[GeoNode-devel] GeoNode 3.x Advanced Installation and uwsgi issue
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Fri Nov 6 06:59:51 PST 2020
Hi Paolo,
so, from the logs you reported uwsgi is now working fine so I guess the
only issue is the NGINX configuration for /
Let's try this:
1. on the uwsgi ini file change
uwsgi-socket = 0.0.0.0:8000
to
*http-socket = 0.0.0.0:8000 <http://0.0.0.0:8000>*
2. on NGINX change the configuration for / location as follows
location / {
# Using a variable is a trick to let Nginx start even if upstream host is
not up yet
# (see
https://sandro-keil.de/blog/2017/07/24/let-nginx-start-if-upstream-host-is-unavailable-or-down/
*set $upstream localhost:8000;*
if ($request_method = OPTIONS) {
add_header Access-Control-Allow-Methods "GET, POST, PUT, PATCH,
OPTIONS";
add_header Access-Control-Allow-Headers "Authorization, Content-Type,
Accept";
add_header Access-Control-Allow-Credentials true;
add_header Content-Length 0;
add_header Content-Type text/plain;
add_header Access-Control-Max-Age 1728000;
return 200;
add_header Access-Control-Allow-Credentials false;
add_header Access-Control-Allow-Headers "Content-Type, Accept,
Authorization, Origin, User-Agent";
add_header Access-Control-Allow-Methods "GET, POST, PUT, PATCH, OPTIONS";
proxy_connect_timeout 600;
proxy_send_timeout 600;
proxy_read_timeout 600;
send_timeout 600;
proxy_redirect off;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-Host $server_name;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
*proxy_pass http://$upstream;*
# uwsgi_params
include /etc/nginx/uwsgi_params;
location ~*
\.(?:js|jpg|jpeg|gif|png|tgz|gz|rar|bz2|doc|pdf|ppt|tar|wav|bmp|ttf|rtf|swf|ico|flv|woff|woff2|svg|xml)$
gzip_static always;
expires 30d;
access_log off;
add_header Pragma "public";
add_header Cache-Control "max-age=31536000, public";
- Restart both uwsgi and nginx services
Il giorno ven 6 nov 2020 alle ore 15:41 Paolo Pasquali <
paolo.pasquali at gmail.com> ha scritto:
> Ciao Alessio,
> I've just followed the documentation.
> There is no difference between nginx conf and the doc example and it is
> similar to another GeoNode 2.10 installation that is working.
> Is there something I should look into?
> Thanks.
> P.
> On Fri, Nov 6, 2020 at 12:04 PM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Ciao Paolo,
>> I was wondering it the issue could be the type of socket you are using
>> between nginx and uwsgi, can you double check?
>> Because it looks to me that UWSGI is working fine from the logs.
>> Il giorno gio 5 nov 2020 alle ore 20:18 Paolo Pasquali <
>>> Paths are correct. Nothing changed by adding the wsgi-file directive. No
>>> additional info from the uwsgi log.
>>> I'm attaching my config file if you have time to take a look at it.
>>> There must be some mistake so huge I cannot see it...
>>> Thanks again for your help.
>>> Ciao
>>> P.
>>> On Thu, Nov 5, 2020 at 7:50 PM Alessio Fabiani <
>>>> Hi Paolo,
>>>> just a double check, make sure that those are correctly set
>>>> chdir = <path_of_geonode_code (where you cloned the repo)>
>>>> virtualenv = <path_of_the_virtualenv>
>>>> if still not working, try to add also the wsgi directive
>>>> wsgi-file = <path_of_geonode_code (where you cloned the
>>>> repo)>/geonode/wsgi.py
>>>> e.g.:
>>>> plugin-dir = /usr/lib/uwsgi/plugins
>>>> plugin = python3
>>>> virtualenv = /home/geosolutions/Envs/geonode3
>>>> chdir = /home/geosolutions/geonode/
>>>> module = geonode.wsgi:application
>>>> wsgi-file = /home/geosolutions/geonode/geonode/wsgi.py
>>>> Il giorno gio 5 nov 2020 alle ore 19:38 Paolo Pasquali <
>>>>> Ciao Alessio,
>>>>> I'm using the virtualenv.
>>>>> As you suggested I added the plugins-dir so now I have in the uwsgi
>>>>> conf:
>>>>> plugins-dir = /usr/lib/uwsgi/plugins
>>>>> plugins = python3
>>>>> Now I'm not getting the no app loaded error anymore but yet the uwsgi
>>>>> fails to start.
>>>>> Nothing from this:
>>>>> $ uwsgi -c /etc/uwsgi/apps-available/geonode.ini
>>>>> [uWSGI] getting INI configuration from
>>>>> You can find the uwsgi log below. Sorry for the spam.
