[GeoNode-devel] download original datasets feature randomly fails
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu May 23 00:17:07 PDT 2019
Hi Paolo,
yes, sure, it is feasible.
Do you have some resources to work on that?
Il giorno mer 22 mag 2019 alle ore 22:15 Paolo Corti <pcorti at gmail.com> ha
scritto:
> Hi Alessio
> I guess that would be feasible with the management command. I wouldn't
> do that when saving the metadata as it can slow down things.
> How about having a setting which disable the creation of the "Original
> Dataset" link?
> thanks for helping with this
> Paolo
> On Mon, May 20, 2019 at 4:24 AM Alessio Fabiani
> <alessio.fabiani at geo-solutions.it> wrote:
> > Hello Paolo,
> > yes it was tested... not recently to be honest.
> > Maybe we can improve it in order to look first for the original dataset
> and advertise the user suddenly.
> > Moreover in the latest versions the management command
> "set_all_layers_metadata" checks and fixes the links, and refreshes the
> metadata accordingly.
> > We could envisage the code creating "Original Dataset" links to check
> for the original resource before creating it.
> > Il giorno ven 17 mag 2019 alle ore 21:49 Paolo Corti <pcorti at gmail.com>
> ha scritto:
> >> Dear Alessio
> >> thanks a lot for the detailed explanation.
> >> The reason in our instances could be that for many layers we haven't
> >> anymore the original shapefile but just the data in PostGIS.
> >> Which means that the best option for us is to disable that link.
> >> ps: by the way, was this tested both with rest and the importer
> >> uploader? (we are using the latter)
> >> Have a great weekend
> >> Paolo
> >> On Fri, May 17, 2019 at 3:47 AM Alessio Fabiani
> >> > Hello Paolo,
> >> > don't know exactly why is failing in your case, it is usually
> working, at least on my experience.
> >> > However, the idea is the following.
> >> > All the download methods exposed on GeoNode, relies on OGC calls. For
> vectors WFS, raster WCS and other formats WMS.
> >> > That means that you overload GeoServer and potentially, especially
> for huge datasets, a single download can stuck your server by consuming all
> the machine resources available.
> >> > Notice also that GeoServer always does a format conversion when you
> ask for a raw data format.
> >> > The latest versions of GeoServer have some protection mechanisms
> allowing you to configure the cap of resources to be consumed.
> >> > That means that for big datasets the download won't be allowed at all.
> >> > The intention of "Original Dataset" download link, is to allow
> GeoNode to package the uploaded files into the filesystem along with all
> the SLDs defined and metadata formats, and send back to the user
> >> > without making OGC requests.
> >> > Of course this will successfully work only if:
> >> > 1. The original uploaded file still exists and it is accessible on
> the filesystem
> >> > 2. The layer is not a pure table on a DB but has a file associated
> with it
> >> > Other than this, and this could be the cause why it is failing in
> your case, the "upload session" metadata stored on GeoNode database should
> point to the correct original files uploaded into GeoNode.
> >> > That said, if you have the chance to investigate a bit more on the
> cause of the failures, we can try to make it a bit more reliable.
> >> > Cheers,
> >> > A.
> >> > Il giorno ven 17 mag 2019 alle ore 00:41 Paolo Corti <
> pcorti at gmail.com> ha scritto:
> >> >> Hi devs
> >> >> when downloading a layer, "Zipped Shapefile" works as expected, while
> >> >> "Original Datasets" randomly fails. Also, I am not sure what is the
> >> >> latter for: when I am able to download it successfully, I see a zip
> >> >> file containing a bunch of .sld and geojson file.
> >> >> Would be glad to learn more about this
> >> >> thanks
> >> >> Paolo
> >> >> Paolo Corti
> >> >> Geospatial software developer
> >> >> web: http://www.paolocorti.net
> >> >> twitter: @capooti
> >> >> skype: capooti
> >> >> #drt3jc1
> >> >> _______________________________________________
> >> >> geonode-devel mailing list
> >> >> geonode-devel at lists.osgeo.org
> >> >> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> >> > GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> >> > Ing. Alessio Fabiani
> >> > @alfa7691
> >> > Founder/Technical Lead
> >> > GeoSolutions S.A.S.
> >> > Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> >> > phone: +39 0584 962313
> >> > fax: +39 0584 1660272
> >> > mob: +39 331 6233686
> >> > http://www.geo-solutions.it
> >> > http://twitter.com/geosolutions_it
> >> > Con riferimento alla normativa sul trattamento dei dati personali
> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
> si precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> >> > This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> >> Paolo Corti
> >> twitter: @capooti
> >> skype: capooti
> >> #drt3jc1
> > @alfa7691
> > GeoSolutions S.A.S.
> > Con riferimento alla normativa sul trattamento dei dati personali (Reg.
> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> Paolo Corti
> twitter: @capooti
> skype: capooti
> #drt3jc1
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190523/f81a5fd7/attachment-0001.html>
More information about the geonode-devel
