 55054 Massarosa (LU)
>>> - Italyphone: +39 0584 962313fax: +39 0584 1660272mob: +39
>>> 331 6233686
>>> http://www.geo-solutions.ithttp://twitter.com/geosolutions_it-------------------------------------------------------
>>> Con riferimento alla normativa sul trattamento dei dati
>>> personali (Reg. UE 2016/679 - Regolamento generale sulla
>>> protezione dei dati “GDPR”), si precisa che ogni circostanza
>>> inerente alla presente email (il suo contenuto, gli eventuali
>>> allegati, etc.) è un dato la cui conoscenza è riservata al/i
>>> solo/i destinatario/i indicati dallo scrivente. Se il messaggio
>>> Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse
>>> darmene notizia.
>>> This email is intended only for the person or entity to which it
>>> is addressed and may contain information that is privileged,
>>> confidential or otherwise protected from disclosure. We remind
>>> that - as provided by European Regulation 2016/679 “GDPR” -
>>> copying, dissemination or use of this e-mail or the information
>>> herein by anyone other than the intended recipient is
>>> prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
>> GeoSolutions S.A.S.Via di Montramito 3/A - 55054 Massarosa (LU) -
>> Italyphone: +39 0584 962313fax: +39 0584 1660272mob: +39 331
>> 6233686
>> Con riferimento alla normativa sul trattamento dei dati personali
>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
>> “GDPR”), si precisa che ogni circostanza inerente alla presente email
>> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
>> conoscenza è riservata al/i solo/i destinatario/i indicati dallo
>> scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a
>> cancellarlo, ogni altra operazione è illecita. Le sarei comunque
>> grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> confidential or otherwise protected from disclosure. We remind that -
>> as provided by European Regulation 2016/679 “GDPR” - copying,
>> dissemination or use of this e-mail or the information herein by
>> anyone other than the intended recipient is prohibited. If you have
>> received this email by mistake, please notify us immediately by
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190516/a41780c0/attachment-0001.html>
More information about the geonode-devel