>>>>> Thanks for your help.
>>>>> P.
>>>>> Thu Nov 5 19:18:40 2020 - *** Starting uWSGI 2.0.18-debian (64bit) on
>>>>> [Thu Nov 5 19:18:40 2020] ***
>>>>> Thu Nov 5 19:18:40 2020 - compiled with version: 10.0.1 20200405
>>>>> (experimental) [master revision
>>>>> 0be9efad938:fcb98e4978a:705510a708d3642c9c962beb663c476167e4e8a4] on 11
>>>>> April 2020 11:15:55
>>>>> Thu Nov 5 19:18:40 2020 - os: Linux-5.4.0-52-generic #57-Ubuntu SMP
>>>>> Thu Oct 15 10:57:00 UTC 2020
>>>>> Thu Nov 5 19:18:40 2020 - nodename: sdg11lab
>>>>> Thu Nov 5 19:18:40 2020 - machine: x86_64
>>>>> Thu Nov 5 19:18:40 2020 - clock source: unix
>>>>> Thu Nov 5 19:18:40 2020 - pcre jit disabled
>>>>> Thu Nov 5 19:18:40 2020 - detected number of CPU cores: 2
>>>>> Thu Nov 5 19:18:40 2020 - current working directory: /
>>>>> Thu Nov 5 19:18:40 2020 - writing pidfile to /tmp/geonode.pid
>>>>> Thu Nov 5 19:18:40 2020 - detected binary path: /usr/bin/uwsgi-core
>>>>> Thu Nov 5 19:18:40 2020 - chdir() to /opt/sdg11lab/sdg11lab
>>>>> Thu Nov 5 19:18:40 2020 - your processes number limit is 63713
>>>>> Thu Nov 5 19:18:40 2020 - your memory page size is 4096 bytes
>>>>> Thu Nov 5 19:18:40 2020 - *** WARNING: you have enabled harakiri
>>>>> without post buffering. Slow upload could be rejected on
>>>>> post-unbuffered webservers ***
>>>>> Thu Nov 5 19:18:40 2020 - detected max file descriptor number: 1024
>>>>> Thu Nov 5 19:18:40 2020 - lock engine: pthread robust mutexes
>>>>> Thu Nov 5 19:18:40 2020 - thunder lock: disabled (you can enable it
>>>>> with --thunder-lock)
>>>>> Thu Nov 5 19:18:40 2020 - uwsgi socket 0 bound to UNIX address
>>>>> /run/uwsgi/app/geonode/socket fd 3
>>>>> Thu Nov 5 19:18:40 2020 - uwsgi socket 1 bound to TCP address
>>>>> 0.0.0.0:8000 fd 5
>>>>> Thu Nov 5 19:18:40 2020 - setgid() to 33
>>>>> Thu Nov 5 19:18:40 2020 - setuid() to 33
>>>>> Thu Nov 5 19:18:40 2020 - Python version: 3.8.5 (default, Jul 28
>>>>> 2020, 12:59:40) [GCC 9.3.0]
>>>>> Thu Nov 5 19:18:40 2020 - PEP 405 virtualenv detected:
>>>>> /home/geonode/.virtualenvs/geonode
>>>>> Thu Nov 5 19:18:40 2020 - Set PythonHome to
>>>>> Thu Nov 5 19:18:40 2020 - Python main interpreter initialized at
>>>>> 0x562215bceb80
>>>>> Thu Nov 5 19:18:40 2020 - python threads support enabled
>>>>> Thu Nov 5 19:18:40 2020 - your server socket listen backlog is
>>>>> limited to 100 connections
>>>>> Thu Nov 5 19:18:40 2020 - your mercy for graceful operations on
>>>>> workers is 60 seconds
>>>>> Thu Nov 5 19:18:40 2020 - mapped 13105368 bytes (12798 KB) for 128
>>>>> cores
>>>>> Thu Nov 5 19:18:40 2020 - *** Operational MODE: preforking ***
>>>>> Thu Nov 5 18:18:43 2020 - WSGI app 0 (mountpoint='') ready in 3
>>>>> seconds on interpreter 0x562215bceb80 pid: 256154 (default app)
>>>>> Thu Nov 5 18:18:43 2020 - spawned uWSGI master process (pid: 256154)
>>>>> Thu Nov 5 18:18:43 2020 - spawned uWSGI worker 1 (pid: 256273, cores:
>>>>> 1)
>>>>> Thu Nov 5 18:18:43 2020 - spawned uWSGI worker 2 (pid: 256274, cores:
>>>>> 1)
