[GeoNode-devel] GeoNode 3.x Advanced Installation and uwsgi issue
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Nov 5 10:50:30 PST 2020
Hi Paolo,
just a double check, make sure that those are correctly set
chdir = <path_of_geonode_code (where you cloned the repo)>
virtualenv = <path_of_the_virtualenv>
if still not working, try to add also the wsgi directive
wsgi-file = <path_of_geonode_code (where you cloned the
repo)>/geonode/wsgi.py
e.g.:
plugin-dir = /usr/lib/uwsgi/plugins
plugin = python3
virtualenv = /home/geosolutions/Envs/geonode3
chdir = /home/geosolutions/geonode/
module = geonode.wsgi:application
wsgi-file = /home/geosolutions/geonode/geonode/wsgi.py
Il giorno gio 5 nov 2020 alle ore 19:38 Paolo Pasquali <
paolo.pasquali at gmail.com> ha scritto:
> Ciao Alessio,
> I'm using the virtualenv.
> As you suggested I added the plugins-dir so now I have in the uwsgi conf:
> plugins-dir = /usr/lib/uwsgi/plugins
> plugins = python3
> Now I'm not getting the no app loaded error anymore but yet the uwsgi
> fails to start.
> Nothing from this:
> $ uwsgi -c /etc/uwsgi/apps-available/geonode.ini
> [uWSGI] getting INI configuration from
> You can find the uwsgi log below. Sorry for the spam.
> Thanks for your help.
> P.
> Thu Nov  5 19:18:40 2020 - *** Starting uWSGI 2.0.18-debian (64bit) on
> [Thu Nov  5 19:18:40 2020] ***
> Thu Nov  5 19:18:40 2020 - compiled with version: 10.0.1 20200405
> (experimental) [master revision
> 0be9efad938:fcb98e4978a:705510a708d3642c9c962beb663c476167e4e8a4] on 11
> April 2020 11:15:55
> Thu Nov  5 19:18:40 2020 - os: Linux-5.4.0-52-generic #57-Ubuntu SMP Thu
> Oct 15 10:57:00 UTC 2020
> Thu Nov  5 19:18:40 2020 - nodename: sdg11lab
> Thu Nov  5 19:18:40 2020 - machine: x86_64
> Thu Nov  5 19:18:40 2020 - clock source: unix
> Thu Nov  5 19:18:40 2020 - pcre jit disabled
> Thu Nov  5 19:18:40 2020 - detected number of CPU cores: 2
> Thu Nov  5 19:18:40 2020 - current working directory: /
> Thu Nov  5 19:18:40 2020 - writing pidfile to /tmp/geonode.pid
> Thu Nov  5 19:18:40 2020 - detected binary path: /usr/bin/uwsgi-core
> Thu Nov  5 19:18:40 2020 - chdir() to /opt/sdg11lab/sdg11lab
> Thu Nov  5 19:18:40 2020 - your processes number limit is 63713
> Thu Nov  5 19:18:40 2020 - your memory page size is 4096 bytes
> Thu Nov  5 19:18:40 2020 -  *** WARNING: you have enabled harakiri without
> post buffering. Slow upload could be rejected on post-unbuffered
> webservers ***
> Thu Nov  5 19:18:40 2020 - detected max file descriptor number: 1024
> Thu Nov  5 19:18:40 2020 - lock engine: pthread robust mutexes
> Thu Nov  5 19:18:40 2020 - thunder lock: disabled (you can enable it with
> --thunder-lock)
> Thu Nov  5 19:18:40 2020 - uwsgi socket 0 bound to UNIX address
> /run/uwsgi/app/geonode/socket fd 3
> Thu Nov  5 19:18:40 2020 - uwsgi socket 1 bound to TCP address
> 0.0.0.0:8000 fd 5
> Thu Nov  5 19:18:40 2020 - setgid() to 33
> Thu Nov  5 19:18:40 2020 - setuid() to 33
> Thu Nov  5 19:18:40 2020 - Python version: 3.8.5 (default, Jul 28 2020,
> 12:59:40)  [GCC 9.3.0]
> Thu Nov  5 19:18:40 2020 - PEP 405 virtualenv detected:
> /home/geonode/.virtualenvs/geonode
> Thu Nov  5 19:18:40 2020 - Set PythonHome to
> Thu Nov  5 19:18:40 2020 - Python main interpreter initialized at
> 0x562215bceb80
> Thu Nov  5 19:18:40 2020 - python threads support enabled
