[GeoNode-devel] Call for a new GeoNode PSC meeting
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Sep 25 01:05:13 PDT 2019
Yep, let's put this topic into the agenda too.
Il giorno mar 24 set 2019 alle ore 08:50 Toni Schönbuchner <
toni.schoenbuchner at csgis.de> ha scritto:
> Hi,
> I am unsure if this must be agreed with the PSC (?). Anyway, an additional
> topic could be the GeonNode Wiki.
> It contains outdated information and partially overlaps with the
> documentation.
> Here is a first suggestion to shorten and revise it. Everyone is invited
> to edit the document.
> https://docs.google.com/document/d/1zYfhAzVCZm4_TwVlkaH-ltKcgsYFmUSGyrxUTQGZM7w/edit?usp=sharing
> Regards,
> Toni
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190925/7c7814a1/attachment-0001.html>
More information about the geonode-devel mailing list