>>>>> Thu Nov 5 18:18:43 2020 - spawned uWSGI worker 3 (pid: 256275, cores:
>>>>> 1)
>>>>> Thu Nov 5 18:18:43 2020 - spawned uWSGI worker 4 (pid: 256276, cores:
>>>>> 1)
>>>>> Thu Nov 5 18:18:43 2020 - spawned uWSGI worker 5 (pid: 256277, cores:
>>>>> 1)
>>>>> Thu Nov 5 18:18:43 2020 - spawned uWSGI worker 6 (pid: 256278, cores:
>>>>> 1)
>>>>> Thu Nov 5 18:18:43 2020 - spawned uWSGI worker 7 (pid: 256279, cores:
>>>>> 1)
>>>>> Thu Nov 5 18:18:43 2020 - spawned uWSGI worker 8 (pid: 256280, cores:
>>>>> 1)
>>>>> Thu Nov 5 18:18:43 2020 - spawned uWSGI worker 9 (pid: 256281, cores:
>>>>> 1)
>>>>> Thu Nov 5 18:18:43 2020 - spawned uWSGI worker 10 (pid: 256282,
>>>>> cores: 1)
>>>>> Thu Nov 5 18:18:43 2020 - spawned uWSGI worker 11 (pid: 256283,
>>>>> cores: 1)
>>>>> Thu Nov 5 18:18:43 2020 - spawned uWSGI worker 12 (pid: 256284,
>>>>> cores: 1)
>>>>> Thu Nov 5 18:18:43 2020 - spawned uWSGI worker 13 (pid: 256285,
>>>>> cores: 1)
>>>>> Thu Nov 5 18:18:43 2020 - spawned uWSGI worker 14 (pid: 256286,
>>>>> cores: 1)
>>>>> Thu Nov 5 18:18:43 2020 - spawned uWSGI worker 15 (pid: 256287,
>>>>> cores: 1)
>>>>> Thu Nov 5 18:18:43 2020 - spawned uWSGI worker 16 (pid: 256288,
>>>>> cores: 1)
>>>>> Thu Nov 5 18:18:43 2020 - unable to find requested cheaper algorithm,
>>>>> falling back to spare
>>>>> Thu Nov 5 18:18:45 2020 - worker 1 killed successfully (pid: 256273)
>>>>> Thu Nov 5 18:18:45 2020 - uWSGI worker 1 cheaped.
>>>>> Thu Nov 5 18:18:46 2020 - worker 2 killed successfully (pid: 256274)
>>>>> Thu Nov 5 18:18:46 2020 - uWSGI worker 2 cheaped.
>>>>> Thu Nov 5 18:18:47 2020 - worker 3 killed successfully (pid: 256275)
>>>>> Thu Nov 5 18:18:47 2020 - uWSGI worker 3 cheaped.
>>>>> Thu Nov 5 18:18:48 2020 - worker 4 killed successfully (pid: 256276)
>>>>> Thu Nov 5 18:18:48 2020 - uWSGI worker 4 cheaped.
>>>>> Thu Nov 5 18:18:49 2020 - worker 5 killed successfully (pid: 256277)
>>>>> Thu Nov 5 18:18:49 2020 - uWSGI worker 5 cheaped.
>>>>> Thu Nov 5 18:18:50 2020 - worker 6 killed successfully (pid: 256278)
>>>>> Thu Nov 5 18:18:50 2020 - uWSGI worker 6 cheaped.
>>>>> Thu Nov 5 18:18:51 2020 - worker 7 killed successfully (pid: 256279)
>>>>> Thu Nov 5 18:18:51 2020 - uWSGI worker 7 cheaped.
>>>>> Thu Nov 5 18:18:52 2020 - worker 8 killed successfully (pid: 256280)
>>>>> Thu Nov 5 18:18:52 2020 - uWSGI worker 8 cheaped.
>>>>> On Thu, Nov 5, 2020 at 7:12 PM Alessio Fabiani <
>>>>>> It is also worth to take a look at this
>>>>>> https://stackoverflow.com/questions/41535283/unable-to-load-uwsgi-plugin-python3-plugin-so-cannot-open-shared-object-file
>>>>>> it seems that someone solved the issue by adding a "plugins-dir"
>>>>>> directive to the conf.
>>>>>> Il giorno gio 5 nov 2020 alle ore 19:09 Alessio Fabiani <
>>>>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>>>>>> Paolo,
>>>>>>> it looks like you are not using the correct python environment.
>>>>>>> I guess you need to activate it before running UWSGI.
>>>>>>> Il giorno gio 5 nov 2020 alle ore 18:26 Paolo Pasquali <
>>>>>>>> Thank you, Alessio.
