[GeoNode-devel] HTTPS support for geonode.org
Francesco Bartoli
xbartolone at gmail.com
Sun Sep 1 06:11:00 PDT 2019
I should have the access, I’ll confirm it asap
Ciao
Francesco
Il 29 ago 2019, 11:46 +0200, Alessio Fabiani <alessio.fabiani at geo-solutions.it>, ha scritto:
> Thanks Tom,
> I don't think I have DNS privileges neither. I'll try to ask around to the other admins if they have access to it.
> > Il giorno mar 27 ago 2019 alle ore 20:18 Tom Kralidis <tomkralidis at gmail.com> ha scritto:
> > > Hi all: going to https://geonode.org shows security warning. I tried enforcing
> > > HTTPS support in [1], however this is disabled with an associated warning
> > > message in the GitHub Pages section:
> > > "The custom domain for your GitHub Pages site is pointed at an
> > > outdated IP address. You must update your site's DNS records if you'd
> > > like it to be available via your custom domain. For more information,
> > > see https://help.github.com/articles/setting-up-a-custom-domain-with-github-pages/.
> > > I'm not sure who has DNS privileges, but can we have this updated so HTTPS
> > > support can be enabled?
> > > Thanks
> > > ..Tom
> > > [1] https://github.com/GeoNode/geonode.github.com/settings
> > > _______________________________________________
> > > geonode-devel mailing list
> > > geonode-devel at lists.osgeo.org
> > > https://lists.osgeo.org/mailman/listinfo/geonode-devel
> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190901/d146ef27/attachment.html>
More information about the geonode-devel
