[GeoNode-devel] errors with style creation during layer upload to PostGIS
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Sep 5 06:34:53 PDT 2019
It looks something related to GeoServer catalog.
Could you try if just reloading it, instead of restarting GeoServer, also
works?
Il giorno gio 5 set 2019 alle ore 15:31 Paolo Corti <pcorti at gmail.com> ha
scritto:
> Dear Alessio
> unfortunately this doesn't appear to be helpful. My idea is that there
> is something wrong in authorization from GeoFence.
> Here is what happening:
> * Restart GeoServer
> * First layer upload works correctly
> * I then remove the layer and I upload it again
> * I get the error. Checkin in GeoServer log I see:
> 2019-09-05 13:25:39,175 ERROR [geoserver.rest] - No such datastore:
> geonode,rivers
> org.geoserver.rest.ResourceNotFoundException 404 NOT_FOUND: No such
> datastore: geonode,rivers
> Restarting GeoServer will fix this.
> This is happening in a GeoNode project, let me see if I can experience
> the same locally.
> ps: I have seen your PR with the changes in gsconfig, I believe anyway
> that they are useful, will merge it as soon as build is finalized.
> thanks for helping with this
> Paolo
> On Thu, Sep 5, 2019 at 8:56 AM Alessio Fabiani
> <alessio.fabiani at geo-solutions.it> wrote:
> > @Paolo any chanche to test the update of the library
> > (maybe be sure you first removed completely the old one, gsconfig)
> > pip install geoserver-restconfig==1.0.3
> > Il giorno mer 4 set 2019 alle ore 23:11 Paolo Corti <pcorti at gmail.com>
> ha scritto:
> >> Looking in the GeoServer log, it appears that GeoNode upload fails to
> >> create the style (and then the layer) in step 7 because it cannot find
> >> the newly created GeoServer layer (even if this was already created at
> >> step 4 in the upload process). This is the error I see in GeoServer:
> >> 2019-09-04 21:05:42,632 ERROR [geoserver.rest] - No such layer:
> geonode:rivers
> >> layer: geonode:rivers
> >> That looks like a regression? Or some configuration which is not
> correct?
> >> In my case I am using DELAYED_SECURITY_SIGNAL set to True.
> >> thanks
> >> Paolo
> >> On Wed, Sep 4, 2019 at 5:01 PM Paolo Corti <pcorti at gmail.com> wrote:
> >> > Hi devs
> >> > I am experiencing the following issue on an instance using GeoNode
> >> > master from a GeoNode project and PostGIS as a datastore. When
> >> > uploading a layer, I see the following
> >> > error message:
> >> > >>> Step 7. Creating style for [rivers]
> >> > Traceback (most recent call last):
> >> > File "/home/ubuntu/geonode/geonode/geoserver/helpers.py", line 246,
> >> > in get_sld_for
> >> > _default_style = layer.default_style
> >> > AttributeError: 'FeatureType' object has no attribute 'default_style'
> >> > File "/home/ubuntu/geonode/geonode/geoserver/helpers.py", line 255,
> >> > in get_sld_for
> >> > name = gs_layer.default_style.name if gs_layer.default_style is
> >> > not None else "raster"
> >> > AttributeError: 'NoneType' object has no attribute 'default_style'
> >> > after that, the layer is created in Django but not in GeoServer. Any
> >> > hint why this could be happening before I debug it on my own?
> >> > I noticed that after restarting GeoServer the layer is again uploaded
> correctly.
> >> > Paolo
> >> > Paolo Corti
> >> > Geospatial software developer
> >> > web: http://www.paolocorti.net
> >> > twitter: @capooti
> >> > skype: capooti
> >> > #drt3jc1
> >> Paolo Corti
> >> twitter: @capooti
> >> skype: capooti
> >> #drt3jc1
> >> _______________________________________________
> >> geonode-devel mailing list
> >> geonode-devel at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> > GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> > Ing. Alessio Fabiani
> > @alfa7691
> > Founder/Technical Lead
> > GeoSolutions S.A.S.
> > Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> > phone: +39 0584 962313
> > fax: +39 0584 1660272
> > mob: +39 331 6233686
> > http://www.geo-solutions.it
> > http://twitter.com/geosolutions_it
> > Con riferimento alla normativa sul trattamento dei dati personali (Reg.
> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> > This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> Paolo Corti
> twitter: @capooti
> skype: capooti
> #drt3jc1
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190905/3cbb65ed/attachment-0001.html>
More information about the geonode-devel