>>>>>>>> I get this error.
>>>>>>>> open("./python3_plugin.so"): No such file or directory
>>>>>>>> [core/utils.c line 3732]
>>>>>>>> !!! UNABLE to load uWSGI plugin: ./python3_plugin.so: cannot open
>>>>>>>> shared object file: No such file or directory !!!
>>>>>>>> The plugin is located at
>>>>>>>> $ locate python3_plugin.so
>>>>>>>> /usr/lib/uwsgi/plugins/python3_plugin.so
>>>>>>>> So if I remove from the geonode.ini file plugins = python3
>>>>>>>> And then I still get
>>>>>>>> $ sudo service uwsgi start
>>>>>>>> Job for uwsgi.service failed because the control process exited
>>>>>>>> with error code.
>>>>>>>> Maybe because from the log
>>>>>>>> Thu Nov 5 17:47:50 2020 - *** Operational MODE: preforking ***
>>>>>>>> Thu Nov 5 17:47:50 2020 - *** no app loaded. GAME OVER ***
>>>>>>>> Thu Nov 5 17:47:50 2020 - VACUUM: unix socket
>>>>>>>> /run/uwsgi/app/geonode/socket removed.
>>>>>>>> Any hint or cue on this?
>>>>>>>> Thanks!
>>>>>>>> Paolo
>>>>>>>> On Thu, Nov 5, 2020 at 3:01 PM Alessio Fabiani <
>>>>>>>>> Hi Paolo,
>>>>>>>>> from the logs I cannot recognize any specific issue.
>>>>>>>>> It might depend on some error during the application
>>>>>>>>> initialization.
>>>>>>>>> You could do a simple test by trying to run uwsgi from the
>>>>>>>>> command line, e.g.:
>>>>>>>>> uwsgi -c <path to the uwsgi config ini>
>>>>>>>>> Il giorno gio 5 nov 2020 alle ore 10:44 Paolo Pasquali <
>>>>>>>>>> Dear devs,
>>>>>>>>>> I'm following the 3.x documentation for installing GeoNode on
>>>>>>>>>> Ubuntu 20 without docker.
>>>>>>>>>> At some point I have to create the uwsgi geonode.ini [1] file.
>>>>>>>>>> I have updated the paths in the geonode.ini file according to my
>>>>>>>>>> installation and the first thing I have noticed is that I need to add
>>>>>>>>>> uid = geonode
>>>>>>>>>> or I get a permission denied error when I try to start the
>>>>>>>>>> service. That was omitted in the 3.x doc.
>>>>>>>>>> Then I get another error.
>>>>>>>>>> with error code.
>>>>>>>>>> See "systemctl status uwsgi.service" and "journalctl -xe" for
>>>>>>>>>> details.
>>>>>>>>>> $ systemctl status uwsgi.service
>>>>>>>>>> *●* uwsgi.service - LSB: Start/stop uWSGI server instance(s)
>>>>>>>>>> Loaded: loaded (/etc/init.d/uwsgi; generated)
>>>>>>>>>> Active: *failed* (Result: exit-code) since Thu 2020-11-05
>>>>>>>>>> 10:02:52 CET; 14s ago
>>>>>>>>>> Docs: man:systemd-sysv-generator(8)
>>>>>>>>>> Process: 208347 ExecStart=/etc/init.d/uwsgi start *(code=exited,
>>>>>>>>>> status=1/FAILURE)*
>>>>>>>>>> Tasks: 9 (limit: 19114)
>>>>>>>>>> Some uwgi processes are active anyway.
>>>>>>>>>> I'm attaching the log file. Could you please help me understand
>>>>>>>>>> the error I'm getting?
>>>>>>>>>> I can see an "unable to find requested cheaper algorithm, falling
>>>>>>>>>> back to spare" which is new from 2.10.
>>>>>>>>>> Thanks!
>>>>>>>>>> Regards,
>>>>>>>>>> Paolo
>>>>>>>>>> [1]
>>>>>>>>>> https://docs.geonode.org/en/3.x/install/advanced/core/index.html#serving-geonode-geoserver-via-nginx
>>>>>>>>>> _______________________________________________
>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>> @alfa7691
>>>>>>>>> Founder/Technical Lead
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>>>>> phone: +39 0584 962313
>>>>>>>>> fax: +39 0584 1660272
>>>>>>>>> mob: +39 331 6233686
>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>>>> This email is intended only for the person or entity to which it
>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>>>> notify us immediately by telephone or e-mail.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> @alfa7691
>> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20201106/12156d6b/attachment-0001.html>
More information about the geonode-devel
