[GeoNode-devel] Docker build issues
Florian Hoedt florian.hoedt at thuenen.de
Tue Sep 3 23:33:59 PDT 2019
Hello Pieter,
This is most likely a windows path issue. All paths are written in unix style.
I had these issues as well and just left using docker on windows, but creating a virtual linux machine which will run docker for me. A box in a box, which is not perfect but works.
https://forums.docker.com/t/docker-toolbox-and-windows-paths/60392/2
@frafra @francbartoli: what do you say?
cheers,
Florian
MSc Florian Hoedt
Koordinator Geoinformation | Coordinator Geoinformatics
OpenData Beauftrager | OpenData Representative
Thünen-Institut, Zentrum für Informationsmanagement | Thünen Institute, Centre for Information Management
Bundesallee 44
38116 Braunschweig
Tel: +49 531 596-1428
Fax: +49 531 596-1499
Mail: florian.hoedt at thuenen.de
Web: www.thuenen.de
Das Johann Heinrich von Thünen-Institut, Bundesforschungsinstitut für Ländliche Räume, Wald und Fischerei - kurz: Thünen-Institut - besteht aus 14 Fachinstituten, die in den Bereichen Ökonomie, Ökologie und Technologie forschen und die Politik beraten.
The Johann Heinrich von Thünen Institute, Federal Research Institute for Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists of 14 specialized institutes that carry out research and provide policy advice in the fields of economy, ecology and technology.
Von: "Pieter du Plooy" <pjduplooy.gis at gmail.com>
An: geonode-devel at lists.osgeo.org
Gesendet: Dienstag, 3. September 2019 20:38:16
Betreff: [GeoNode-devel] Docker build issues
Hi guys.
Using docker toolbox (Win 7). Just cloned the repository, and get the following error on build:
Step 8/9 : EXPOSE 8000
ERROR: Service 'django' failed to build: error creating overlay mount to /mnt/sda1/var/lib/docker/overlay2/645283667aeba9f90420f12e8d0c381f365397b0e083783d75bfa
4a5fbbf6b21-init/merged: no such file or directory
I am using the following command:
$ docker-compose -f docker-compose.yml -f docker-compose.override.192.168.99.100.yml up --build -d
Dont know what to do know.
Machine configuration havent changed since previous build..
Pieter
geonode-devel mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190904/3fbf7d17/attachment.html>
More information about the geonode-devel mailing list