> Thu Nov  5 19:18:40 2020 - your server socket listen backlog is limited to
> 100 connections
> Thu Nov  5 19:18:40 2020 - your mercy for graceful operations on workers
> is 60 seconds
> Thu Nov  5 19:18:40 2020 - mapped 13105368 bytes (12798 KB) for 128 cores
> Thu Nov  5 19:18:40 2020 - *** Operational MODE: preforking ***
> Thu Nov  5 18:18:43 2020 - WSGI app 0 (mountpoint='') ready in 3 seconds
> on interpreter 0x562215bceb80 pid: 256154 (default app)
> Thu Nov  5 18:18:43 2020 - spawned uWSGI master process (pid: 256154)
> Thu Nov  5 18:18:43 2020 - spawned uWSGI worker 1 (pid: 256273, cores: 1)
> Thu Nov  5 18:18:43 2020 - spawned uWSGI worker 2 (pid: 256274, cores: 1)
> Thu Nov  5 18:18:43 2020 - spawned uWSGI worker 3 (pid: 256275, cores: 1)
> Thu Nov  5 18:18:43 2020 - spawned uWSGI worker 4 (pid: 256276, cores: 1)
> Thu Nov  5 18:18:43 2020 - spawned uWSGI worker 5 (pid: 256277, cores: 1)
> Thu Nov  5 18:18:43 2020 - spawned uWSGI worker 6 (pid: 256278, cores: 1)
> Thu Nov  5 18:18:43 2020 - spawned uWSGI worker 7 (pid: 256279, cores: 1)
> Thu Nov  5 18:18:43 2020 - spawned uWSGI worker 8 (pid: 256280, cores: 1)
> Thu Nov  5 18:18:43 2020 - spawned uWSGI worker 9 (pid: 256281, cores: 1)
> Thu Nov  5 18:18:43 2020 - spawned uWSGI worker 10 (pid: 256282, cores: 1)
> Thu Nov  5 18:18:43 2020 - spawned uWSGI worker 11 (pid: 256283, cores: 1)
> Thu Nov  5 18:18:43 2020 - spawned uWSGI worker 12 (pid: 256284, cores: 1)
> Thu Nov  5 18:18:43 2020 - spawned uWSGI worker 13 (pid: 256285, cores: 1)
> Thu Nov  5 18:18:43 2020 - spawned uWSGI worker 14 (pid: 256286, cores: 1)
> Thu Nov  5 18:18:43 2020 - spawned uWSGI worker 15 (pid: 256287, cores: 1)
> Thu Nov  5 18:18:43 2020 - spawned uWSGI worker 16 (pid: 256288, cores: 1)
> Thu Nov  5 18:18:43 2020 - unable to find requested cheaper algorithm,
> falling back to spare
> Thu Nov  5 18:18:45 2020 - worker 1 killed successfully (pid: 256273)
> Thu Nov  5 18:18:45 2020 - uWSGI worker 1 cheaped.
> Thu Nov  5 18:18:46 2020 - worker 2 killed successfully (pid: 256274)
> Thu Nov  5 18:18:46 2020 - uWSGI worker 2 cheaped.
> Thu Nov  5 18:18:47 2020 - worker 3 killed successfully (pid: 256275)
> Thu Nov  5 18:18:47 2020 - uWSGI worker 3 cheaped.
> Thu Nov  5 18:18:48 2020 - worker 4 killed successfully (pid: 256276)
> Thu Nov  5 18:18:48 2020 - uWSGI worker 4 cheaped.
> Thu Nov  5 18:18:49 2020 - worker 5 killed successfully (pid: 256277)
> Thu Nov  5 18:18:49 2020 - uWSGI worker 5 cheaped.
> Thu Nov  5 18:18:50 2020 - worker 6 killed successfully (pid: 256278)
> Thu Nov  5 18:18:50 2020 - uWSGI worker 6 cheaped.
> Thu Nov  5 18:18:51 2020 - worker 7 killed successfully (pid: 256279)
> Thu Nov  5 18:18:51 2020 - uWSGI worker 7 cheaped.
> Thu Nov  5 18:18:52 2020 - worker 8 killed successfully (pid: 256280)
> Thu Nov  5 18:18:52 2020 - uWSGI worker 8 cheaped.
> On Thu, Nov 5, 2020 at 7:12 PM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> It is also worth to take a look at this
>> https://stackoverflow.com/questions/41535283/unable-to-load-uwsgi-plugin-python3-plugin-so-cannot-open-shared-object-file
>> it seems that someone solved the issue by adding a "plugins-dir"
>> directive to the conf.
>> Il giorno gio 5 nov 2020 alle ore 19:09 Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> ha scritto:
>>> Paolo,
>>> it looks like you are not using the correct python environment.
