[GeoNode-devel] GeoNode Project: Timeout updates Layer with new ManyToManyField in ResourceBase
Giambattista Mameli
mameli.giambattista at gmail.com
Mon Oct 21 09:01:59 PDT 2019
Hi guys,
I developed a custom GeoNode Project implementing a M:M relationship on the
ResourceBase table
Here the steps:
1) model creation of the new table
class DomainArea(models.Model):
identifier = models.CharField('Domain Area name', max_length=255,
unique=True)
description = models.TextField(default='')
gn_description = models.TextField(
'GeoNode description', default='', null=True)
is_choice = models.BooleanField(default=True)
def __unicode__(self):
return u"{0}".format(self.gn_description)
class Meta:
ordering = ("identifier",)
verbose_name_plural = 'Domain Areas'
2) add the relation between the ResourceBase table and the new created table
domainarea = models.ManyToManyField(
DomainArea,
related_name='resourcebase_domainarea',
blank=True)
ResourceBase.add_to_class('domain_area', domainarea)
3) Add the function to handle the new value in the admin panel
admin.site.register(DomainArea)
All the steps work good, Django creates the new table with all the
relationship and I can handle via admin panel both values and associations
between domain areas and Layers/Docs/Maps.
The problem is when I modify these values.
After the first association, all the updates go wrong (timeout, even with a
very long timeout set).
This is the error message:
Traceback:
File
"/usr/local/lib/python2.7/site-packages/django/core/handlers/exception.py"
in inner
41. response = get_response(request)
File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py"
in _legacy_get_response
249. response = self._get_response(request)
in _get_response
187. response = self.process_exception_by_middleware(e,
request)
in _get_response
185. response = wrapped_callback(request, callback_args,
*callback_kwargs)
File
"/usr/local/lib/python2.7/site-packages/django/contrib/admin/options.py" in
wrapper
552. return self.admin_site.admin_view(view)(*args,
**kwargs)
File "/usr/local/lib/python2.7/site-packages/django/utils/decorators.py" in
_wrapped_view
149. response = view_func(request, args, *kwargs)
File
"/usr/local/lib/python2.7/site-packages/django/views/decorators/cache.py"
in _wrapped_view_func
57. response = view_func(request, args, *kwargs)
File "/usr/local/lib/python2.7/site-packages/django/contrib/admin/sites.py"
in inner
224. return view(request, args, *kwargs)
File
change_view
1512. return self.changeform_view(request, object_id, form_url,
extra_context)
_wrapper
67. return bound_func(*args, **kwargs)
_wrapped_view
bound_func
63. return func.__get__(self, type(self))(*args2,
**kwargs2)
File
changeform_view
1409. return self._changeform_view(request, object_id,
form_url, extra_context)
File
_changeform_view
1449. self.save_model(request, new_object, form, not add)
File
save_model
980. obj.save()
File "/usr/local/lib/python2.7/site-packages/polymorphic/models.py" in save
83. return super(PolymorphicModel, self).save(*args, **kwargs)
File "/usr/local/lib/python2.7/site-packages/django/db/models/base.py" in
save
808. force_update=force_update,
update_fields=update_fields)
save_base
848. update_fields=update_fields, raw=raw, using=using,
File "/usr/local/lib/python2.7/site-packages/django/dispatch/dispatcher.py"
in send
193. for receiver in self._live_receivers(sender)
File "/usr/local/lib/python2.7/site-packages/geonode/decorators.py" in
wrapper
53. return func(*args, **kwargs)
File "/usr/local/lib/python2.7/site-packages/geonode/geoserver/signals.py"
in geoserver_post_save
85. producer.geoserver_upload_layer(payload)
File "/usr/local/lib/python2.7/site-packages/geonode/messaging/producer.py"
in sync_if_local_memory
71. worker.run(timeout=broker_socket_timeout)
File "/usr/local/lib/python2.7/site-packages/kombu/mixins.py" in run
170. for _ in self.consume(limit=None, **kwargs):
File "/usr/local/lib/python2.7/site-packages/kombu/mixins.py" in consume
192. conn.drain_events(timeout=safety_interval)
File "/usr/local/lib/python2.7/site-packages/kombu/connection.py" in
drain_events
315. return self.transport.drain_events(self.connection, **kwargs)
File
"/usr/local/lib/python2.7/site-packages/kombu/transport/virtual/base.py" in
drain_events
966. raise socket.timeout()
Any help will be greatly appreciated
Thanks in advance
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20191021/48af86ea/attachment-0001.html>
More information about the geonode-devel
