[GeoNode-devel] Integration of other apps like Geonetwork
Florian Hoedt
florian.hoedt at thuenen.de
Fri Nov 15 00:31:55 PST 2019
Hi Pieter,
You would´t include the war in any container but using a seperate one. You can add the docker image from GeoNetwork to the docker-compose stack, for example.
See:
https://hub.docker.com/_/geonetwork
You should publish it on a different port than 8080 to the host machine, since geoserver allready uses that port.
cheers, Florian
MSc Florian Hoedt
Koordinator Geoinformation | Coordinator Geoinformatics
OpenData Beauftrager | OpenData Representative
Thünen-Institut, Zentrum für Informationsmanagement | Thünen Institute, Centre for Information Management
Bundesallee 44
38116 Braunschweig
Tel: +49 531 596-1428
Fax: +49 531 596-1499
Mail: florian.hoedt at thuenen.de
Web: www.thuenen.de
Das Johann Heinrich von Thünen-Institut, Bundesforschungsinstitut für Ländliche Räume, Wald und Fischerei - kurz: Thünen-Institut - besteht aus 14 Fachinstituten, die in den Bereichen Ökonomie, Ökologie und Technologie forschen und die Politik beraten.
The Johann Heinrich von Thünen Institute, Federal Research Institute for Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists of 14 specialized institutes that carry out research and provide policy advice in the fields of economy, ecology and technology.
Von: "Pieter du Plooy" <pjduplooy.gis at gmail.com>
An: geonode-devel at lists.osgeo.org
Gesendet: Freitag, 15. November 2019 05:19:15
Betreff: [GeoNode-devel] Integration of other apps like Geonetwork
I would like to know how i go about to add other WAR's like Geonetwork et all to the docker build of Geonode. In which container will I put the war?
Is this at all possible?
Pieter
geonode-devel mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20191115/d714c454/attachment.html>
More information about the geonode-devel