>>> I guess you need to activate it before running UWSGI.
>>> Il giorno gio 5 nov 2020 alle ore 18:26 Paolo Pasquali <
>>>> Thank you, Alessio.
>>>> I get this error.
>>>> open("./python3_plugin.so"): No such file or directory [core/utils.c
>>>> line 3732]
>>>> !!! UNABLE to load uWSGI plugin: ./python3_plugin.so: cannot open
>>>> shared object file: No such file or directory !!!
>>>> The plugin is located at
>>>> $ locate python3_plugin.so
>>>> /usr/lib/uwsgi/plugins/python3_plugin.so
>>>> So if I remove from the geonode.ini file plugins = python3
>>>> And then I still get
>>>> $ sudo service uwsgi start
>>>> Job for uwsgi.service failed because the control process exited with
>>>> error code.
>>>> Maybe because from the log
>>>> Thu Nov  5 17:47:50 2020 - *** Operational MODE: preforking ***
>>>> Thu Nov  5 17:47:50 2020 - *** no app loaded. GAME OVER ***
>>>> Thu Nov  5 17:47:50 2020 - VACUUM: unix socket
>>>> /run/uwsgi/app/geonode/socket removed.
>>>> Any hint or cue on this?
>>>> Thanks!
>>>> Paolo
>>>> On Thu, Nov 5, 2020 at 3:01 PM Alessio Fabiani <
>>>>> Hi Paolo,
>>>>> from the logs I cannot recognize any specific issue.
>>>>> It might depend on some error during the application initialization.
>>>>> You could do a simple test by trying to run uwsgi from the
>>>>> command line, e.g.:
>>>>> uwsgi -c <path to the uwsgi config ini>
>>>>> Il giorno gio 5 nov 2020 alle ore 10:44 Paolo Pasquali <
>>>>>> Dear devs,
>>>>>> I'm following the 3.x documentation for installing GeoNode on Ubuntu
>>>>>> 20 without docker.
>>>>>> At some point I have to create the uwsgi geonode.ini [1] file.
>>>>>> I have updated the paths in the geonode.ini file according to my
>>>>>> installation and the first thing I have noticed is that I need to add
>>>>>> uid = geonode
>>>>>> or I get a permission denied error when I try to start the service.
>>>>>> That was omitted in the 3.x doc.
>>>>>> Then I get another error.
>>>>>> error code.
>>>>>> See "systemctl status uwsgi.service" and "journalctl -xe" for details.
>>>>>> $ systemctl status uwsgi.service
>>>>>> *●* uwsgi.service - LSB: Start/stop uWSGI server instance(s)
>>>>>>      Loaded: loaded (/etc/init.d/uwsgi; generated)
>>>>>>      Active: *failed* (Result: exit-code) since Thu 2020-11-05
>>>>>> 10:02:52 CET; 14s ago
>>>>>>        Docs: man:systemd-sysv-generator(8)
>>>>>>     Process: 208347 ExecStart=/etc/init.d/uwsgi start *(code=exited,
>>>>>> status=1/FAILURE)*
>>>>>>       Tasks: 9 (limit: 19114)
>>>>>> Some uwgi processes are active anyway.
>>>>>> I'm attaching the log file. Could you please help me understand the
>>>>>> error I'm getting?
>>>>>> I can see an "unable to find requested cheaper algorithm, falling
>>>>>> back to spare" which is new from 2.10.
>>>>>> Thanks!
>>>>>> Regards,
>>>>>> Paolo
>>>>>> [1]
>>>>>> https://docs.geonode.org/en/3.x/install/advanced/core/index.html#serving-geonode-geoserver-via-nginx
>>>>>> _______________________________________________
>>>>>> geonode-devel mailing list
>>>>>> geonode-devel at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>> GeoServer Professional Services from the experts! Visit
>>>>> http://goo.gl/it488V for more information.
>>>>> Ing. Alessio Fabiani
>>>>> @alfa7691
>>>>> Founder/Technical Lead
>>>>> GeoSolutions S.A.S.
>>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>>> phone: +39 0584 962313
>>>>> fax:     +39 0584 1660272
>>>>> mob:   +39 331 6233686
>>>>> http://www.geo-solutions.it
>>>>> http://twitter.com/geosolutions_it
>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>> This email is intended only for the person or entity to which it is
>>>>> addressed and may contain information that is privileged, confidential or
>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>> e-mail or the information herein by anyone other than the intended
>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>> notify us immediately by telephone or e-mail.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> @alfa7691
>> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20201105/bd188c88/attachment-0001.html>
More information about the geonode-devel mailing list
