[GeoNode-devel] Bootstrap 3 EOL
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Sep 13 03:53:57 PDT 2019
Dear Toni,
that would be great!
You have my great +1
However, we should formally pass through a GNIP.
Il giorno ven 13 set 2019 alle ore 12:28 Toni Schönbuchner <
toni.schoenbuchner at csgis.de> ha scritto:
> Dear Devs,
> we’re currently using bootstrap 3.4 (active LTS Start 2014-11-01) which
> has reached EOL.
> https://github.com/twbs/release
> https://blog.getbootstrap.com/2019/07/24/lts-plan/
> To stay up-to-date we should consider upgrading to version 4.
> Breaking Changes in Version 4
> A) LESS > SASS
> Bootstrap 4 moved from LESS to SASS.
> We would need to convert:
> https://github.com/GeoNode/geonode/tree/master/geonode/static/geonode/less
> https://github.com/GeoNode/geonode/tree/master/geonode/static/geonode/css
> B) Browser Support
> Version 4 does not support Internet Explorer 8, 9, and iOS 6 anymore!
> C) Dropped Glyphicons
> Bootstrap no longer includes Glyphicons. Instead, you’re advised to find
> your own favourites and include them in whichever way you see fit.
> F.e.: https://useiconic.com/open/ or https://octicons.github.com/
> What we get
> - ! Security Fixes (XSS vulnerabilities pop up quite often) !
> - Cards https://coreui.io/docs/components/cards/ (Could be useful for
> featured maps)
> - A more advanced Grid System
> - All JS Plugins use ES6
> - Flexbox
> - Reboot instead of Normalize.css
> - Better Variable handling (Vars not split around severals files anymore)
> - Rem instead of px. (more scalable)
> - New breakpoints
> Before opening a GNIP I would ask if there are voices against an upgrade?
> Cheers,
> Toni
> CSGIS
> Gottschedstraße 12
> 04109 Leipzig
> Telefon 0341. 39 37 3397
> Web https://csgis.de
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
> ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190913/4bfec2cd/attachment-0001.html>
More information about the geonode-devel mailing list
