[GeoNode-devel] [Geoserver-users] Restauring GeoServer to its Default Credentials
1520 gis
juliermeopensourcedeveloper at gmail.com
Thu May 16 10:28:11 PDT 2019
Dear Mr. Mueller,
Thank you very much for your reply.
I appreciated it
Kin regards
Julierme
On Wed, Apr 24, 2019 at 3:21 AM Christian Mueller <
christian.mueller at os-solutions.at> wrote:
> Hi
> Edit users.xml and set "password="plain:mypassword".
> Afterwards log in to Geoserver as admin and change the password. As a
> consequence you should see "password="digest1:.....".
> Cheers
> On Tue, Apr 23, 2019 at 6:19 PM 1520 gis <
> juliermeopensourcedeveloper at gmail.com> wrote:
>> I also tried setting tGeoserver admin password bellow but it did not
>> work:
>> <user enabled="true" name="admin"
>> password="digest1:D9miJH/hVgfxZJscMafEtbtliG0ROxhLfsznyWfG38X2pda2JOSV4POi55PQI4tw"/>
>> Kind regards
>> Julierme
>> On Tue, Apr 23, 2019 at 12:44 PM 1520 gis <
>>> Dear users and developers,
>>> I have faced an issue with GeoServer Credentials since I changed its
>>> defaults. I am running GeoNode-project master version installed via docker.
>>> I went to Django container @ .../security/usergroup/default/users.xml and
>>> I changed the admin credentials as discussed in here
>>> <http://osgeo-org.1560.x6.nabble.com/Forgot-the-geoserver-login-password-td5298425.html>
>>> , but I did not get any success.
>>> Any help on how I could achieve that will be very appreciated.
>>> Kind regards
>>> Julierme
>> Geoserver-users mailing list
>> Please make sure you read the following two resources before posting to
>> this list:
>> - Earning your support instead of buying it, but Ian Turton:
>> http://www.ianturton.com/talks/foss4g.html#/
>> - The GeoServer user list posting guidelines:
>> http://geoserver.org/comm/userlist-guidelines.html
>> If you want to request a feature or an improvement, also see this:
>> https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
>> Geoserver-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geoserver-users
> DI Christian Mueller MSc (GIS), MSc (IT-Security)
> OSS Open Source Solutions GmbH
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190516/85925361/attachment.html>
More information about the geonode-devel
