[GeoNode-devel] Sending emails using Exchange 2013 server and NTLM authentication
EFTAS Fabian Wilske
fabian.wilske at eftas.com
Fri Apr 17 09:55:32 PDT 2020
Dear all,
I'm using GeoNode 2.10.x and want to send mails by using an Exchange 2013 server which only supports NTLM for SMTP authentification. I realized that the default email backend in GeoNode `django.core.mail.backends.smtp.EmailBackend` only supports LOGIN, PLAIN or CRAM-MD5 for authentication. Luckily, I found another backend (https://github.com/shadiakiki1986/django-smtp-ntlm-backend) for NTLM authentication. But it does not work.
I did the following in the Python shell:
>>> from django.core.mail import send_mail
>>> send_mail('test subject', 'message', 'email at address.com', ['recipient at gmail.com'], fail_silently=False,)
File "<stdin>", line 1, in <module>
File "/usr/local/lib/python2.7/site-packages/django/core/mail/__init__.py", line 62, in send_mail
return mail.send()
File "/usr/local/lib/python2.7/site-packages/django/core/mail/message.py", line 348, in send
return self.get_connection(fail_silently).send_messages([self])
File "/usr/local/lib/python2.7/site-packages/django/core/mail/backends/smtp.py", line 111, in send_messages
sent = self._send(message)
File "/usr/local/lib/python2.7/site-packages/django/core/mail/backends/smtp.py", line 127, in _send
self.connection.sendmail(from_email, recipients, message.as_bytes(linesep='\r\n'))
File "smtplib.py", line 736, in sendmail
self.rset()
File "smtplib.py", line 470, in rset
return self.docmd("rset")
File "smtplib.py", line 395, in docmd
return self.getreply()
File "smtplib.py", line 369, in getreply
raise SMTPServerDisconnected("Connection unexpectedly closed")
smtplib.SMTPServerDisconnected: Connection unexpectedly closed
Relevant settings in settings.py:
EMAIL_ENABLE=True
EMAIL_BACKEND=django_smtp_ntlm_backendNTLMEmail
EMAIL_HOST=<mailserver>
EMAIL_PORT=25
EMAIL_HOST_USER=<domain>\<user>
EMAIL_HOST_PASSWORD=<password>
DEFAULT_FROM_EMAIL=<from-email>
EMAIL_USE_SSL=False
EMAIL_USE_TLS=False
The settings for the mail server are correct and the mail server is working fine. I am able to send mails with a SMTP testing tool called Swaks with the same settings using the same mail server. Does anybody has experience with using Exchange and NTLM authentication for sending emails with GeoNode? Or is there any other email backend I can use? I'm grateful for any hints.
Best regards
Fabian
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20200417/793f60e9/attachment.html>
More information about the geonode-devel
